Hello,
Can I fit a HPI Datsun 510 body onto a Tamiya M-07 chassis? Both have 225mm wheelbase. The HPI body is around 165mm wide.
I have the body but I'm not sure if it fit over the mechanicals of the M-07 chassis because the bonnet and boot may be too shallow.
Thanks for your advice.
A Datsun 510 has a pretty squared off front and rear end, they don’t dip or slant downwards so I’d guess it would fit easily.
I’ve got an ABC Hobby Datsun 510 body but it’s a 210mm wheelbase version sat on an ABC Gambado Chassis, but it will easily fit on my M03 if that helps at all?
Good luck with your plan though.
Thank you for your reply. I didn't realise that there was a four door version of the Datsun 510 available.
Would you be so kind as to post a few pictures of your Datsun on it's chassis?
Kind regards, Humayun.
Unfortunately, the M-07 chassis does not suuport the 210mm wheelbase any more.
