Johan 182 Posted April 8, 2018 My Dancing Rider finally finished, now need to go out and let it rip.. 14 Share this post Link to post Share on other sites
taffer 946 Posted April 8, 2018 Still waiting for mine to arrive......so delayed! Should be here in the next two weeks, did you install any hopups? Bearings etc? Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted April 8, 2018 Great! I too considered the Willy's Wheeler paint scheme for my Dancing Rider, but chose another "Tamiya nostalgia" theme. Still waiting for stickers, but hope to complete it within a couple of weeks. Share this post Link to post Share on other sites
Jason1145 3984 Posted April 8, 2018 Is anyone going to do comedy feet sticking out the bottom on each side? ( they could move in the wind as it goes forward etc) no? Just me? 2 1 Share this post Link to post Share on other sites
svenb 3735 Posted April 8, 2018 1 hour ago, Jason1145 said: Is anyone going to do comedy feet sticking out the bottom on each side? ( they could move in the wind as it goes forward etc) no? Just me? No, me too😉 really tempted to get a couple for me and my son. Share this post Link to post Share on other sites
WillyChang 1812 Posted April 9, 2018 1 hour ago, Jason1145 said: Is anyone going to do comedy feet sticking out the bottom on each side? where would you stick them? they'd need to be pretty high up, probably above the bodypost... to look scale per the full torso figurine Share this post Link to post Share on other sites
bsy2010 218 Posted April 9, 2018 Love mine as well And with a 5500kv brushless, it moves 5 Share this post Link to post Share on other sites
Bromley 681 Posted April 9, 2018 I'd love to see one of these in number 46 "The Doctor" colours. 1 Share this post Link to post Share on other sites
waterbok 1282 Posted April 9, 2018 Doctor Who? Considering going brushless, find it fast enough however if run on a 2S Li-Ion pack. Bit worried about the front suspension when running on rougher surfaces than flat asphalt or concrete. 1 Share this post Link to post Share on other sites
Jason1145 3984 Posted April 9, 2018 13 hours ago, WillyChang said: where would you stick them? they'd need to be pretty high up, probably above the bodypost... to look scale per the full torso figurine You’d hang them out the bottom of the Bodyshell I think they’d look ok. Share this post Link to post Share on other sites
Johan 182 Posted April 9, 2018 oh 7 hours ago, bsy2010 said: Love mine as well And with a 5500kv brushless, it moves Oh.. so my 7300kv is over the top? Share this post Link to post Share on other sites
bsy2010 218 Posted April 10, 2018 18 hours ago, Johan said: oh Oh.. so my 7300kv is over the top? I'll be fast, probably too fast... and, the diff outdrives might not like it too much Share this post Link to post Share on other sites
Shodog 1834 Posted April 10, 2018 Everybody’s Dancing Queen looks cool. I bought one last night when I was at the hobby shop Today I ordered the bearings and battery. Any other hop ups I should build into it from the start? 1 1 Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted April 10, 2018 2 hours ago, Shodog said: Today I ordered the bearings and battery. Any other hop ups I should build into it from the start? I guess it's very unlikely that you ordered the bearing set from JV-E-Shop on eBay? But being one of relatively few sources for T3-01 aftermarket parts so far, I guess there is a slight chance you did. In case you did; I feel obliged to inform that I got my bearing set and a couple of other parts for the T3-01 from them and instead of the required 1060 bearings, I got 1260 bearings. Thankfully, I had enough 1060 bearings already for which I didn't have any purpose, so I could build the model without delay, but it was still annoying. As for other hop-ups, using blue TRF O-rings (# 42137) in the fork for a bit of damping is suggested in the manual. Apart from that, I've done no changes to the chassis. For the body, I got ABS headlight and taillight reflectors and instrument cluster and now I'm waiting for my custom stickers from MCI. By the way, talking about aftermarket parts for the T3-01, the aftermarket body from RCon that was announced some weeks ago, is available. Sooner than I expected! Lola Clear Lexan Pickup Body For Tamiya T3-01 1 Share this post Link to post Share on other sites
nowinaminute 2813 Posted April 10, 2018 On 09/04/2018 at 11:09 AM, waterbok said: Doctor Who? Considering going brushless, find it fast enough however if run on a 2S Li-Ion pack. Bit worried about the front suspension when running on rougher surfaces than flat asphalt or concrete. I don't know how well it works personally but I've seen owners of other vehicles say that using a bit of that super soft packaging foam inside the dampers can give a sort of dampening effect. Not as good as a real oil shock of course but it does work to a degree apparently. Share this post Link to post Share on other sites
waterbok 1282 Posted April 10, 2018 3 hours ago, nowinaminute said: I don't know how well it works personally but I've seen owners of other vehicles say that using a bit of that super soft packaging foam inside the dampers can give a sort of dampening effect. Not as good as a real oil shock of course but it does work to a degree apparently. Mmm that sounds like a good thing to test. I tried the O-ring that didn't make me happy. Share this post Link to post Share on other sites
bsy2010 218 Posted April 11, 2018 14 hours ago, nowinaminute said: I don't know how well it works personally but I've seen owners of other vehicles say that using a bit of that super soft packaging foam inside the dampers can give a sort of dampening effect. Not as good as a real oil shock of course but it does work to a degree apparently. I'll try the foam idea, or drill out the fork a bit to give the o-ring a little more room 16 hours ago, Shodog said: Today I ordered the bearings and battery. Any other hop ups I should build into it from the start? Here is the bearing list: 4* 3x6x2,5 8* 6x10x3 2* 8x12x3,5 I also added the Yeah Racing CVDs, which will give you the ability to run normal 12mm hex adapter to modify the rear width a little 1 Share this post Link to post Share on other sites
WillyChang 1812 Posted April 12, 2018 hmmm... the Force is strong on these... Share this post Link to post Share on other sites
WillyChang 1812 Posted April 12, 2018 On 11 April 2018 at 12:51 AM, Shodog said: Everybody’s Dancing Queen looks cool. I bought one last night when I was at the hobby shop ABBA much, Jim? 1 1 Share this post Link to post Share on other sites
Kenshin 0 Posted February 5, 2022 On 4/9/2018 at 3:59 AM, bsy2010 said: Love mine as well And with a 5500kv brushless, it moves where did you these decals? i have been looking for these quite some time! Share this post Link to post Share on other sites
JennyMo 3522 Posted November 20, 2022 I know this is an older thread, but if anyone [still] has one of these, could you measure the diameter of the front wheel - is a 1.7? Many thanks in advance... Jenny x Share this post Link to post Share on other sites
Willy iine 18803 Posted November 21, 2022 20 hours ago, JennyMo said: I know this is an older thread, but if anyone [still] has one of these, could you measure the diameter of the front wheel - is a 1.7? Many thanks in advance... Jenny x Hi JennyMo! Is it the same wheel as the Dual Rider2? If so I measured the front wheel to about 43mm rim lip to rim lip just now.. Share this post Link to post Share on other sites
JennyMo 3522 Posted November 22, 2022 16 hours ago, Willy iine said: Hi JennyMo! Is it the same wheel as the Dual Rider2? If so I measured the front wheel to about 43mm rim lip to rim lip just now.. Hi Willy - yes, I can't imagine they are any different, being essentially the same chassis - and if its 43mm then that is pretty much a 1.7 as I surmised... interesting, thank you! Jx Share this post Link to post Share on other sites
Willy iine 18803 Posted November 22, 2022 5 hours ago, JennyMo said: Hi Willy - yes, I can't imagine they are any different, being essentially the same chassis - and if its 43mm then that is pretty much a 1.7 as I surmised... interesting, thank you! Jx No problem and good luck with your project! Can’t wait to see what you come up with. 1 Share this post Link to post Share on other sites
SlideWRX 760 Posted November 22, 2022 On 4/9/2018 at 3:59 AM, bsy2010 said: I feel like you need a Noid driving this https://www.figurerealm.com/galleries/avoidthenoid/avoidthenoid.jpg Share this post Link to post Share on other sites
