Granddad Stinky 975 Posted May 29, 2017 I'm sure this had been done to death, so please feel free to direct me to the right place. A little while ago I bought some cheap servos from FleaBay. Guess what? Yup, they're cheap! They're fine on my boats, where they just move a rudder but I'm sure the one in my DT-03 is skipping teeth internally, leaving the servo saver at an angle. What's a reasonable servo to handle Buggy life, that won't break the bank? Thanks. Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted May 29, 2017 Alturn US 770. Cheap as chips but really good Share this post Link to post Share on other sites
Granddad Stinky 975 Posted May 29, 2017 They look just the job, I'll order some now. Many thanks. Share this post Link to post Share on other sites
Supercoolnothing 721 Posted May 29, 2017 I like savox 0252's for my bashers bit more ex but really good quality although like all savoxs they can be a bit power hungry. Share this post Link to post Share on other sites
Buggyjam 144 Posted May 29, 2017 10 minutes ago, Supercoolnothing said: I like savox 0252's for my bashers bit more ex but really good quality although like all savoxs they can be a bit power hungry. Yeah I like Savox. I run a 0231 waterproof in my neo scorcher. I wanted 2 in my truck but researched 2 of them running through one receiver port probably would be too much and cause a trip off. Share this post Link to post Share on other sites
ThunderDragonCy 7776 Posted May 29, 2017 I have a £7.50 alturn in my dt03. No problems. 1 Share this post Link to post Share on other sites
Munchbox 100 Posted May 29, 2017 I was running a 10kg Rage RC in mine. All metal gear, double ball bearing servo for about $10. Very nice unit to begin with. I came down hard and knocked one of the ic chips off the logic board. All 8 solder joints busted hahaha. Now I'm trying a 15kg Qunqi for $12. Same all metal gear and double ball bearings. So far so good. Share this post Link to post Share on other sites
TurnipJF 9111 Posted May 29, 2017 I use an Alturn AAS700 in my F103, which has withstood a season of learning to race on a track, i.e. many, many collisions, with no issues whatsoever. It has nylon gears but is waterproof and ballraced. Share this post Link to post Share on other sites
Granddad Stinky 975 Posted May 29, 2017 1 hour ago, ThunderDragonCy said: I have a £7.50 alturn in my dt03. No problems. This sounds fine for me, I have to manage my disability benefits. Thanks everyone. 1 Share this post Link to post Share on other sites
Wooders28 4703 Posted May 29, 2017 I went for a core rc one in the bullhead (paid £12 If I remember right).Good torque,not that slow and metal gears. https://www.modelsport.co.uk/core-rc-9016mg-servo-9kg-16-sec/rc-car-products/388927 If you think you're stripping gears, I'd look for a metal geared one. Share this post Link to post Share on other sites
Granddad Stinky 975 Posted May 30, 2017 I don't think it's stripping teeth, it's either not meshing properly and skipping one tooth, or one gear riding over the other. The amount that it moves is always the same. Share this post Link to post Share on other sites
iluvmud 812 Posted May 30, 2017 Anyone use JX servos?? Share this post Link to post Share on other sites
berman 5315 Posted May 30, 2017 1 hour ago, Granddad Stinky said: I don't think it's stripping teeth, it's either not meshing properly and skipping one tooth, or one gear riding over the other. The amount that it moves is always the same. Did you have the end points set properly? If the servo has to travel more than the steering allows, it can usually skip or strip a tooth and every time you turn the opposite way, it will veer to the other side. Also make sure there is nothing binding your steering. I prefer Savox 0254 for non metal geared, or the 0352 for metal. Those are my go to servos. 7kg and 14s minimum. Share this post Link to post Share on other sites
GregM 1109 Posted May 30, 2017 On a light 2WD buggy like the DT-03, a Futaba S3003 does a reliable job from my own experience. I personally wouldn't go lower. Mind the numerous fakes on Ebay, though. Also, mind that some servo manufacturers have hubs incompatible to Tamiya's Futaba and Acoms spline type servo savers. Hitec is one of those coming to my mind. cheers, GregM Share this post Link to post Share on other sites
Jonathon Gillham 4595 Posted May 30, 2017 Is this for a racer or a basher? I tried a S3003 on my 4wd and it lasted 4 mins on the track, just couldn't handle the constant jumps and landings. I have found secondhand savox to be the best bet, they are pretty much indestructible, rebuildable, and its surprising how many of them are floating around having done half a dozen race meets for about 40% of the new price. If you are going to check out a club ask around, just pitch it along the lines of you know you need to upgrade, what do people suggest and there will be someone with a spare in their toolbox willing to part with it. Share this post Link to post Share on other sites
Granddad Stinky 975 Posted May 30, 2017 20 hours ago, TwistedxSlayer said: Alturn US 770. Cheap as chips but really good These must be really popular. WheelSpin, ModelSport etc all sold out. A small model shop up north had two left, so I had them. The guy said, with a ball raced spindle and being waterproof, he can't find enough of them to sell, even these were an order that was cancelled. Who's a lucky boy then? 😁 1 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted May 30, 2017 1 hour ago, Granddad Stinky said: These must be really popular. WheelSpin, ModelSport etc all sold out. A small model shop up north had two left, so I had them. The guy said, with a ball raced spindle and being waterproof, he can't find enough of them to sell, even these were an order that was cancelled. Who's a lucky boy then? 😁 I usually buy mine off eBay. Where up north? Share this post Link to post Share on other sites
Granddad Stinky 975 Posted May 30, 2017 Stoke-on-Trent. Share this post Link to post Share on other sites
theRuggedMan 19 Posted May 30, 2017 Are you sure it's not the splines on the servo slipping rather than the gears? Some of those cheapy eBay special servos have horribly weak splines! Share this post Link to post Share on other sites
Granddad Stinky 975 Posted May 30, 2017 2 hours ago, theRuggedMan said: Are you sure it's not the splines on the servo slipping rather than the gears? Some of those cheapy eBay special servos have horribly weak splines! Do you mean the servo saver slipping on the splines? I did check this with two TipEx marks, it's not that. Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted May 30, 2017 I've had a cheap servo slip n the gears and not the splines. Ahhh good ol' Stoke on Trent, not north, Midlands ;-) Share this post Link to post Share on other sites
Granddad Stinky 975 Posted May 30, 2017 14 minutes ago, TwistedxSlayer said: I've had a cheap servo slip n the gears and not the splines. Ahhh good ol' Stoke on Trent, not north, Midlands ;-) I'm a southern softie, anywhere above the M4 is up north! 😁 2 Share this post Link to post Share on other sites
Wooders28 4703 Posted May 30, 2017 The lake district is 2hrs South! 🤔 Share this post Link to post Share on other sites
theRuggedMan 19 Posted May 30, 2017 24 minutes ago, TwistedxSlayer said: I've had a cheap servo slip n the gears and not the splines. Ahhh good ol' Stoke on Trent, not north, Midlands ;-) For me it's always the splines and only after a large crash! Does my nut In sometimes! Stoke on Trent!?!? It's like another country to me! Anything past Stroud is north to me! Lol although I feel I'm in a strange land when I'm on the Mendips! 1 hour ago, Granddad Stinky said: Do you mean the servo saver slipping on the splines? I did check this with two TipEx marks, it's not that. Mute be those gears then! These cheap servos can be false economy sometimes but there ok for shelfers! Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted May 30, 2017 18 minutes ago, Granddad Stinky said: I'm a southern softie, anywhere above the M4 is up north! 😁 Yeah a suppose you have a valid point :-) Share this post Link to post Share on other sites
