Hi all I have had a quick look before posting but can’t find what I want. Are there any hop ups for the dog bones and input and output cups for the street rover ? I’ve seen it sharesparts with a few other models but can get conformation on what actually fits I was looking at dt02 parts but then I read tto2b dogbones or cvd’s work but no mention output cups and axles so I’m getting a little confused and lost on what to purchase. Any links would be greatly apperciated
many thanks
Assuming ita just the stock dt02 gearbox and diff you need the following for a metal driveshaft upgrade
Shafts - Tamiya 9805551
Outdrives - Tamiya 9804237
Hub end cups - Tamiya 50823
This gives you metal dog bones. If you want universals any tt02b/dt02/dt03/df01-2-3 will work and you just need the outdrives for the diff end.
Basically any of the DF/DT-02 or TT-02B systems will work, as long as you are consistent in its application.
TT-02B dogbones will work with the stock Street Rover axles and drive cups, which are the same as the ones used on the TT-02B.
Desert Gator/Sand Viper dogbones will work, but they need Desert Gator/Sand Viper axles and drive cups to go with them.
DF-02 dogbones will work, but you need DF-02 axles and drive cups to go with them. (These look superficially like the stock items, but the cup depth is different to accommodate the longer dogbones.)
