Maelstrom
The Striker virus spreads
While reading the inspiring threads by kontemax and jason1145 a slightly used Striker came up on ebay and I had to bag it.
Striker restorationStriker restoration
"In need of a little love" it said in the description.
Striker restoration
Loved the home made skid guard.
Striker restoration
And the inventive way of holding the tyres on the wheels!
Striker restoration
As almost all the black plastic was badly scratched I opted to replace most of it and was lucky to find some very cheap replacements
Striker restoration
I stripped and cleaned everything, all the while searching for futher spares.
Then the fever gripped me and I ended up with another 1 1/2 Strikers in bits...
20170903_165236
...and another one...
20170903_165327
Yes, that IS a brushless motor!
Finally the amazing €23 Sonic fighter
20170511_233116
So far I'm just about finished with the first one...
... pics to follow!
Filled the worst scratches with milliput, sanded, based and painted white. The spoiler was badly scratched, so after repairs it was based and painted blue, I also sprayed the nose blue instead of using the sticker.
20170904_201839
20170904_20182420170904_20184620170904_201857
The wheels were unsaveable and were replaced with the rere Grasshopper 2 ones. The "cyan blue" on the repro stickers turned out light blue<_<.
Started in the next one. Blue with white and silver decals is what I have in mind. What do you think?
What a great job you've done on that. A great looking car!
I want one. But not if they breed like rabbits. :)
Love it... so jealous of that €23 Sonic Fighter and the Striker with the purple shocks.. had to double take when I saw 3 motor wires on it!!!!!!! Crazy lol.
The one you have finished looks Ace, how did you do the letter writing on the tyres it  comes out really nice!
The next one sounds good, deep blue maybe with white and silver decals, nice to see creative colours... I'd leave that SF the way it is!
They're available in all sorts of colours and with different size tips. Got mine off amazon.
I'd love to add some alloy front dampers to my next Striker build. Does anyone have spare Sonic Fighter F parts to sell? -not easy to find on ebay :wacko:
Yep - I have 1 S-F F parts left.
Lots of other Sonic Fighter & Striker parts too.
If anyone happens to be seriously considering brushless power in their Striker, please note:
1. You won't be able to steer
2. If you can't steer, driving in a narrow street is not a good idea
3. The front of a Striker was not designed with high speed contact with a wall in mind
20170910_17213520170910_17214320170910_17215020170910_172301
Ouch. Silly me.
Ouch. Silly me.
Dude!?!?! Now that's some serious crash damage. :o
''Tis but a scratch, come on, battery back in and get out there!
My Sonic Fighter had a crack in the lower chassis just where yours looks to be, not all the way across but nearly... Some JB Weld will get that back together in under 24 hours.
Note taken - no brushless motors in Striker :)
What brushless motor was in that? Did Jason tell you they can handle a 'mild' brushless just fine? That is some serious damage, I doubt my 13.5T would make it go fast enough to do that
 I was told many moons ago that most Tamiya's can handle mild brushless thanks to their wide gears being pretty robust... to be fair this Striker could handle the brushless set up it was the walls fault!
You're gonna have to up that 13.5t then if you're to get on the Speed lists ;p
@Maelstrom are you already fixing the broken chassis?
It was a 12 T motor. Im pretty sure that the Striker would have been fine in a nice open space, with maybe a little weight at the front. As it was, I actually hit the wall at a slight angle with only about a three metre run up from a dead stop. The Tamiya Striker probably can handle mild brushless. It can't handle walls.
Or daft drivers 😐
@Jason1145 unfortunately too  much work at the moment to even think about repairs - I did get round to ordering some JB Weld though.
I was surprised to see that much damage from hitting a wall, the car looks pretty fragile. I doubt my TT02B would suffer that much damage in the same crash, but won't try it out just to see...
Yes @Jason1145 i definitely need to up my game for the speed runs. Then again with my current efforts I could just put my gps in any car and that would be an improvement!
...And there, precisely, is the reason for the Striker's reputation as being fragile. That area of the chassis nose is too narrow and thin, and the bumper provides no protection, and in fact might make it worse.
The one kid with a Striker in my neighborhood growing up went through 3 or 4 chassis before he made a skidplate out of an old "no parking" sign to reinforce it. This also added a ton of weight to the front, which also helps with the understeer a bit.
One of these days I'm going to take a vintage car and drive it like I stole it, and pretend I'm 13 years old and penniless again, and see if I can engineer better freebie fixes than we managed back then. I don't have a Striker, but I do have an FX10... hmm....
Or daft drivers 😐
I used JB Weld on my cracked Sonic Fighter chassis in that same area, I smeared it all over to make a good 2mm covering so hopefully it acts as a reinforcement over the original chassis too.
Then I drilled and mounted the FX10 front bumper in place of the stock one!
Im curious if you can use JB Weld for strengthening a known weak area on a chassis, say around exposed screw holes like on the Thundershot chassis where both front and rear ends bolt on to the chassis.
If you decide against repairing, e.g. if you manage to find a new body set for yourself, I might be interested in taking your broken chassis & body off your hands. Being a fresh break with no repairs attempted makes it an ideal candidate for a Striker related experiment I've been thinking of trying.
Time for a small update:
The damage to the Striker was actually even more grevious than I thought:
20170919_202020
It had obviously been repaired before!
20170919_202012
Got to work with JB Weld.  Have never used this before and I must say that the repaired areas now seem to be pretty stable
20170921_203842
20170928_190336
20170928_19035020170928_190410
Tough to sand down though
Striker Nr. 2 is coming along nicely. Paint job isn't finished yet, but here is a sneek peek:
20170928_185735
And the decals from Canada have arrived!
20170928_185805
Oh I like this build! I will start on mine after my Frog is done. Im going to go hardcore on the F1 theme and throwing out those front arms all together.
OK, this has taken quite a bit since the last update. I wasn't happy initially with the white decals on Striker No. 2 - just not white enough on the blue background - so I sort of lost interest and moved on to other projects. Got round to finishing it now though
20180218_175049
No. 1 and 2 side by side:
20180218_174947
Looks great to me, in fact, seeing all the colour options you can go for with the advent of custom decals, the original Striker in White has zero appeal in comparison... like a missed opportunity!
Calm down before anyone flames me for calling the preceived ugly duckling.. ugly... I love the Striker but just not in white ;)
Saying that, it’s nice to have one in the stable as a comparison, Tamiya heritage and all that.
Your new blue one came out very nice and the Driver figure looks ace,  how many parts went into this whole restoration of the blue Striker?
Edit: I can see what you mean about the white decals not being white enough.. they look fine on the decal sheet but they are too thin and let the blue through once stuck on... I noticed this with some MCI decals too ( red decals on a Black Cosworth shell).
The only way to avoid it is...... not sure actually?!
Thanks for the compliment!
Probably the only way to avoid the darker base colour shining through would be to mask out the area the decals are going to be placed and re-base that in white. Frankly too much effort for me though.
Striker No. 2 was created by mixing the least worn parts I had from my initial shopping binge. No extra costs there!
