Sign in to follow this
TWINSET
New Carisma RTR Scaler SCA-1E Coyote
RRP £239.99!!
"The RTR Coyote has all the features you would expect of a rig of this type. It’s designed around a steel ‘C’
section ladder chassis, has a detailed 50s style truck body, and is designed to be the starting point for anyone
wanting to get into this exciting a vibrant sector of RC at an affordable price.
It’s not a competition rig; it doesn’t have any fancy gimmicks or technology, but it is a robust, well-designed
and tested one-box solution. Just charge the pack and hit the trails. It really is as simple as that.
But looks can be deceiving: Underneath the understated shell is a full steel UJ equipped driveline with a
locked-axle transmission to generate maximum traction from the slipper clutch protected gearbox, right
through to the wheels and tyres. A 35T brushed motor offers the perfect balance between torque and RPM,
and true 4-link double triangulated link geometry is used to minimise axle steer. The high torque, axle
mounted servo can be chassis mounted in the future if so desired, and the waterproof electronic speed control
is programmable for both NiMH and LiPo use, with a crawler mode set as its default which offers instant
reverse and always-on drag brakes.
The high grip 1.9” offroad tyres are fitted to real beadlock wheels allowing the owner to fine tune the rig’s
weight bias for crawling by adding stick on wheel weights. For fun and trail-only use, the rig’s stock setup is
just perfect. The front bumper is winch-ready and the shell designed to accommodate an LED kit to add that
extra touch of scale realism and allow night runs. Scale, Trail, Crawl. The SCA-1E is capable of all, and the basis
of as detailed or as simple a scale build as you want to undertake.
“Owning a SCA-1E is just the start of the Adventure, where it takes you, is up to you…”
That doesn't look half bad. And if the diffs and transmission can take a bit of beating - that's a winner!
It just finished second in the Proline/G6 Endurance Event in Austria as an out-of-the-box stock rig to get G6 Certification;
Basically, that means it was entered into a comp, driven for 12 hours straight by three different team members and nothing broke.
And the team came 2nd overall, so they weren't kid-gloving it round the course
