MuntyScruntfundle 1 Posted December 24, 2017 Hi folks. Has anyone come up with a better idea than the steering collar on these models? Part of the problem with the plastic, which when it's been used and or bashed about it stretches so the steering becomes more than woolly! I've printed some replacements which work well, but there isn't a plastic that allows for a bit of stretch without bending after a hard impact. Unfortunately I don't have the ability to print anything at a fine enough pitch to replicate the splines on a servo, I could file a servo down for a flat edge, but that seems like overkill. Any ideas? Many thanks. Share this post Link to post Share on other sites
Prescient 671 Posted December 24, 2017 Do you mean the servo saver that attaches to the servo? Loads of aftermarket upgraded ones including from Tamiya that are brilliant and cheap. Share this post Link to post Share on other sites
TurnipJF 9115 Posted December 24, 2017 A single metal spring from a Tamiya high-torque servo saver placed over the stock plastic C-spring tightens things up nicely. And since you get three springs in a pack, you can improve 3 servo savers for the price of one! Share this post Link to post Share on other sites
Nobbi1977 1793 Posted December 24, 2017 I superglue them. The glue will crack under a hard impact but holds it tight the rest of the time. Not killed a servo yet and my driving is terrible Share this post Link to post Share on other sites
zomboided 374 Posted December 24, 2017 I use a tamiya high torque servo saver for this beast, works lovely. Share this post Link to post Share on other sites
waterbok 1282 Posted December 24, 2017 I use a kimbrough servo Server, high torque metal gear servo and my 3D print servomount you can get at shapeways. 1 Share this post Link to post Share on other sites
Juggular 4914 Posted December 24, 2017 I use zip-ties. I would estimate that one zip-tie can remove about 70-80% of the slop, depending on how tightly you bind it. Two zip-ties would make it give as little as Kimbrough "strong" servo savers do. On the photo, I used one zip-tie for my Bigwig. I am happy with it. 2 1 Share this post Link to post Share on other sites
WillyChang 1812 Posted December 25, 2017 6 hours ago, MuntyScruntfundle said: Has anyone come up with a better idea than the steering collar on these models? Part of the problem with the plastic, which when it's been used and or bashed about it stretches so the steering becomes more than woolly! Check that the 2 nubs the C-spring clamps onto are both EQUALLY same thickness. Any difference at all, you'll get sloppy deadband = wooly steering centreing. I either file down the thicker nub or build up the thinner one... a layer or 3 of superglue does the job. Paint it on both sides of nub until it measures exactly same as the other. Then clamp on the spring and wrap a small ziptie around it. Share this post Link to post Share on other sites
