I've had a bit of a senior moment. I've bought a 3660 3300kv motor combo for my truck build. Unfortunately, I didn't spot that it has a 5mm shaft. Any help sourcing a TT02BĀ 17t pinion gear would be appreciated.
Thanks. šŸ‘
6 minutes ago, Static Age said:
I'd just run a 5mm drill through the centre of a regular 540 motor pinion.Ā
Yeah, I could do that in my little lathe (Plan B)Ā but I'll see if I can buy a proper one first.
Modelsport sell rw racing pinions with 5mm shaft. not sure of the available pitches though, but it will probably be your best selection. Failing that www.hpcgears.com, but they won't be cheap for one small gear.......
Edit: just checked modelsport and they don't have any 0.6module gears with 5mm shaft :(
Ā
Ā
Ā
Ā
Thanks, I appreciateĀ the homework. šŸ‘
I changed virtually everything else on the truck build, why should this be any different? šŸ¤·ā€ā™‚ļø
Plan B it is,Ā I hope they didn't harden the centre of the gear too much. šŸ¤¦ā€ā™‚ļø
9 minutes ago, Jonathon Gillham said:
When Ā i was trying to find normal pinions I kept finding those with 5mm shafts, check out Hobbyking, pretty sure it was there
Good idea.
    • IXLR8  »  Clappy75
      Hi Jon,
      In the linked image, I've simply moved the bar forward until it is centered directly over the rear shock tower (approx. 10.72mm) and kept the same height. Ā Is this what you had in mind?
      https://flic.kr/p/2roEkj2
      DougĀ
      Ā
      Ā
      · 0 replies
    • WhteRbt
      Checking out this status thing…  And now with a beautiful avatar! šŸ˜‚
      · 0 replies
      · 0 replies
      Hello
      Hope you are well
      Thank you for your help
      Kind regards
      Jack
      · 0 replies
    • seoondaddy
      Seo-onDaddy - YouTube
      · 0 replies
