taffer 948 Posted March 20, 2018 the txt-1 came with 2 bodyshells 1 Share this post Link to post Share on other sites
JeffSpicoli 1363 Posted March 20, 2018 anyone know how I can lower my BRAT? softer springs available for the front or rear? Share this post Link to post Share on other sites
Frog Jumper 3662 Posted March 20, 2018 1 hour ago, JeffSpicoli said: anyone know how I can lower my BRAT? softer springs available for the front or rear? Hot Trick used to make a "Frog Lowering Kit" which was essentially two nylon zip-ties. Basically, you compressed your shock springs and held them in place with the zip-ties by looping them through... You can always use a shorter shock than the one that comes with the Frog/Brat. Digging further, the Tamiya #50520 (Monster Beetle rear replacement) can be set for 80mm (for use with BF/MB/Frog/Brat). You could potentially use the Tamiya #50519 and set it to 70mm. This would lower your chassis 10mm (or 0.4 inches). Both of these sets are large in diameter than the original Frog/Brat rear shocks so you'll need to invest in the BF shock towers or something equivalent (CRP #1622). Here is a pix of my Frog with the Tamiya #50520s on the rear with CRP #1622s: https://jpegbay.com/gallery/006638070-.html#1 Tamiya also makes shock spring sets, and many other RC manufacturers offer springs. The #50520 and #50519 come with two sets of springs each, one hard and one soft. You'll just have to experiment with them... Terry Share this post Link to post Share on other sites
Mahjik 197 Posted March 20, 2018 I have no idea what the kit contains, but this did pop up: https://www.hobbybanditusa.com/store/p1261/BOLINK_BL_5280%3A_Tamiya_Frog_Lowering_Kit.html 1 Share this post Link to post Share on other sites
Frog Jumper 3662 Posted March 21, 2018 6 hours ago, Mahjik said: I have no idea what the kit contains, but this did pop up: https://www.hobbybanditusa.com/store/p1261/BOLINK_BL_5280%3A_Tamiya_Frog_Lowering_Kit.html That's an interesting bit of kit! It looks like there are some shocks in there with it... Good find, I've never seen one before! Terry Share this post Link to post Share on other sites
JeffSpicoli 1363 Posted March 21, 2018 18 hours ago, Mahjik said: I have no idea what the kit contains, but this did pop up: https://www.hobbybanditusa.com/store/p1261/BOLINK_BL_5280%3A_Tamiya_Frog_Lowering_Kit.html you're the man! only 1 in stock of course, insane! Share this post Link to post Share on other sites
Slyda 183 Posted October 15, 2018 Just finished one, well 99% finished. 4 Share this post Link to post Share on other sites
jonboy1 2943 Posted October 16, 2018 23 hours ago, Slyda said: Just finished one, well 99% finished. that's beautiful!! 1 Share this post Link to post Share on other sites
jonboy1 2943 Posted October 16, 2018 one i did a little while back: 3 Share this post Link to post Share on other sites
Capucine 53 Posted October 28, 2018 Here is an extra that you can add to the Brat. The Tamiya Toyota Land Cruzer 40 body. Fits nicely on the Brat chassis with no modification except adding an extention to the rear posts. Front single post is long enough and no mod required. Added leds lights on the rear, front and the light bar. Bodies can be switched in a few minutes. Leds lights are running on the # 3 button of my 3 channels Futaba radio. 7 Share this post Link to post Share on other sites
Country Mike 120 Posted October 28, 2018 can you tweak the wheels so the rear is out as far as the front? It bugs me that the front track is wider. Share this post Link to post Share on other sites
Capucine 53 Posted October 28, 2018 Not too sure if it can be done. Maybe using wider wheel hub. I have a whole bunch in stock made of alumunum. Will certainly see if it can be done as long as the shaft is long enough to insert the wheel nut. Share this post Link to post Share on other sites
jonboy1 2943 Posted October 29, 2018 19 hours ago, Country Mike said: can you tweak the wheels so the rear is out as far as the front? It bugs me that the front track is wider. The main issue is that the front has a "deeper dish" than the rear, which I believe is a carry over from the original short arch Ranger. I designed some deep dish rears a while back - if you look at my post up above (the red Brat) you can see them there. Got them here for sale if you're interested: http://shpws.me/O9Qc 2 Share this post Link to post Share on other sites
Country Mike 120 Posted October 30, 2018 Sweet! I'll be adding them to crimbo list. I hate the stance of it. Next up: I saw a japanese guy have an anti roll bar on the rear. Apparently tamiya, it locked the bar to those holes mid arm, clamped to the back of the gear box and went around to the other arm. He also had an adaptor on the front suspension so a damper sat horizontally and acted on both arms. I found it on instagram and awaiting reply to part numbers from him. 1 Share this post Link to post Share on other sites
Frog Jumper 3662 Posted October 31, 2018 17 hours ago, Country Mike said: Sweet! I'll be adding them to crimbo list. I hate the stance of it. Next up: I saw a japanese guy have an anti roll bar on the rear. Apparently tamiya, it locked the bar to those holes mid arm, clamped to the back of the gear box and went around to the other arm. He also had an adaptor on the front suspension so a damper sat horizontally and acted on both arms. I found it on instagram and awaiting reply to part numbers from him. The front shock is probably the Parma #12605: http://vintage.dirt-burners.com/hop-up-index/parma/ It features front arms that have risers that hold a monoshock across the top. The anti-roll bar is likely the Parma #13229: https://www.ebay.com/i/113220182551?chn=ps This piece isn't listed on that Parma page, so I used an ebay link. No affiliation to the seller of that product. Several manufacturers made this. I think one I have on my Frog is a You-G brand. IMO, this piece is a waste of money... Terry Share this post Link to post Share on other sites
Raman36 1656 Posted November 9, 2018 On 10/27/2018 at 7:51 PM, Capucine said: Here is an extra that you can add to the Brat. The Tamiya Toyota Land Cruzer 40 body. Fits nicely on the Brat chassis with no modification except adding an extention to the rear posts. Front single post is long enough and no mod required. Added leds lights on the rear, front and the light bar. Bodies can be switched in a few minutes. Leds lights are running on the # 3 button of my 3 channels Futaba radio. interesting!!! So the brat fits the CR01 then? My first Tamiya was a brat.. I loved the body but hated the chassis.. for this reason I’ve never picked up a re-re. Have always pondered what chassis to put the body on. Share this post Link to post Share on other sites
Capucine 53 Posted November 9, 2018 Fits perfect. Just add some inserts to the rear posts for longer posts because of the high roof of the Toyota. I bought the bodyset including all the decals etc for a cheap price online marketplace. 1 Share this post Link to post Share on other sites
Re-Bugged 10152 Posted August 10, 2019 Just parking this here, if you don't mind 12 Share this post Link to post Share on other sites
berman 5315 Posted November 9, 2019 Mine was the red one, I painted the blue one for a neighbour. Unfortunately I sold it some time ago. Would love another brat! 6 Share this post Link to post Share on other sites
markbt73 5316 Posted November 9, 2019 Heh... funny that this thread should re-surface now... this is a current shot of my workbench: The "The Manhattan Project" Project is back on! 7 Share this post Link to post Share on other sites
cliffw0970 49 Posted January 18, 2020 This is my work in progress Brat basher. Lots more to do including highlighting etc. The paintwork is mat black, with the truck bed remaining gloss. (the pictures are terrible, so hard to see). Ive dropped some transparent Tamiya stars on the bonnet, just playing around really. I need to get some black wheels or paint these, white doesn't look right with black imo. 3 Share this post Link to post Share on other sites
Northern_Ben 27 Posted March 31, 2020 Just to resurrect this thread slightly. Think a brat may be my next project. But a few of the retailers gave stated that the Brat kit isn’t sand/waterproof as standard. What’s needed to make it sand/water resistant? Not wanting to submerge it, just worried about running on wet grass and dirt. is it just a case of getting a waterproof esc/servo? Share this post Link to post Share on other sites
Toolmaker72 507 Posted March 31, 2020 Just having a read 🙂, the issue with deeper dish front wheels. I made a one off spacer to fit on the rear inners and then mounted the deeper dish front wheel moulding to the rear inner. The front wheel inner I made narrower to fit the rear wheel moulding. Unfortunately I sold that model but pictures are below showing them sprayed black and fitted to the model I sold 3 Share this post Link to post Share on other sites
jonboy1 2943 Posted March 31, 2020 On 10/16/2018 at 9:46 AM, jonboy1 said: one i did a little while back: 47 minutes ago, Toolmaker72 said: Just having a read 🙂, the issue with deeper dish front wheels. I made a one off spacer to fit on the rear inners and then mounted the deeper dish front wheel moulding to the rear inner. The front wheel inner I made narrower to fit the rear wheel moulding. Unfortunately I sold that model but pictures are below showing them sprayed black and fitted to the model I sold I went for the easier option and modelled up some from scratch and 3D printed them Share this post Link to post Share on other sites
zakspeed 187 Posted March 31, 2020 Another one of mine just finished 7 Share this post Link to post Share on other sites
