velineon 11 Posted August 13, 2017 After spending a long time digging through threads, trying to find a comprehensive list of all the period Hop-Ups for the DF01/TA01 platform and its descendants, I realized there were none. So I decided to make my own. I used futureworks' list as a base and expanded it from there. It's still in progress, but its sorted by manufacturer, and I'm trying to get a link for an image of each hop up, preferably in original packaging for each item. I have used the exact terminology that Tamiya used for naming each Hop-Up. I hope this is helpful for people who want to make a "checklist" of sorts for their cars, or for others like me, who just wanted to see what was out there for this chassis. Please let me know if you have any additions or suggestions, or if you have any corrections. Period Correct TA01/TA02/Manta Ray/Dirt Thrasher/Blazing Star/Top-Force Hop Ups Limited Edition Anodized Aluminum 49068 Aluminum King Pins (Blue) (same as 53157) 49092 Aluminum Servo Stay (Blue) (same as 53308) 49096 Aluminum Servo Stay (Pink) (same as 53308) 49098 TA03 Universal Drive Shaft (1 Pair) (Pink) (same as 53310, but Pink Ltd. Ed.) 49099 TA03 Super Low Friction Damper Set (Silver & Blue) (same as 53280) 49100 TA03 Super Low Friction Damper Set (Silver & Pink) (same as 53280) 49101 Aluminum King Pins (Pink) (same as 53157) Limited Edition Plastics 49543 4WD Touring & Rally Car Fluorescent Yellow Suspension Arms 49544 4WD Touring & Rally Car Fluorescent Green Suspension Arms 49545 Fluorescent Green Adjuster Set 49546 Fluorescent Pink Adjuster Set 49547 4WD Touring & Rally Car Fluorescent Yellow Gear Case Set (F & R) 49548 4WD Touring & Rally Car Fluorescent Green Gear Case Set (F & R) 49549 4WD Fluorescent Gear Case (Pink) 49550 Manta Ray TA01 Fluorescent Yellow Chassis 49551 Manta Ray TA01 Fluorescent Orange Chassis 49552 Manta Ray TA01 Fluorescent Green Chassis 49553 Fluorescent High Torque Servo Saver Set (Yellow) 49554 Fluorescent High Torque Servo Saver Set (Green) 49555 4WD FF Touring Car Fluorescent Orange Damper Spring 49556 4WD FF Touring Car Fluorescent Green Damper Spring 49557 4WD Rally Car Fluorescent Yellow Damper Spring 49558 4WD Rally Car Fluorescent Pink Damper Spring 49559 4WD/FWD Touring & Rally Car Plated Mesh Wheels 49560 4WD/FWD Touring & Rally Car Plated Spoke Wheels 49567 TRF Acto tuned motor 49572 TA01 Chassis White Suspension Arms (F & R) 49573 TA02 Chassis White Suspension Arms (F & R) 49574 FWD Touring Car White Suspension Arms (F & R) 49575 Manta Ray White Suspension Arms (F & R) 49576 Castrol Celica Chrome Plated Wheel 4pc 49577 CVA Mini Shock Unit Set II White 49578 4WD TA02 & FWD Car Super White Chassis 49579 4WD TA02 & FWD Car Fluorescent Orange Chassis 53024 Aluminum Flange Lock Nut 53029 1150 Sealed Ball Bearing Set (2 pcs.) 53030 850 Sealed Ball Bearing Set (4 pcs.) (for servo hinges on 53166) 53042 Ball Diff Grease 53056 Pin Type Wheel Adapter (aluminum wheel hexes) 53068 RS-540 Sport Tuned Motor 53070 Manta Ray Ball Diff Set 53071 Manta Ray Torque Splitter Set 53072 Manta Ray Differential Ball & Plate Set 53073 Manta Ray Ball Bearing Set 53079 Manta Ray Stainless Steel Propellor Shaft Set 53095 3x10mm Titanium Tapping Screw (10 pcs.) 53098 4WD Stainless Steel Suspension Shaft Set 53099 Manta Ray F.R.P. Double-Deck Chassis Set 53100 Top-Force Carbon Graphite Chassis Set 53112 Top-Force Aluminum Pressure Plate Set 53115 Skyline GT-R Universal Shaft Set 53118 Skyline GT-R Hard Joint Cup Set 53124 3mm Tungsten-Carbide Diff Ball Set 53127 Skyline Speed Tuned Gear Set 53131 Skyline GT-R Aluminum Mesh Wheels 53140 Skyline GT-R Aluminum 6-Spoke Wheels 53141 4WD Touring & Rally Car Lightweight King Pins 53142 Touring & Rally Car Aluminum Motor Mount 53143 4WD Rally Car Skid Guard Set 53144 Touring & Rally Car Bushing & Ball Connector Set 53145 4WD Touring & Rally Car Urethane Bumper Set 53153 Acto-Power Touring Special Motor 53152 TA02 Short Type Hard Propeller Shaft 53155 Low Friction Aluminum Damper Set (Pink Std., Blue & Black Ltd. Ed.) 53156 4WD/FWD Touring & Rally Car Hard Inner Sponge Set 53157 4WD TA02/FWD Chassis Aluminum King Pins 53161 Aluminum Flange Lock Nut (Gold) 53162 Aluminum Flange Lock Nut (Black) 53163 On-Road Tuned Spring Set (4WD/FWD Touring & Rally Car) 53164 Touring & Rally Car Hollow Carbon Gear Shaft Set 53166 4WD TA02/FWD Chassis F.R.P. Chassis Set 53167 4WD Touring & Rally Car Bearing Set (TA02 Chassis) 53172 4WD TA02/FWD Chassis Universal Shaft Set 53189 4WD Touring & Rally Car Rear Stabilizer Set 53191 4WD/FWD Front Turnbuckle Tie-Rod Set 53192 Turnbuckle Upper Arm Set 53193 FRP Front Damper Stay 53194 FRP Rear Damper Stay 53195 4WD/FWD Carbon Chassis Plates 53200 4WD Front One-way Diff Unit 53209 1/10 Touring & Rally Car Shaped Tire Insert (1 Pair) 53216 1/10 Touring & Rally Car Shaped Tire Insert, Wide (1 Pair) 53217 Touring Car Hard Joint Cup Set (For Ball Diff) (replace 53267) 53218 Touring Car Hard Joint Cup Set (For Gear Diff) 53219 1/10 Touring Car Aluminum Pressure Plate Set 53226 1/10 Touring Car Aluminum Front Hub Carrier (1 Pair) 53227 1/10 4WD/FWD Touring Car M2 Radial Tires (1 Pair) 53280 TA03 Super Low Friction Aluminum Damper Set 53310 TA03 Universal Drive Shaft (1 Pair) (same as 53172, except w/ blue anodized collar) 53325 TA03 Aluminum Knuckle Arms 53642 5mm Ball connector Blue 53596 Aluminum Servo Stays (Short) 58157 TA02 Special Chassis --- Aftermarket AR Products TA-06L TA-10 TA-14 TA-20 Tamiya TA01 Top Force King Pin Cross TR-15FP Strong Front Lower Suspension Arms Upper Links TA01 TR32 Suspension Arm TR32UF Tamiya TA02 Front Universal Shaft For Cross TR32 Susp Arm HPI 6124 HPI Front One way for Tamiya TA01 TA02 6400 Rear Lowering set for Tamiya 4WD 6410 Front Lowering set for Tamiya 4WD 8011 Tamiya 4wd fiberglass chassis set HJ060 Tamiya TA02 Chassis (longitudinal battery) Kawada TU-07 Tamiya TA01 Tie Rod Set TU-10 Tamiya TA01 Aluminum Rear Sus Arm TU-11 Tamiya TA01 Adjustable Upper Arm TU-13 Tamiya TA01 Turnbuckle Tie Rod Set TU-?? Tamiya TA01 Aluminum Front Sus Arm Kose K-0810 Universal Shaft. Long Suspension Arm (Tamiya TA01, FF01) K-1104 One Way Joint Cup (Tamiya TA01 TA02 TA02W) K-1552 Titanium King Pin (Tamiya TA01 Series) K-1902 Front One-Way Unit (Tamiya TA01, TA02, TA02W) MRE TA02 Nitro Conversion P&C Racing TA2048 Tamiya TA02/FF Anodized Alloy Steering Assembly Rainbow Products TC-010 Alum Rear Upper Arm (Tamiya TA01) TC-012 Alloy Spindle (Tamiya TA01) TC-014 Alum Front Upper Arm (Tamiya TA01) TC-016 Body Lifter (Tamiya TA01) TC-032 Side Protector (Tamiya TA01) Tech Racing TFF-14 Tamiya FWD FF01 TA02 Complete Rear Upper Suspension Links TSC-2F Front Universal Shaft (Tamiya TA01) TSC-9W Super Tie Rod Set (Tamiya TA01) TSC-11 Tamiya TA02 TA01 4WD Prerunner Front Strut Bar Brace TSC-16 Adjustable Upper Link, Rear (Tamiya TA01) Thunder Tiger 6118-A TA02 Gas Conversion Kit Tobee Craft Screws Other Tamiya RC CARS Bible Catalog TA01 TA02 4WD Rally & FF FWD 1995 Volume-2 3 Share this post Link to post Share on other sites
svenb 1718 Posted August 13, 2017 WOW! Great list, must have taken a far bit of time. I'm lucky enough to have a hopped up TA02 but mine has some more hop ups(Tamiya) 49099 TA03 SUPER LOW FRICTION DAMPER SET(SILVER & BLUE) 49068 BLUE SERVO STAYS 53310 TA03 UNIVERSAL SHAFT SET 53012 3x10mm TITANIUM ROUND HEAD SCREW 53018 3x10mm TITANIUM COUNTERSUNK HEAD SCREW 53021 3mm ALUMINIUM NUT Last 3 for the F.R.P Chassis set and F.R.P Damper stays. ---------------------------------------------- There are also the pink versions of the kingpin(49101) and servo stays(49096) Plus the SILVER & PINK TA03 damper set (49100) TA03 Super Low Friction Damper set (53280) 53209 Shaped Tyre Inserts 53216 Wide Shaped Tyre Inserts 53218 HARD JOINT CUP (FOR GEAR DIFF) Plus all the Hop Up tyres sven 1 Share this post Link to post Share on other sites
velineon 11 Posted August 14, 2017 @svenb Thanks for your feedback, I did some looking at the parts you listed and added them in. Share this post Link to post Share on other sites
Backlash 478 Posted August 14, 2017 What about the HPI centre battery chassis for the FF01 and TA02?? https://tamiyabase.com/forum/forum/16-anything-else/12143-ta-df-01-02-vintage-bits-and-pieces.html?format=html&start=20 1 Share this post Link to post Share on other sites
Tizer 290 Posted August 14, 2017 Great list! I will have a look through my aftermarket hop ups at home. I should still have all the cards somewhere to find the partnumbers. 1 Share this post Link to post Share on other sites
velineon 11 Posted August 14, 2017 9 hours ago, Backlash said: What about the HPI centre battery chassis for the FF01 and TA02?? I forgot about that one,but I did some research and it's part # HJ060, I'll add it to the list Share this post Link to post Share on other sites
Pvt_Joker 0 Posted February 17, 2018 53121 - Skyline long front suspension arm set. Share this post Link to post Share on other sites
OCD 471 Posted February 19, 2018 Phoenix: SS-400 Active Upper Arm Front SS-401 Active Upper Arm Rear GMT-016 TA02 Graphite Chassis Set Tech Racing: TTC-6F Super Stabilizer (Front) Share this post Link to post Share on other sites
Pvt_Joker 0 Posted February 19, 2018 There's a company in China that does anodised alloy parts but they're a bit iffy. I bought a blue prop shaft which was a poor fit and ended up having to modify the gear boxes with a dremel so it could spin freely without the joints rubbing. Didn't mind too much because at the time it was just a basher for the street. I ended up selling the car on ebay as a complete replica shelf queen ta02 racing special full of hop up parts... Share this post Link to post Share on other sites
