Siang20
Kyosho Optima Swing Shaft Compatibility.
Wanna get some info from all Kyosho Fan out there, if any one have the part LA231-02 and UM510-01 in hand may tryout the fitting for me? and will their fit together nicely? as i discover the LA231-02 will fit on Optima nicely with some shim adding. problem the swing shaft of 65.5mm from part LA231-01 are too long, and after confirming the measurement, the part UM510-01 62.5mm swing shaft will fit hence leave me question mark whether this 2 part compatible with each other or not?
