Egress front carbon shock tower
Pulley
Has anyone got a carbon front shock tower for an egress I could buy?
or know of one for sale?
thanks mark
Thanks, I'm lol liking for the original not the re-re
i may use a new one tho
thankyou for the link
You should probably change the thread title to include vintage/original then, otherwise people wont know what you're after.
2 hours ago, Percymon said:
You could try Fibre-Lyte in the UK too - they will make from CF or GFP in thicknesses of your choice.
Cheers, I believe I used to use them to make carbon and composite fins and frames for our helicopters at Quickuk
thanks for jogging my memory
40 minutes ago, Thommo said:
FYI - I think you'll find 89 Egress shock towers are FRP, not carbon.
Thanks thommo
i think you're confusing it with the avante (frp chassis and towers); the egress had graphite chassis and towers.
On 08/11/2017 at 3:31 PM, Thommo said:
No, no confusion.  Carbon chassis plates and steering bridge and FRP shock towers. 👍🏻
I'm confused >_<
i now remember that my friends and i had upgrades from the start :)
:D
I'm now running the carbon Avante Hop-Up front shock tower on my Egress.  It's the one that came with the re-release Hi-Cap damper set from around 2013.  That's been the best for my set up and with the front damper lower mounts as per 2013 Egress.
I also use the 2013 Egress carbon rear shock mount.  I fitted these for the purpose of preserving my original FRP towers and they've turned out to be a great replacement on the old Eggy !
