I have just bought a used M-06 Lowride Pumpkin and I have discovered it has a 19t pinion on the motor, which is obviously wrong. I have checked the other gears and they look undamaged.
I don't really want the standard Tamiya Aluminium pinion gear but want to stay at 16t. Would this RW pinion be suitable ?
https://www.ebay.co.uk/itm/RW-0-6-Mod-Hardened-Steel-Pinions-16-18-20-21-22-24-Tamiya-M-Chassis-M03-M05-M07/142646375426?hash=item213662f402:m:m3Ut6KDSVxolHIIFLwetLrA
If not any suggestions would be appreciated.
Many Thanks for any help.
1 hour ago, WillyChang said:
yes 06mod
Hello mate. Thanks for answering. Sorry for my ignorance, but is the RW pinion all I need to use with the stock gears in the Lowride ?
Yes anything "06mod" = metric = what you want :)
Just double check your manual &/or the car as to which # of teeth you can use... I thought the RWDs (M-0evens) use odds pinion & the FWDs use evens... or is it the other way round... ahh haven't opened any M06 or M05 many yrs.
Definitely AVOID anything "standard/imperial" or noted as "48dp" or even 32/64dp etc, they're not metric.
if ever anyone says "48dp metric"... AVOID THAT LOSER LIKE THE PLAGUE! :angry:
@WillyChang   The manual says 16t, 18t or 20t, so I've ordered a 16t.
Thank you very much for your help and advice once again.
I'm off to watch the Commonwealth games now.
Have a great weekend :D
