I wondered which parts I would need to convert an onroad TA-02 to offroad specs like the Prerunner or F-150 Stadium.
Any masters of the TA-02 here?
There isn’t really much too it, the bigger wheels and delimited shocks like others have said.
I think all of them where TA01 based so they had the single shock mount front arms, and the dual 5x11 knuckle arms instead of the 10x15 + 6 x 12mm bearing arms which are used on Ta02, Ta03 and cc01.
At least that’s how my f150 is.
Good point. I notice some of the steering bits are broken. I got a TA01 in similar condition. Didn't cost too much to get the blue uprights from the TA02, the TA02 front arms with more shock positions and some CC01 42mm universals from Yeah Racing. Improves the front end quite nicely.
EDIT - IGNORE WRONG THREAD.
Ta01 arms & shocks are shorter than df01 (buggy based on same platform).
If you want a real buggy stance you'd need to replace them (direct swap onto ta01 chassis). But if you just want *something * to run off road as people have said just changing delimiters & wheels will allow that.
