Ann3x 220 Posted February 14, 2018 *Updated 5th June 2018 with Super Astute Gearbox For a while now I've been restoring old RCs and kinda got sick of not being able to find certain parts. So, after a little prompting, I decided to learn 3D modeling and start creating my own versions of some hard to find parts. For now, Ive been focusing on Super Astute and Dyna Storm parts but I'll probably cover other models as/when I restore them. Check out my shapeways store "VRC" here. I've test printed and iterated all of these parts (few in pipeline still) and they all fit properly and actually "work". They aren't identical to the original parts but they fit and work fine. Where another part is available (eg the ORBracing DS parts) I'm not going to bother re-making unless I can significantly improve them. For anything else, I'm up for it :). Obviously many of the Super Astute parts are also cross compatible with the Astute, King Cab, Hilux Monster Racer, Mad Cap, Saint Dragon etc. Here are my current offerings: Dyna Storm Parts: Gear Case Cover & Plug: Super Astute Parts: Gear Box Cover: (replaces the dust leaking lexan version) Gear Box Plug (note, fits original lexan case currently, alternative version for VRC case coming shortly) Gear Box Base: Front Battery Holder (stick pack): Front Battery Holder (Lipo pack - note needs low profile servo): Rear Battery Holder: Battery Strap: Battery Pin (also fits DynaStorm): Gearbox (see thread here): 3 Share this post Link to post Share on other sites
Ann3x 220 Posted February 14, 2018 I'm still working on a few parts including: A hardcase Lipo Super Astute front battery holder (will fit cuboid lipos but needs low-profile servo) A new Gearbox plug for the VRC SA Case (currently original plug fits fine but 3d version is too loose on the hard case) Dyna Storm slipper hub (replaces the heavy metal part) Who knows, I have some other more out there plans too! Will post here as/when they come out of prototype. 1 Share this post Link to post Share on other sites
ThunderDragonCy 7777 Posted February 14, 2018 These look great. Given the models reputation for weak transmission, what about a transmission housing that will fit a modern tamiya differential? Share this post Link to post Share on other sites
Ann3x 220 Posted February 14, 2018 1 hour ago, ThunderDragonCy said: These look great. Given the models reputation for weak transmission, what about a transmission housing that will fit a modern tamiya differential? A sealed gear diff is on my list to attempt - the issue is the gears themselves. I'm not sure if 3d printed ones will hold up. If not, then ill have to work out a way to use an existing diff (eg TA-06) with either the either right pitch & tooth count or substitutes for all internal gears and a modded housing to enclose (either way). Either option is complicated but potentially doable. Any ideas, please do suggest. Share this post Link to post Share on other sites
ThunderDragonCy 7777 Posted February 15, 2018 8 hours ago, Ann3x said: A sealed gear diff is on my list to attempt - the issue is the gears themselves. I'm not sure if 3d printed ones will hold up. If not, then ill have to work out a way to use an existing diff (eg TA-06) with either the either right pitch & tooth count or substitutes for all internal gears and a modded housing to enclose (either way). Either option is complicated but potentially doable. Any ideas, please do suggest. I wasn't thinking of modifying the diff itself. I was thinking modified outer transmission casing A parts which would move the shafts to allow the installation of a modern diff complete. No 3d printed gears at all. Totally do away with the Astute diff. Super Astute gears seem to be 0.5 mod so i have no idea what modern drivetrain uses this, but the Astute diff is 0.8 mod. The DT03 diff is also 0.8 mod and has a ball diff option. No idea how the size compares to the astute diff though. Share this post Link to post Share on other sites
Ann3x 220 Posted February 15, 2018 Yeah, that's roughly #2.2 that I listed in my post.... What we'd need to find would be: A modern transmission (likely to stay in production a while with good spares availability) 3 Gear gearbox configuration (so rotation is right direction) Slipper (most of them) Sealed gear diff (most of the higher end ones) Outdrives similar length (~ 55mm) to King Cab (& Astute) that will fit Tamiya bogbones If we can find the above then making a Gearbox housing compatible with all of the Astute lineage should be doable. 1 Share this post Link to post Share on other sites
ThunderDragonCy 7777 Posted February 15, 2018 If you're talking the whole transmission (which is probably wise) something other than tamiya might be the place to look. I looked at sourcing TRF201 internals and they aren't that common and pretty expensive. I have no idea about other brands or race cars with slippers and the like but in the UK Schumacher parts seem to be easy enough to come by. Share this post Link to post Share on other sites
Ann3x 220 Posted February 15, 2018 Yeah, other option is TA-06/M-06 gears. Ill have a think. As i said, its already on my list to look at but is likely a long term project. Share this post Link to post Share on other sites
Tizer 604 Posted February 15, 2018 It would be great to have a gearbox that looks similar from the outside, but actually houses modern gears that are easy to find and also a modern slipper with readily available spurgears. Anything from a Associated B6, Yokomo YZ2 or maybe even old RC10 stuff would work well. Great work so far! Another good step towards getting more Dynastorms out on track. 1 Share this post Link to post Share on other sites
ThunderDragonCy 7777 Posted February 19, 2018 Was just looking at this again at lunchtime (as I missed out on a cheap Madcap last night I've been thinking about these cars again!). The TRF201/211 drivetrain is still relatively cheaply available and is 48dp which is commonly used. It seems it shares quite a lot of parts with the TA06 which you mentioned (diff gear and idler gear). The parts seem fairly readily available and not bad price, so a revised transmission case 3D printed to mount the TRF201 gearset and use the 201 aluminium motor mount would be cool. Share this post Link to post Share on other sites
Ann3x 220 Posted February 19, 2018 I've actually ordered a Schumacher cougar kr to scavenge parts from, nice kit but 2013 vintage so not sure on longevity and part by part it's quite expensive (cheaper to buy the kit and sell extra parts in fact). Will have a play and see. 1 Share this post Link to post Share on other sites
Collin 1952 Posted February 20, 2018 Very nice parts man! Do you plan to construct anything for the TR-15T? Always interestet in aftermarket parts on this model Share this post Link to post Share on other sites
Ann3x 220 Posted February 20, 2018 9 hours ago, Collin said: Very nice parts man! Do you plan to construct anything for the TR-15T? Always interestet in aftermarket parts on this model Anything specific? Many of the orb racing parts are compatible.... Share this post Link to post Share on other sites
Collin 1952 Posted February 20, 2018 Its true, ORB covers a lot and I have all their parts as an upgrade. What I really looking for is a rear bumper. There was a 3rd party hop-up but it seems to be really rare thing. Maybe both front and rear arms? Share this post Link to post Share on other sites
Thommo 1201 Posted February 21, 2018 Aaaah battery trays and the rear gear cover....... you're a genius ! The more 3D parts I see, the more I want to build another Astute Hybrid. Resistance is useless ! Share this post Link to post Share on other sites
Boomerang_kid 18 Posted March 2, 2018 Following this, I am keen on some Super Astute front and rear arms! Share this post Link to post Share on other sites
Ann3x 220 Posted March 2, 2018 8 hours ago, Boomerang_kid said: Following this, I am keen on some Super Astute front and rear arms! I have added to "Ze list". Not sure if I have SA arms to copy from tho.... I definitely have Madcap and Astute, will check. Share this post Link to post Share on other sites
Snappy1 964 Posted March 3, 2018 I am sitting on a mint Super Astute, it has a broken front arm and I refuse to fit the madcap arms I have, do you want to copy Super Astute arms to be printed? 1 1 Share this post Link to post Share on other sites
Ann3x 220 Posted March 3, 2018 6 hours ago, Snappy1 said: I am sitting on a mint Super Astute, it has a broken front arm and I refuse to fit the madcap arms I have, do you want to copy Super Astute arms to be printed? That might be very useful. Let me check my own spares pile 1st but if I don't have, could be ideal. It might mean you don't have the arms for a while btw (can take a few print's to get things right). Anyway 1st things 1st, I'll check my spares. Share this post Link to post Share on other sites
Snappy1 964 Posted March 3, 2018 Time isn't an issue, let me know if you need them. Share this post Link to post Share on other sites
Ann3x 220 Posted March 4, 2018 Ive added today a lipo version of the super astute front tray. It's a few mm longer so that it can accept new style lipo packs (you need to use a low profile servo tho too): 1 Share this post Link to post Share on other sites
Ann3x 220 Posted March 4, 2018 Not sales related but see here for progress on the replacement gearbox. 1 Share this post Link to post Share on other sites
Boomerang_kid 18 Posted March 5, 2018 I have my Super Astute arms I can lend you. Seeing as I'm in the UK, it would cheaper for me to send these to you. I'm not in a hurry for you to do your R&D. Quality takes time, and if it benefits the wider Super/astute/madcap/king cab/monster racer community, I'm all for it. PM me. Share this post Link to post Share on other sites
Ann3x 220 Posted March 5, 2018 2 hours ago, Boomerang_kid said: I have my Super Astute arms I can lend you. Seeing as I'm in the UK, it would cheaper for me to send these to you. I'm not in a hurry for you to do your R&D. Quality takes time, and if it benefits the wider Super/astute/madcap/king cab/monster racer community, I'm all for it. PM me. Thanks for the offers (both of you). I will do arms for sure but will get the gearbox completed 1st. Will work out whose arms I'm borrowing once it gets to top of the queue :). Share this post Link to post Share on other sites
Ann3x 220 Posted March 13, 2018 FYI - The Super Astute Gearbox Plug (A5) is now cross compatible with my replacement hard gearbox cover AND the original/TBG Lexan cover. 2 Share this post Link to post Share on other sites
