Please, could someone explain me how to paint the letters on my Sand Blaster 915 tires? So much input found, but so confused.
Which paint do I have to use?
What is the best way to apply the paint?
Thank you very much.
ernieks
https://www.ebay.co.uk/i/263210963590?chn=ps&adgroupid=48716125379&rlsatarget=pla-382120633635&abcId=1129946&adtype=pla&merchantid=118994546&poi=&googleloc=1007167&device=c&campaignid=974960635&crdt=0
use either a bbq skewer or a tooth pic.decant some of the paint onto a scrap bit of card and dip the sharp end into the paint then apply onto the lettering.
don't worry if it goes over the lines as you can always remove with a blade later
So I need special paint for tires? Would any of the Tamiya paints work too?
Removing incorrect drawing is easy everytime as you mentioned?
ernieks
That or the gelly roll pens, although still takes a little practice so start by using a spare tire :D  I'm finding that the large letters on the SBJ tires are trickier then the narrow one-pass letters on the Smoothies
Gel roll pens make it pretty simple, but can’t get it to last long. One run on some gravel seems to remove a lot of it. What’s everyone use for a good clear coat to protect it?
