Just been running my tt01e with its 12t motor in.only around 30 minutes.  Really does fly. However it’s started under braking from top speed to grind or make a crunching noise........ any ideas? Is it the gears? TIA
Posted (edited)
Sounds like your front ring and pinion is wearing allowing it to skip teeth.
At high speed when the brakes are applied hard it stresses those gears hard!!
Edited by ncpantherfan71
typo
I’m going to sound thick but the front ring in the front gearbox? Pinion connected to motor ?
1 minute ago, ncpantherfan71 said:
Yes, ring and pinion in the front gearbox.
Just now, TurnipJF said:
Diff ring and pinion connected to front drive cup which is at the front end of your propshaft.
Ok thanks
Found out what it was. The motor has come loose so tighten up the screws and booooooooooom fixed....
