ThunderDragonCy
Suspension shafts for DT03 - help finding the right kit
Found the screw pins backing out of the front hub ends of the wishbones. Would like to replace with shafts, but having measured the width of the wishbone ends at 22mm I am guessing the 3x22mm shafts recommended for the DT02 will be too short. I have seen some 25.3 which would work with spacers but only seen them in pairs. Are there any other lengths or kits to look out for which would have 4 or 8 shafts in?
Related - are the quoted lengths across the whole shaft or between the e clip grooves? I.e would the 22mm shafts fit a 22mm wide part because they are 22 between the clips, or would they not fit because they are 22mm long and the clips means they only fit around 20mm between the clips?
DT-02 and DT-03 wishbones are identical, so presumably the shafts would be too?
