Steve_i_o 0 Posted January 6, 2018 Afternoon all, For xmas my kids got a Grasshopper kit, its all built but now we are having issue with the receiver/speed controller, i've configured the ESC for a brushed motor but i am unable to get it to connect to the receiver. I've tried binding it but im not getting the red LED (im a complete novice when it comes to this) and now at a loss Many Thanks Steve http:// upload photoes Share this post Link to post Share on other sites
WillyChang 1814 Posted January 6, 2018 Red led on RX not flashing? Try the bind plug in CH3 hole. Although if you've bought a new radio set, they usually come bound ready to go don't need to rebind. Plug the servo into CH1 and see if that responds? Share this post Link to post Share on other sites
Steve_i_o 0 Posted January 6, 2018 no LED when its plugged into any of the ports Share this post Link to post Share on other sites
lentner3 281 Posted January 6, 2018 I would start by connecting the battery servo and motor. I assume you have the battery plugged in and the esc turned on. This supply’s the power to the reciever. Your tx and rx should already be connected out of the box. Share this post Link to post Share on other sites
Steve_i_o 0 Posted January 6, 2018 We had it all built and connected assuming it would be plug and play but nothing, i removed it all from the chassis for diagnosis Share this post Link to post Share on other sites
lentner3 281 Posted January 6, 2018 Sounds like an issue with power getting to your receiver. Make sure the lead from the esc is plugged in to channel 2 and the right way round (white is signal, then positive and negative) Make sure it is fully seated. If you have power to your esc and it is switched on you should get a light on the receiver regardless of it being synced to the transmitter. (I think) The sort of thing that is easy to resolve in person but tricky via message. i would have the servo plugged in as you normally hear it twitch when powered up which confirms power to the RX. Do you have a multimeter handy to check? Share this post Link to post Share on other sites
Steve_i_o 0 Posted January 6, 2018 Lentner, Thanks for the help, however, when all connected up i don't get anything from the servo when power is applied. Annoyingly i dont have a multimeter handy Share this post Link to post Share on other sites
Backlash 481 Posted January 6, 2018 Here are some things to try.... Is your 7.2 volt battery fully charged? Are the batteries in the transmitter / hand control new? Are you turning the hand control on first and the car on second? Have you got the switch on the ESC turned on? Have you tried it in both the on and off positions (maybe the label got switched around?) After you bound the hand control to the receiver, did you remove the bind plug before testing the ESC, receiver and servo? Are you connecting to the blue and yellow wires from the ESC to the green and yellow wires on the motor? Carefully remove the ESC plug from the receiver, and check that you can see all 3 pins in channel 2 on the receiver.. Share this post Link to post Share on other sites
lentner3 281 Posted January 7, 2018 Backlash has given you some sensible things to try. But you really need to know if power is getting to the rx. Can you confirm at least that the esc light is on? Share this post Link to post Share on other sites
Steve_i_o 0 Posted January 12, 2018 Sorry for the delay in responding I have borrowed a multi-meter and the ESC is sending out power, i have a green flashing light on the ESC Is your 7.2 volt battery fully charged? It isAre the batteries in the transmitter / hand control new? Everything is newAre you turning the hand control on first and the car on second? Just tried it this way around and its still the sameHave you got the switch on the ESC turned on? Have you tried it in both the on and off positions (maybe the label got switched around?) it is on, i have a green flashing light (i assume this means its on)After you bound the hand control to the receiver, did you remove the bind plug before testing the ESC, receiver and servo? Have not been able to find out the binding status of the hand control and receiverAre you connecting to the blue and yellow wires from the ESC to the green and yellow wires on the motor? I haven't connected the motor yetCarefully remove the ESC plug from the receiver, and check that you can see all 3 pins in channel 2 on the receiver.. All the pins are all present I am beginning to think its the receiver not working Share this post Link to post Share on other sites
Backlash 481 Posted January 12, 2018 Are you leaving the bind plug in the receiver when you are trying to test everything? All of the 2.4GHz radios that I have, you have to remove the bind plug after you have gone through the binding process.. I turn the power off to the receiver (turn off the ESC, unplug the battery etc) before I remove the bind plug, and then turn the power back on to the receiver once the bind plug has been removed, and test if the binding process worked.. Is this what you are doing? Share this post Link to post Share on other sites
Backlash 481 Posted January 12, 2018 I'm not sure what Flysky radio that you have, but Willy explains the Flysky bind process in post 4 of this thread.. Share this post Link to post Share on other sites
Steve_i_o 0 Posted January 12, 2018 Thanks Backlash, Had a read and i'm not even getting a red light on receiver or any twitching of the servo im going to see if i can get a proven receiver i think Share this post Link to post Share on other sites
WillyChang 1814 Posted January 12, 2018 Yeah could be a dud, best way is to swap in a known-good unit. Use your multimeter to check there's power coming out of its servo lead just to be sure... should be 6V DC between the red & black wires. Also use the continuity tester to make sure the bind plug is conductive between the 2 pins in the plug. Have had some FlySky bind plugs that weren't connected, probably a break in the wire somewhere. I usually don't bother taking new ones out the bag anymore, I just use an old faithful tried&tested bind plug (from Spektrum). Share this post Link to post Share on other sites
Steve_i_o 0 Posted January 12, 2018 6V? ive only got 1V, im not electrically inclined so ive attached a pic Share this post Link to post Share on other sites
Backlash 481 Posted January 12, 2018 Steve, are you measuring between the red and black wires? As Willy said, you should be getting between 5 to 6 Volts DC on your meter.. Share this post Link to post Share on other sites
WillyChang 1814 Posted January 12, 2018 Check the volts across the battery... it should be at least 7.5-8.0V after coming off the charger. You didn't say what charger you're using, it it a slow (over 2hr?) type? BrandNew nimh packs can sometimes go into lazy hibernation & refuse to wakeup, slow charging might not be enough to wake them up. Needs a kick with a fast charger to get every cell awake then 5-10cycles before they're operating normal. Share this post Link to post Share on other sites
Steve_i_o 0 Posted January 13, 2018 Yeah its across the red and black. I've got the standard charger that came with the kit (Slow i assume) just checked the battery and its at 7.8V Share this post Link to post Share on other sites
WillyChang 1814 Posted January 13, 2018 1 hour ago, Steve_i_o said: Yeah its across the red and black. I've got the standard charger that came with the kit (Slow i assume) just checked the battery and its at 7.8V yeah ok your batt is alright, it's not asleep Something suss about the ESC then, assuming you're poking the right pins (or even if you aren't...) there shouldn't be any way if getting 0.99V reading. It'll be either 0V or 6.0V across any combination of those 3 leads to the plug. Try another ESC or find another power source to juice the RX. I keep a 4xAA cradle or external BEC with servoplug around the workbench for testing. Test everything before taping them into car, avoids headaches later. Share this post Link to post Share on other sites
MICHAELs TopForce17 586 Posted January 13, 2018 I would contact the store where you got it and say you want a new esc this one don’t work. Share this post Link to post Share on other sites
TurnipJF 9192 Posted January 13, 2018 Probably best to do that. The TBLE-02 is quite reliable for the most part, but sometimes the BEC goes on them, as appears to have happened with yours. Share this post Link to post Share on other sites
WillyChang 1814 Posted January 13, 2018 If you've bought kit locally then yeah, then yeah hit up customer service. But if you're needing to spend big bucks to return it... I'd check the going rate for this instead:- http://www.hobbywing.com/goods.php?id=358 hobbywing quicrun 1060 Share this post Link to post Share on other sites
Steve_i_o 0 Posted January 20, 2018 Well Fellas, Cant thank you all enough for all the help, it was the ESC at fault, replaced it this morning and it all now works and the kids are now trashing it Many thanks Steve Share this post Link to post Share on other sites
WillyChang 1814 Posted January 20, 2018 2 hours ago, Steve_i_o said: Cant thank you all enough for all the help, it was the ESC at fault, replaced it this morning and it all now works and the kids are now trashing it Rare occurrence but guess you got short straw better luck next kit! Share this post Link to post Share on other sites
