So after test driving my Brat one time lightly around the shop - It was great in forward gear - I did notice it sounded slightly odd in reverse - IIRC correctly that loose sound where the gears don’t totally “grab” in reverse is a diff adjustment issue correct?
Thanks!
did you turn the bolt all the way tight then a quarter turn back ..?
Did you check or replace the gears too as the old maybe worn down if old ones still in box ..
 I just built one for my monster beetle and was too loose so it would not drive , but then after I done what the info says it seems fine .....
Brand new kit, but I think what you say is probably the issue, I'll adjust the diff and see what happens.  Thanks!
15 hours ago, tamiya3speed said:
Did you use the Monster Beetle/Blackfoot gears in the trans?  It requires these and not the stock brat gears.
I was wondering about that - which gears should I order?  Thanks!
