Bullitt3577 35 Posted April 26, 2017 Had one of these when they came out and wanted to find one for my collection. The body is in pretty bad condition but I may be able to glue it back together for shelf duty since I'm not into running cars these days? The only things it needs is a bumper and the brake lever/arm is missing. It came with a spare engine but it has some kind of epoxy on the case like it was cracked? Both engines have missing fins so I decided to look for a replacement and I found a new one for $10 on eBay. Share this post Link to post Share on other sites
Bullitt3577 35 Posted April 26, 2017 Chassis is in pretty good condition, just oily and dirty! Share this post Link to post Share on other sites
Bullitt3577 35 Posted April 26, 2017 Not too much wear on the bottom. Share this post Link to post Share on other sites
Bullitt3577 35 Posted April 26, 2017 Mostly disassembled 1 Share this post Link to post Share on other sites
Bullitt3577 35 Posted April 26, 2017 The body still needs to be cleaned a bit more before I try and glue it back together. You can see I used the small bumper from the optima re release, just had to drill 2 holes. I'm still going to try and make a bumper that's like the original, just have to order the material. 2 Share this post Link to post Share on other sites
Bullitt3577 35 Posted April 26, 2017 I ended up polishing the chassis, this is what happens when you buy a buffer! Lol 1 Share this post Link to post Share on other sites
Bullitt3577 35 Posted April 26, 2017 I haven't put the radio gear back in yet. The suspension sits a little high but hopefully it'll drop down after I re install the radio gear? I also haven't seen this type of shock collar set up before, I can't soften up the tension on the springs? 1 Share this post Link to post Share on other sites
Granddad Stinky 975 Posted June 28, 2017 On 26/04/2017 at 9:02 AM, Bullitt3577 said: I haven't put the radio gear back in yet. The suspension sits a little high but hopefully it'll drop down after I re install the radio gear? I also haven't seen this type of shock collar set up before, I can't soften up the tension on the springs? I'm pretty sure you can fit these. I've put them on my Re-Re Optima and they really look the part. http://www.watercoolinguk.co.uk/p/Phobya-Hose-Clamp-Hexagonal-10-11mm-Red_33129.html?gclid=Cj0KEQjw4cLKBRCZmNTvyovvj-4BEiQAl_sgQh6D8180w3sqUKGQza8bAC81KGUvfk-P_ccJ1h_YlCAaApEk8P8HAQ Share this post Link to post Share on other sites
Bullitt3577 35 Posted July 13, 2017 On June 28, 2017 at 6:06 AM, Granddad Stinky said: I'm pretty sure you can fit these. I've put them on my Re-Re Optima and they really look the part. http://www.watercoolinguk.co.uk/p/Phobya-Hose-Clamp-Hexagonal-10-11mm-Red_33129.html?gclid=Cj0KEQjw4cLKBRCZmNTvyovvj-4BEiQAl_sgQh6D8180w3sqUKGQza8bAC81KGUvfk-P_ccJ1h_YlCAaApEk8P8HAQ I've seen those but I don't think they work for the plastic shocks. I ended up getting the shocks from the re release optima and installed those and I'm looking at possibly getting an aftermarket front shock tower that puts the shocks more upright. Share this post Link to post Share on other sites
