Cubee 4 Posted March 3, 2018 Hi there. First post on this forum. Just wanted to show what I have been doing with my recently acquired HotShotII that was in a fairly broken state. The usual cracks around the screw holes and a couple of unexpected ones. I have been working some time now to recreate several Tamiya parts as a 3D design. While I almost never do an exact replica, the parts are drop-in functional replacements. On this car you can for instance see some printed wishbones, and the lower one at the front is an integrated print instead a composition of the original HotShot wishbone with that HotShot2 extension. For anyone who is interested I will be posting my designs on Thingiverse. I only do this after I validated them for fit and function ( not for longevity, that will have to wait ). https://www.thingiverse.com/Qbee/designs 3 1 Share this post Link to post Share on other sites
MadInventor 3888 Posted March 3, 2018 What would spark most interest would probably be a replacement part for the rear shock tower, as these are quite difficult to get hold of. The wishbones are readily available thanks to the recent boomerang re-re 1 Share this post Link to post Share on other sites
WillyChang 1818 Posted March 3, 2018 1 hour ago, Cubee said: I have been working some time now to recreate several Tamiya parts as a 3D design. While I almost never do an exact replica, the parts are drop-in functional replacements. On this car you can for instance see some printed wishbones, and the lower one at the front is an integrated print instead a composition of the original HotShot wishbone with that HotShot2 extension. For anyone who is interested I will be posting my designs on Thingiverse. I only do this after I validated them for fit and function ( not for longevity, that will have to wait ). https://www.thingiverse.com/Qbee/designs Looks great!! Hope you do share the improved front lower arm I'd certainly give it a test. fyi if it helps save you any time, I found some arms by fellow thingymember CORNL here's a link https://www.thingiverse.com/thing:2627499 but weirdly they don't always appear on a thingisearch Share this post Link to post Share on other sites
Cubee 4 Posted March 3, 2018 Thanks for the feedback. @MadInventor Indeed the shock tower is on my radar but I only start modeling once it breaks, and mine seem to be holding up really well @WillyChang That Super Sabre R part was the one swing arm that I had not modeled yet. So many thanks. Share this post Link to post Share on other sites
Running Fox 70 Posted March 3, 2018 9 hours ago, Cubee said: https://www.thingiverse.com/Qbee/designs I see some Fox rear Wishbones there too! Great! Share this post Link to post Share on other sites
gpgp01 36 Posted March 5, 2018 Great design, Thank you! I think these parts should be needed to be some flexible material, also thick a bit than before, but Tamiya didn't the works. Can I ask a question? Should I need a program to mirror the parts for the other side? Share this post Link to post Share on other sites
WillyChang 1818 Posted March 5, 2018 3 minutes ago, gpgp01 said: Should I need a program to mirror the parts for the other side? What are you doing with the file & what's your workflow? i layout STL with Cura and it's got a mirror/duplicate tool that does the job just fine... Cura then does the slicing & outputs as gcode Share this post Link to post Share on other sites
gpgp01 36 Posted March 5, 2018 29 minutes ago, WillyChang said: i layout STL with Cura and it's got a mirror/duplicate tool that does the job just fine... Cura then does the slicing & outputs as gcode I was just thinking the STL files to be printed by Shapeways when I have a chance because I have no 3d printer and didn't know about what softwares should be used for it. Seems I need to learn how to deal with Cura for it. Share this post Link to post Share on other sites
Cubee 4 Posted March 5, 2018 1 hour ago, gpgp01 said: Great design, Thank you! I think these parts should be needed to be some flexible material, also thick a bit than before, but Tamiya didn't the works. Can I ask a question? Should I need a program to mirror the parts for the other side? I printed my parts in black Polymaker PolyPlus. I mainly use black because it looks good and it seems to print better than the other colors. It is also of the correct flexibility I think. Pure generic PLA is not well suited because it is too stiff and brittle. There is also PolyMax but I feel that PolyPlus does a better job in general for my prints. You could also go for ABS. I personally have no experience printing in ABS. For mirroring you can use a ton of tools. A slicer can do it or a program like MeshMixer. Share this post Link to post Share on other sites
gpgp01 36 Posted March 5, 2018 43 minutes ago, Cubee said: I printed my parts in black Polymaker PolyPlus. I mainly use black because it looks good and it seems to print better than the other colors. It is also of the correct flexibility I think. Pure generic PLA is not well suited because it is too stiff and brittle. There is also PolyMax but I feel that PolyPlus does a better job in general for my prints. You could also go for ABS. I personally have no experience printing in ABS. For mirroring you can use a ton of tools. A slicer can do it or a program like MeshMixer. Thanks for your help. I wished I avoid to use tools and 3d printers to make or get some parts I needed. My eyes are not that good to look at screen for a little long time. Maybe I could find out some tools which children can use with relatively easy. Share this post Link to post Share on other sites
paullysstic 0 Posted January 28, 2019 On 3/3/2018 at 6:15 PM, Cubee said: Thanks for the feedback. @MadInventor Indeed the shock tower is on my radar but I only start modeling once it breaks, and mine seem to be holding up really well @WillyChang That Super Sabre R part was the one swing arm that I had not modeled yet. So many thanks. @Cubee Hi, is there any chanche that you realize the rear shock tower model? I'm looking for for someone drawing or even selling an already printed one. Share this post Link to post Share on other sites
