Bvtrinh
Project God Of Thunder
Inspired by Nowinaminute and Granndad Stinky on this from this thread here:
Before I knew it, it was all apart.
DF39D57D-6614-4723-A2B9-D4C71F061A49.jpe
I knew I wanted to have a four link suspension in the rear, carbon fiber chassis, and oil filled shocks; however, in order to have more torque to move the bigger wheels, I wanted to use the portal axles from a Traxxas TRX-4.
6835E317-83AA-4DFB-B631-721EE22AC354.jpe187E4710-41FB-437E-AB42-383B36E2CD62.jpe7E0A97E0-C8F3-45F0-9A99-DEF95F84EEEB.jpe
So I started with the fronts.  How was I going to retrofit a CVD driveshaft? Luckily, I had a B44 where I could measure the CVD and it looked like it would fit. The only thing I had to do was enlarge the pin to 2mm on the B44 axle and enlarge the opening on the CVD end. This is what the portal looked like:
A6BECF0D-0A81-4B6A-BA52-FD241C2716D9.jpe
EA4D8863-BCB1-40D3-BCAB-5DA0A46F85AC.jpe
Next, I made the hub carriers from Delrin.
70CD5FF7-AFFC-498E-9D10-38742C6D84A2.jpeEFCDA443-A31B-4B45-B68A-A0FAC35B51D2.jpe
B3F42799-3AE2-4E5B-A174-142C45AD7913.jpe
Looks good but the axles are about 1/4 inch too long! Time to make suspension arms!
As for the tires, I have always been a fan of the Krimson Krusher and wanted similar tires.
93DD8C89-5A26-4EBC-9885-1D21A6CEF040.jpe
Well, that is it for now until the 3/8" Delrin sheets and band saw blade arrives.
Was able to get the front gearbox together and make the suspension arms!
Bearing carriers
6A93E657-C229-435D-8784-BDE7787C1771.jpe
A2C4B611-E2F3-4647-A28E-8097A33812DE.jpe
3A186654-0311-4308-8177-1F2AE3347E4C.jpe
Counter gear from a re-release Tamiya Frog
8C99A330-973D-48A5-8BF6-C4065337C50A.jpe
working on the suspension arms
9EF91A65-BC63-42E0-B79C-29B89AD08FF4.jpe
Done. Not perfect or aesthetically pleasing but it gets the job done!
C084C56E-7CE6-4A81-A523-A99055B1CAB2.jpe
E5DD4AE8-EC7D-4887-AE5E-DA145ACFA0FE.jpe
425AF931-3966-4E9B-AFAD-642B8EFDE510.jpe
87DBBEC7-5DF1-435F-AB38-70FF6E2C495B.jpe
B70E6F41-1CC7-40DF-8CD7-892F720B7E35.jpe
Time to build the shocks.
EC15B6C0-265E-4FA3-8738-20FB26EE84FE.jpe
1F8FA1ED-CD60-42D6-8EC6-3103C3C0D6E7.jpe
Time to focus on the rear.
Funnily enough, I broke a gear on one of my trucks and also discovered the Frog/Brat gears are compatible. Also gives you a few gearing options!
As for the rest of the truck, amazing work!
I may have inspired you but you have inspired me in turn.
I'm particularly interested to see how the 4 link goes because I want to do that to my trucks badly but have been to scared/lacking in knowledge to build up the courage to try it.
In fact, 99% of my Nikko stuff could do with a 4 link conversion...and my Lunchbox etc lol
See, I wouldn't have even thought of making parts like that from scratch. I'd love to make some new arms just to widen the track in conjunction with some longer dog bones. Do you think it would be possible to make something like that with hand tools?
Yes, it is indeed possible. I used a drill press, bandsaw, and a disc sander. I am somewhat dissatisfied with the aesthetics of the arms and plan to redo them after I finish everything.
I have seen some people do a better job with a hand held drill, clamp and hand saw. My hands are not that steady.
Update:
I completed the shock mounts for the front and attached the shocks to see how they fit. It just about bottoms out at the end of the shock travel and now has about two and a half to three inches of suspension travel. A huge improvement over stock and still manages to clear the 540 motor.
89B860EA-C7FE-4DBD-A6B9-9FD95D512C7D.jpe
The next part might be NSFW for fans of Traxxas. In fact, it might be sacrilegious. I cut the rear axles of the TRX-4 to use the ends as adaptors for the portal axles. I also had a pair of 16mmx13mmx20mm delrin inserts made.
186BD196-AC25-4282-9030-4D80234B32C3.jpe
75012A2F-9FD4-4502-8D6C-469F2AD4EF74.jpe
2548AE6D-2794-49A7-A28F-D853E2930D47.jpe
2066BA8F-8D7C-47CF-8C75-2CD529BCE5C0.jpe
2B73829E-D4D9-4C80-8D17-87382F2EC9AB.jpe
0397CEA0-9042-4271-BB0C-962FCB2AD5CE.jpe
I realized the rear track was longer than the front so I was faced with either making the front arms longer and using longer CVD shafts or removing more materials off of the inserts. I ended up doing the latter and adding a little wheel extensions in the front.
BF0EAAB0-7036-4650-9BB0-22F925FEADD5.jpe
76A68AE2-E07E-4E25-BCB9-BFE2DE5AC18E.jpe2E162ECC-97E9-4775-86D1-C2BC4A5335F8.jpe
Much better!
46AEB7E1-B5AA-43B2-A289-AF87BFE5B382.jpe
E138F3D3-E5B9-4BF9-A869-13BB1A206E3A.jpe
And here are the front and rear.
FD383275-E6A6-479A-A6DE-CE29EDEB83A1.jpe
I will work on the mounting points for the four link rear suspension and mock out the chassis in the upcoming week!
Completed the mounting points for the four link suspension. So far, I’m doing a good job of not modifying the Thor to the point of not being able to return it to stock.
I saw a Hot Racing truss for the Axial Yeti which I thought would fit so I started to make the truss/upper link adaptor.
C9E06DBC-3ABF-4820-96C7-ED931E6AD533.jpe
C494BCA8-1DB3-40DB-8D15-FAE738081F7A.jpe
74A68ED3-C4AD-4972-BAAE-C78832F1735C.jpe
7F6159A5-D49D-4A7F-8056-897DA911E562.jpe
The finish is rough right now but I plan on smoothing it out before dying it. Next, I started making the lower link mounting points and it will attach where the original swing arm did. I also don’t like seeing things go to waste so I reused the TRX-4 link mounting point.
00E8CE1A-C990-4243-90E6-CBCE6C2ADA2C.jpe
0D76E465-B63D-4160-AF95-A81961B5862A.jpe
Here’s the modified truss and parts.
8A421BBD-7E9F-40C9-ADBF-EBFC6C014209.jpe
C6A65F32-02AD-4D9A-970D-94D57F7BFA4B.jpe
Time to assembly it to see how it looks like.
D1A3D494-B95B-4AEF-9842-14DFB08A3C25.jpe
C7DAE0EC-B3A1-45B9-9E70-98D18FF6A449.jpe
3273FF3E-8E58-4BBF-9383-6F12AD3D1860.jpe
BD17BB97-5A88-4050-9EF4-655DD703B123.jpe
C7ED0F17-650C-4F13-84C1-50F519FD89F6.jpe
14E05964-F9CF-4677-8F70-6FBE786C6068.jpe
FD1C51E6-37E7-4D0F-9CBD-A08AFD6AEC04.jpe
Dang, that is several steps above hobby grade. I am seriously impressed by your skills and resourcefulness.
Thank you! I do enjoy making things. Perhaps one day I will get a 3D printer so the parts can look more professional...
I'd love to see what you'd come up with using a 3d printer if this is what you do without one!
Started working on the carbon fiber chassis today. Each side is 5mm thick. I covered it with masking tape to not ruin the finish while I work on it.
EAA7972B-00AF-4CEB-AEF7-B935C316A9EE.jpe
Drawing lines and making holes.
C434AFA4-63B2-4942-9B10-E2C8BA802EA3.jpe
9955EF05-3335-423D-BAD5-8EB258B2CF80.jpe
I will buy some thin files tomorrow to smooth out the lines and edges.
I used 8mm carbon fiber rods on the chassis. I found out I just couldn’t tap it. I need to get M3 inserts for a secure hold.
00C6C976-C808-4969-889C-B98A43AEDC30.jpe
E87F63C5-D2E1-4643-A2DD-1F391F821CB8.jpe
7A50AF63-884C-4D5A-8555-78C0FEA6B89E.jpe
Started to assemble it to see how it looks.
9D841BE5-9689-46EA-B544-504694D5007E.jpe
CF9EF845-4BAD-45DC-A444-B68099BC03D3.jpe
C84FE5A2-50EF-4A90-9EF3-8829E46FB585.jpe
544C142A-36AD-429A-BC91-36554ABE9ADF.jpe
2EAC35E8-EB2F-45D1-A9C3-5845F0552FF8.jpe
A4FD80C7-185D-4B10-9FE1-02A8D7AE271E.jpe
0425F2AF-5FC6-4D03-B2A5-B83DE84DCB30.jpe
E268209C-ECA6-421E-9226-70422E1F563B.jpe
F7F29200-0FF0-4161-8790-0C4AFA4011D1.jpe
4C1DCB14-AD3A-4CF5-98F6-E87D4426000E.jpe
5DF73A30-F791-46BE-9560-D98025FF8428.jpe
And here is the Thor posing next to my almost finished CPE Clodbuster.
8EC06900-6572-4B54-847F-861707B7BB63.jpe
5EB3AC64-A824-423D-B7E0-4E352FE4CD31.jpe
574651AE-7489-431D-9ABA-048C2AAA26D9.jpe
Time to disassemble, modify the rear axle shafts to fit the portals, mount the electronics, and more work. I have longer front CVDs coming in so I can make longer front arms and remove the wheel extenders.
Minor update. I was a little overzealous when sanding the carbon fiber a took a little too much off. So I put a layer of Camo cotton fabric on it and put epoxy on. I then put several layers of chalkboard clear.
868324CD-888B-4E21-BDB4-165E2F72C13B.jpe
E07F3B1C-9DFD-4493-BC91-A23F14BE435E.jpe
Thank you! Hopefully I will have time to complete a few other things for the truck this weekend.
Updates:
made new arms using a bandsaw and router this time. Also modified a Hot Racing skid plate for a Axial Yeti.
93274D18-BF1A-40A9-B48E-0C519FF330A3.jpe
0202EA18-5A68-4463-A1F8-690A75C9D760.jpe
9DD4E71A-7340-4F5E-BCB2-2C416108A0FD.jpe
D52D1774-6B37-4722-9CD1-E0C7F8993F63.jpe
435955BB-1F3C-43D2-8116-3EA624184B57.jpe
270D9EA8-5F8D-400C-8651-0072B216882E.jpe
Now I’m working on the steering. I recycled the TRX-4’s steering linkage and modified a Hot Racing carbon fiber one for the Axial Yeti. I still need to adjust it as it is coming in contact with the sway bar.
42DF50F0-B3DD-43D7-AC37-CA0DE1F5300F.jpe
84860252-39D7-4D50-93EB-78293761D112.jpe
83978280-9FE0-4CD7-8717-2C6F302CC5FB.jpe
9BCB5E0B-1AFC-4AE3-8BBE-C6074483B935.jpe
I have not updated in awhile but it doesn’t mean I have not been working on the truck. It is actually near completion. As usual, I thought of making upgrades to the gear boxes and remembered I had sealed gear diffs from a Tamiya TB04 that was meant for a project that never came to fruition. I measured it and it was very similar to the stock diffs.
5C9890B8-2D71-4528-8E72-F7EE01C7A8FD.jpe
I bought a Schumacher 50T delrin spur gear and with a little modification, it fit! I also made the rear drive shafts from a 5mm carbon fiber shaft. Let’s see how the torsional strength is.
FC7293F6-864B-4F39-BFAF-26123BEBBE4E.jpe
82B2FFED-48ED-4168-8C7D-7D7E7424AEF6.jpe
D1AACAC7-389E-4B16-8A04-59609F06160B.jpe
78D9B533-E380-493A-BDA6-72E76EE1240A.jpe
CD7D6835-DF68-4BE8-BD68-2A02CFE6E9CD.jpe
The fronts were a little more difficult because I was using Team Associated CVD axles so I had to use their diff cups: one side from the B44 gear diff and the long side from a B44 ball diff (extremely modified). I shaved the diff plate off the cup, inserted a brass insert to reduce the opening, and made another shaft out of the 5mm carbon fiber. Then I held everything together with a pin that a bearing goes over to hold it in. It is also much more durable than the stock diff cups as they are hardened steel! I had to purchase a special drill bit to drill the hole.
BBCD8CC1-3B1B-4C92-8127-CA42EAD25B15.jpe
7866B6A9-A3F2-4800-AD84-2C47D1B6B699.jpe
And here are the size comparisons:
3AE601B5-3011-4DBB-A948-E85E99994A7E.jpe
51213975-8857-410F-B730-2BFC1F31E912.jpe
A5549B7B-0015-4598-9185-BEE041608B6A.jpe
8F02308B-1DE2-4568-A096-1F2207CD7FAE.jpe
I also used a replacement counter gear for the overdrive Thorp counter gear for a Tamiya Fox. It was a 46t which allowed me to use a bigger pinion. It also fit much better than the Frog counter gear and is stronger.
04C8D931-3DF8-4529-8EDC-E8BE50BACD03.jpe
4602FF9F-AD03-4AE0-98C3-6FB3E8B62670.jpe
And here I am about to put the gear boxes together. What’s the most important thing? Shims, shims and more shims. And gear lube.
81F14295-0F91-4ABB-9305-16B70BB59B79.jpe
6820305F-021B-4904-9336-811C0EBB5971.jpe
4F9B5A31-D1D5-4947-9431-CDC302CF7B10.jpe
My first attempt at dying delrin didn’t go so well. The pieces that turned pink were from a different delrin block.
D376899D-2193-4740-8760-E9D68CABA331.jpe
I bought more Rit dye and was much more successful. I’ll take more pictures tomorrow along with the body I plan on using.
I redyed the delrin parts but this time with more salt and RIT Dye More liquid. I was able to hold the water at boiling temperatures for much longer and that seemed to do the trick. I also used a LiPo 2S battery holder from a Yokomo car. It fits nice and snug in there. I also anodized the aluminum parts bronze and made suspension limiters out of 3/8” Kevlar tape. Lastly, I made 1/4” body posts out of delrin and will use 1/4” rubber grommets on the body to make a secure fit and reduce damage in rollover and crashes. I will show that after the body is painted and finished. Last part is to dye the remaining delrin parts and mount the receiver, esc, and bec.
6807E32C-7CD7-424E-A019-C5E5CBC5955F.jpe
D147C7EC-C3A4-43D1-A8BC-2E82A5CAF8D9.jpe
50A32AC8-D09D-42FC-A807-9400883F562E.jpe
E9FCC918-082F-4634-A25A-3165D4DACA5F.jpe
52F17FCC-4CDB-4293-809A-A8A045845641.jpe
3226E337-F8F7-4E40-8284-427050FCEF07.jpe
In deciding what body to use, I wanted to remain true to the original Thor body. As such, I went with a Tamiya Hilux shell and extended the bed about an inch. This was the first time I used JB plastiweld and it seems to be holding up pretty well through all the sanding.
3C8BFF12-FFCC-4281-9187-2E12CC60EF26.jpe
E55603F6-A3E4-4C89-BFA1-6A625D440BC6.jpe
FA13E4C4-E4E5-41F1-BA29-D663D650EDC2.jpe
A38D88E9-12A5-44DF-B234-DBA463EDFA5D.jpe
1E53B220-5061-4B45-A60A-10256429886F.jpe
10B25230-F0C2-47CA-96CC-864DFAEFB72F.jpe
EDEAD66B-6069-4397-B1AE-B06776A8519A.jpe
A3A68F57-6ACD-46C2-8807-67C58D35845F.jpe
108D2458-035F-4F9C-891B-1B2903A77163.jpe
Amazing, its staring to look like a proper monster!
Would love to see it in action
Blimey not much Nikko left but **** that looks cool! Can't wait to see it in action!
I started to paint and design decals for the shell. This is before I had to start over due to not waiting long enough to apply the clear coat.
97B91FEC-4FFD-408B-9406-90D379EDB7E2.jpe
11608016-9359-4256-A369-7BB280E2A0D5.jpe
B0253739-435E-4C7A-86CB-38DFB64E148F.jpe
F280C5AF-6241-4483-B160-3344098355D9.jpe
F5BC1067-634F-401A-9201-28372114A4F6.jpe
The electronics are in and ready for testing!
5BF5ABBF-83E0-4204-A6A4-FBAFFCB3478C.jpe
EEAFE7D7-C2A3-4CEB-9E06-BCF379FB6718.jpe
9B37DEDA-B4E5-4E04-8BE2-D7DBE80E122F.jpe
Here’s a teaser video my wife made. Unfortunately I snapped both the carbon fiber rods. I guess they were not made for torsional stress. Time to machine the axles from carbon steel and have them heat treated. Enjoy!
Excellent production!
Looks really good in action!
