ALEXKYRIAK
Racing Fighter Build
EDIT: this thread has been rebuilt, having transferred the photos from photobucket to Flickr (12.01.2017)
Ok, so this started out as a 'build an alternative to the Mad Bull in the form of a monster buggy' concept, using a Racing Fighter DT-03 as a base (inspiration: see @ThunderDragonCy DT-03 build, it's awesome).
What actually happened was I kind of fell in love with the Racing Fighter and decided to build it as per the original design, albeit with a range of hop-ups, and an odd personalised mod here and there....  Here goes.
So this little badger turned up in the post. An absolute steal from Tamico, CVA dampers and Torque Tuned motor included.
IMG_3848
Love the design and format of the chassis and frame:
IMG_3855
First move is to connect the two halves of the chassis. Quite like this design, 3 screws to hold this together:
IMG_3879Dt03
Front suspension brace attached. Hop up coming here soon:
IMG_3884
On to the servo build. Savox Digital SC-1251MG is servo of choice here:
IMG_3887
To be paired with a GPM Racing Products servo saver. Looks more like just a servo steering piece to me, not sure how this constitutes a saver:
IMG_3893
Servo saver mounted with ball studs to receive the steering arms:
IMG_3892
Hop up item. GPM servo mount. Couldn't find silver for love nor money:
IMG_3893
IMG_3894
First time I've used a dedicated servo mount. This is awesome, the servo feels rock solid on the chassis. Tight fit of the servo to the mount also:
IMG_3896
Servo saver mounted to the servo, using my trusty servo tester setup to ensure servo saver is mounted at absolute centre steering on the servo head. Awesome little piece of kit for very little outlay:
IMG_3901
IMG_3902
From servo to steering. I plan to install the DT03 turnbuckle set. First time using these:
IMG_3903
Turnbuckle steering arms fixed to the servo:
IMG_3906
And installed into the chassis. Love the central design of this, with the angled position of the servo:
IMG_3907
And on to the front suspension. Another hop up here. This is the GPM front aluminium suspension mount, replaces the plastic piece:
IMG_3910
IMG_3911
With lower front arms mounted:
IMG_3912
Installed to chassis:
IMG_3914
And cover by front skid plate. Love the design of this front suspension mount assembly:
IMG_3915
IMG_3917
IMG_3916
Next, on to the front wheel c-hubs. A hop up here, aluminium hubs from GPM:
IMG_3919
Beautiful looking piece of kit. Have gone for silver all round where possible:
IMG_3920
And not forgetting the front knuckle arm hop up, also GPM:
IMG_3922
Installed ball studs for steering:
IMG_3924
The completed assembly at the end of the front arms. Also shown here is the turnbuckle upper "arm" hop up, which adjust wheel camber:
IMG_3946
IMG_3942
These turnbuckle steering link things can hurt thumbs when assembling, get some good pliers and a flat faced  plier, makes it real easy:
IMG_3940
On to the rear gear box. Decided to try out AW Grease as recommended on this forum, to achieve a semi limited slip differential affect:
IMG_3997
Applied to the differential gears (reverse callipers recommended..!)
IMG_3998
Installed in the main differential gear case:
IMG_4007
And with counter gear, all ball raced:
IMG_4002
Installed in gear box housing:
IMG_4005
Completed gear box:
IMG_4010
On to the motor. A brushless sensored speedpassion 13.5t.
IMG_4011
IMG_4012
Mounted into gearbox, motor set to the 17t pinion orientation:
IMG_4016
Spur gear fitted to gearbox, and 17t steel pinion fitted to motor:
IMG_4019
IMG_4018
Gearbox fully closed up:
IMG_4021
Rest of build to follow tomorrow night.
Lower arms mounted to the rear gearbox. Upper arms not required as these will be replaced with the turnbuckle arms:
IMG_4023
IMG_4025
Said arms from the DT-03 Turnbuckle set. These are a right pain to tighten up equally! I like the way the screw direction is opposite at each end to allow the arm to get longer or shorter:
IMG_4026
Next item to install, hop up Gear Box joints. This metal part replaces the plastic part N2. This is the main drive from the gearbox:
IMG_4028
Metal driveshaft replacement part for N3, 3 inch dogbone.
IMG_4034
The drive shaft links between the gear box joint and this part, the TG10 Wheel axle:
IMG_4033
The wheel axle sits in the GPM aluminium rear knuckle arms which carries the rear wheel:
IMG_4032
So here you can see the gear box joint mounted to the gearbox on the right, and the wheel axle and the rear knuckle arm on the left. Driveshaft not yet installed:
IMG_4035
Getting the driveshaft installed requires you to hold the knuckle arm in place and slot the shaft in....
IMG_4036
With some grease, I used molybdenum grease (not kit standard but used on the HotShot for example), got this from Tamico. Applied to the gear box joint and the wheel axle:
IMG_4030
So putting that lot together looks a bit like this:
IMG_4037
Again, the stock plastic upper arm is not required, turnbuckle arm replaces it, providing adjustability for camber.
(will have to post rest of build tomorrow.... Tamiyaclub website and photobucket website are playing up big time tonight, taking ages to post stuff - and I just lost a big bit of the post.... :(  )
Looks great! Following along. I just ordered the Chrome version, been waiting forever for it to get back in stock....What a great looking piece of art!
Ok so all suspension arms on, front and rear:
IMG_4045
IMG_4047
So now onto the shock towers - sorry, "damper stays". Another hop up here, carbon damper stays. Mmmmm.... lovely carbon:
IMG_4050
Front is top, rear is below:
IMG_4052
Front damper stay:
IMG_4065
Rear stay:
IMG_4079
Another nod to ThunderDragon, I checked out the DF-03 spring set, very nice hop up pack indeed. These are to go on CVA 2 mini (front) and short (rear) shock bodies.
IMG_4053
IMG_4058
IMG_4057
^^^Very useful diagrams, these ^^^
When building the shocks, I went with three hole pistons front and rear in the end:
IMG_4060
Black springs front (stiff), gold rear (medium).
IMG_4062
Ball studs mounted to damper stays: this is the top of the rear:
IMG_4075
 Long ball stud screw goes into rear lower arm:
IMG_4074
Rear shock installed:
IMG_4083
IMG_4079
Front shocks:
IMG_4078
IMG_4084
IMG_4085
Wheels and tyres, tried ThunderDragons Schumacher CAT block tyres mounted onto the kit standard wheels, because they look awesome on stock wheels...!:
IMG_4090
IMG_4111
IMG_4109
IMG_4112
Front wheel inside detail with front C-hub and knuckle arm:
IMG_4119
IMG_4120
Rear inside hub detail:
IMG_4123
Time to test fit body:
IMG_4162
ime to
About to paint.... still can't decide on a bl**dy colour scheme.... only had a month to choose....!
IMG_4177
Went stealth black in the end....!
IMG_4219
IMG_4225
IMG_4257
IMG_4224
IMG_4220
IMG_4235
IMG_4237
IMG_4230
IMG_4248
IMG_4252
IMG_4255
IMG_4251
Will sticker it up at the weekend....!
One minor mod you'll see in the pics above is the angle up of the rear wing, to give it a bit more of an aggressive, more old-school buggy feel:
IMG_4222
This was achieved using this piece, the stock rear gearbox bracing arm, part C3. This was a left over as I replaced this with an aluminium hop up as mentioned earlier in the thread:
IMG_4184
Made some holes in the rear wing bracket, traced the C3 holes onto M5, shown in two white dots below:
IMG_4185
And drilled M5 and M4 at the same time (vice used to hold them together), and then fixed the C3 part to it:
IMG_4187
IMG_4205
This pushes the wing part upwards when mounted to the wing mount:
IMG_4258
IMG_4259
Just used a 3mm drill to create the two holes in parts M4 and M5, and two m3 bolts and two m3 nuts to connect the two pieces. Nice uplift at the rear end...!
IMG_4250
Looks good, i wish i could find the gpm front suspension arm mount. One of the only upgrades i dont have for my dt03t
Thanks guys, really enjoyed building it. Big thanks to Thunder's detailed build thread, learned a lot from him.
Will need to give it some stickers.
I also have a second body I'll try in an orange colour.
Then I will run it...!
I'll try to create a consolidated list of the components and hop ups used in this thread soon.
I quite like the look of these. Not had a 2wd buggy since my first which was a Hornet.
Best leave it til after I get my boys some cars though.
Or I could go for red body, silver roof, white wheels, a few number 3 stickers, and make it 'project RacingShot'....!
Excellent looking DT03, just as good looking as that new chrome version they released!
Thanks Sellig and Jason. Hmmm, chrome you say.... interesting.... !
Yeah, I searched high and low for that component; Europe, US or Asia, no joy however. Sometimes you can't let one hop-up hold up the whole build, so I had to ignore it on this one. In a mad irrational burst of purchasing insanity,  I sort of ordered another Racing Fighter kit right after finishing the paint job of this one on Sunday night ...
Nice build I've broken or bent quite a lot of my gpm aluminium parts and replaced them with the kit plastic parts again. The aluminium servo mount makes a big difference to the stiffness of the front.
Have you broken the gearcase where the arms connect? I have broken it four times since january, prior to that went a year with no issues.
I have all the tamiya hop ups with no issues. GPM parts i have rear knuckles, hexes, c hubs and front rocker arms never had issues. I had the gpm dogbones but changed to tamiya universals.
I can vouch that jazzride aluminum is junk
Fingers crossed I've had no rear end breakages. I bent the front hubs and broke the shock tower mount.
What actually happened was I kind of fell in love with the Mad Fighter and decided to build it as per the original design, albeit with a range of hop-ups, and an odd personalised mod here and there....  Here goes.
IMG_3848
Ok, the second Racing Fighter kit turned up. Now I can start my Mad Bull Alternative project in earnest!
Will do the Mad Bull alternative on a separate thread to keep this one simple. Looking forward to that one...!
On this car, I made a small adjustment to the rear shocks: I replaced part X1 with X2 to make the shocks longer- I think I overtightened X2 the first time around and damaged it, so had to make do with installing X1 until I could get more X2s.
Went from top top to bottom:
IMG_4525
This X2 part was troublesome as I wasn't sure how much thread was supposed to be left visible. See below, this feels like I haven't installed it correctly but it doesn't seem to go on further than this:
IMG_4527
With the longer shock, the rear of the car now has a lot more clearance. Have subsequently corrected the amount of thread that goes into the plastic.
