tecnica2001 196 Posted November 27, 2017 Here's the start of a long project, I've always been a fan of the Scorcher Beetle body and off course the Blackfoot body, but didn't really want to buy another ORV chassis just to get the body, or separate my Monster Beetle from its body.....so I decide to build a rig for a yet to be purchased Blackfoot body. i wanted to do something different, since I already have a spare Lunchbox transmission, which I deviced a 4 link suspension for...I wante to go 4 link suspension in the front too... Share this post Link to post Share on other sites
tecnica2001 196 Posted November 27, 2017 The front end is made up of a Fox upright, attached to a square aluminum plate, using Traxxas tie rid ends, the cross members are made out off m3 threaded rod and aluminum tubing.... Share this post Link to post Share on other sites
tecnica2001 196 Posted November 27, 2017 The rear end is a Lunchbox tranny with some square angles to ad 4 links to it... Share this post Link to post Share on other sites
Grastens 2795 Posted November 27, 2017 An intriguing project. Will be keeping an eye on this one! Share this post Link to post Share on other sites
tecnica2001 196 Posted November 28, 2017 Mounted a servo, but just a mock up... Added the four links, I'm using M3 threaded rod and Traxxas m3 rod ends.... Since this is a recycling rc bin parts car, I had to improvise.... Share this post Link to post Share on other sites
tecnica2001 196 Posted December 7, 2017 Going in a new direction with the front end, TLT-1 axle housing, without the internals, just the housing..... Share this post Link to post Share on other sites
tecnica2001 196 Posted December 8, 2017 Here's a bit of an update, with this wheel and tire combo, the front track is up to 8.5 and the rear is almost 8.8", I was hoping to stay within the 6.7" width.... i might just make this into a Blackfoot bodied Bigfoot truck.... 1 Share this post Link to post Share on other sites
tecnica2001 196 Posted December 9, 2017 To get to the width that makes me happy, I had to cut down the tilt-1 axle housing, and finagle, a new front axle, thankfully all the holes lined up with the aluminum plates that I had from Lowe's....Now it's 197mm front track, with those 1.9 wheels on, it might narrow up further with smaller wheels and narrower tires, my goal is to ge this to fit under a Blackfoot body.... Share this post Link to post Share on other sites
njmlondon 570 Posted December 14, 2017 Really interesting project. There is a wonderful 4-link Blackfoot on a CR01 chassis somewhere here on TC which I always thought looked amazing. Looking forward to seeing where you go with this. Share this post Link to post Share on other sites
tecnica2001 196 Posted December 24, 2017 A bit of progress: I flipped the lunchbox tranny around and 4 linked it to the chassis, just to get an idea if I need a different frame and shocks....it looks like I'm going to need shorter shocks, maybe 70mm, and a set of 1.55 wheels are on the way... Share this post Link to post Share on other sites
tecnica2001 196 Posted December 24, 2017 Side view of the tranny on 4 link Share this post Link to post Share on other sites
tecnica2001 196 Posted December 25, 2017 With the Blackfoot body on, i need to start working on linking the front end, will definitely have to shorten the rear links to make room for the fronts, as it sits now, my front links would be too short to have any significant articulation.... Share this post Link to post Share on other sites
