Saito2 6686 Posted May 26, 2018 "You just need the TA06 metal gear diff kit as far as I know. It's what was shipped with the 201XM which uses the same gearbox. I'll look into getting a slipper ASAP then. It's running 4370kV so plenty of poke." So I read this in the "post" thread earlier. Is this true? Will the TA06 gear diff kit 54471 directly drop into my TRF201? I've been looking to swap out my ball diff for awhile. Share this post Link to post Share on other sites
Rb4276 803 Posted May 26, 2018 Yes i used to have the part number but that was over 2 years ago. If im not mistaken it isnt a direct fit but easily done. Go on facebook trf page and ask. That is where ingot the info 1 Share this post Link to post Share on other sites
Rb4276 803 Posted May 26, 2018 The more i think about it i think you needed an on road cars gear case too Share this post Link to post Share on other sites
ThunderDragonCy 7881 Posted May 26, 2018 That was me and apparently I am wrong. It's the mid motor chassis that run the ta06 diff. Saw an interesting thing suggesting that you can do it by replacing the gear case with the FF03 gear case, but couldn't see if anyone had tried it. Ff03 gear cases are 't expensive though so maybe get one and see if it bolts up? Share this post Link to post Share on other sites
Rb4276 803 Posted May 26, 2018 Yup, i knew it was a another gear case and i saw pictures of it done. If I remember the screws bolting to the chassis are the mod but i am not 100% positive because it was 2 years ago 1 Share this post Link to post Share on other sites
frameskip 63 Posted May 27, 2018 I’ve also heard that the FF03 and TRF201 diffs are interchangeable. Just keep in mind that the FF03 requires a special gear case to accomodate the width of the TA06 gear diff: https://www.tamiyausa.com/product/item.php?product-id=54398 1 Share this post Link to post Share on other sites
