Has anyone got a pair of these screws? They hold the front arms to the chassis bracket. The 22mm ones are the longer ones that also go through the shock tower. All the frog/brat ones are 3x20.
If not, any ideas what else they are used in? I cant find any.
Thanks.
Thanks.
Can you use M3 screws/bolts and those little brass ferrules?
13 minutes ago, graemevw said:
Just to confirm, these are what I need.
If you really get stuck, send one to me and I'll have a go at making some. I could turn down some M5 stainless Allen bolts and thread the end. 😁
Thanks, but I have a lathe. The thought has crossed my mind.
My lathe is 115 years old though and im still using hand ground cobalt steel tooling. Im not sure I can get a finish good enough to not accelerate wear in the arms.
I will be able to sort something, id much rather have the right screws though. I cant believe they arent reasonably easily available!
Ill make new arms with better attachment points if I have to!!!
  • 6 months later...
