TT-02B Neo Scorcher
Tamiya Neo Scorcher TT-02B buggy for sale.
This is an extremely fast buggy, and has been upgraded to handle the power with almost every part of the drivetrain upgraded to cope with the power of the mamba max pro and 5700kv motor. Postage to mainland UK is included in price.
Upgraded with the following parts:
Ball bearings used throughout.
Castle creations 5700kv 4 pole motor.
Castle creations mamba max pro ESC, and castle link. On/Off switch removed to reduce wiring, powers on with battery connected. (wired for 4mm bullet connector to battery)
DF-02 bevel gears and differentials (metal gears as stock plastic do not survive long)
Square racing Japan universal shafts front and rear.
Square racing rear hubs
Tamiya aluminium centre shaft with aluminium drive cups.
Tamiya aluminium steering mechanism
Adjustable turnbuckles all round.
Fresh set of shocks and springs newly built.
Square racing carbon fibre rear shock tower (plastic stock part flexes too much, do not run front carbon tower as angle of deflection will mean it does not survive an impact.)
Yeah racing adjustable motor mount.
Custom gearing with 34 tooth pinion along with the powerful motor make this a very fast buggy.
High speed spur gear set allowing use of any spur gear.
Hitec HS-7966HB coreless steering servo for ultra quick and accurate steering.
Custom rear wing.
Pro line Dirt Hawg tyres.
2 channel etronix pulse radio control transmitter and receiver.
This buggy has been pushed hard to find the limits of the tt-02b, but every component has always been replaced or upgraded where needed to get to what I believe is the most durable setup. Would like to get £260  posted given the components used in the drive train but happy to entertain reasonable offers. Check my vids in the youtube thread to see how quick this thing is.
