Hi guys. I want to replace the steering rods on my re re Frog with modern 3mm sized turnbuckles and centralize the servo. I am not sure what ball joint ends will fit on the steering arms and work with a 3mm turnbuckle. The kit white ones are a bit small to accommodate a 3mm hole I would think. Any suggestions please?
Yep, what I need is some ball joint ends that will fit onto the stock steering arms, and take a thicker steering rod. I am not sure what the steering arm ball size is, so if anyone has done this it would be good :-)
