Janner 35 Posted September 22, 2017 Hi all, I picked up a nice condition Avante 2001 runner. I took it out for a small test run last night and boy is it slow! I thought it might be the original Sports Tuned motor so I popped a new one in. Could the futaba electrics be the problem or is it the pinion. It is islower than my stock Hopper, thats how slow it is...... Could it also be the grease in the gearboxes? It looks quite thick. Cheers Share this post Link to post Share on other sites
Percymon 2184 Posted September 22, 2017 If its a restriction in the drivetrain then the motor and ESC should get hot pretty quickly, maybe even thermal trip the ESC ? You could test the driveltrain by supporting the chassis and just turning each wheel individually by hand to check each diff, and by turning a pair at a time to check the front to back transmission If its used it could have anythign in the way of grease - ive bought cars with auto gearbox grease in, thick ceramic grease and far worse lol! What pinion is it running ? It's 20T for stock motor Pinion / spur gear interaction - too tight ? Probably not if you've changed motors. How well does the motor spin when out of the car but powered by the ESC (ie in full radio mode but not actually powering the drivetrain ) ? Share this post Link to post Share on other sites
Percymon 2184 Posted September 22, 2017 You can view the manual here (if not available for download on TamiyaUSA site)... https://www.yumpu.com/xx/document/view/51261621/tamiya-avante-2001-manual-wheelsacademyinfo Share this post Link to post Share on other sites
frameskip 63 Posted September 22, 2017 How tight is the pinion ball diff? If this has loosened over time you may be losing power. See step 32 in the manual. Share this post Link to post Share on other sites
Janner 35 Posted September 22, 2017 Thanks @Percymon. Both motor seems to spin up the same out of the car. I did notice one of the wheel hex hubs has worn, so is not powering the front right wheel. I will also look at page 32, so thank you @frameskip. I'll check the pinion when I take it apart for a clean out. I noticed a rogue screw in the from wishbone so I want to get that changed. Other than that it is pretty good. Share this post Link to post Share on other sites
