vwbug2016 1 Posted August 4, 2017 Came out great but my steering does not centre well any ideas? I thought perhaps the rubber covers were snagging but looks ok. Servo is centred correctly... Share this post Link to post Share on other sites
Snappy1 667 Posted August 5, 2017 Is it a very cheap servo? I have found the cheap ones don't centre correctly, Remove the servo saver from the steering mechanism, if the steering is not binding without the servo, it probably isn't the steering at fault Share this post Link to post Share on other sites
vwbug2016 1 Posted August 5, 2017 Its standard futaba used in the xb kits ill try and post a video, you turn and then it just wont return straight very annoying! Share this post Link to post Share on other sites
Delayar 13 Posted August 8, 2017 The Bigwig needs a servo with a higher torque, because the rubber boots add some resistance to the steering. I also had problems with a cheap standard servo, I replaced it with one which has a torque of 110Ncm (at 6V). It now works fine. I wonder if a high torque servo saver would further improve the steering. Cheers, Markus Share this post Link to post Share on other sites
vwbug2016 1 Posted August 8, 2017 Can you recommend a servo ? Simon Share this post Link to post Share on other sites
Delayar 13 Posted August 8, 2017 Hi! I have this one in my Bigwig: https://www.der-schweighofer.at/en/Servo-MEX-645BB-MG-Digital-Standard-modelleXXpert-a100613 Cheers, Markus Share this post Link to post Share on other sites
tamiya monkey 209 Posted May 25, 2018 Hi everyone, my steering works fine, but doesn't have much lock, is this normal or is it just mine, ive tried altering the end points but doesn't help much. Share this post Link to post Share on other sites
Jonathon Gillham 3186 Posted May 25, 2018 Its probably normal, none of the Shot series cars have great steering lock. Share this post Link to post Share on other sites
