Blista
Team Associated Green Slime alternative for diff rebuild?
I'm going to rebuild the diffs in my XV01 using the guide provided on thercracer.com
Team Associated Green Slime is recommended to help stop leaks, but it isn't available at any of my usual places.  There's a few other products that seem similar, however I have no idea what the Green Slime is beyond it being referred to as a shock o-ring lube.
There's:
Tuning Haus Shock O-Ring Grease
Team Losi O-Ring Grease
GMade Shock Grease
Arrowmax O-Ring Grease
Sweep Green Grease
Does anyone know which would be a good substitute?  I'm guessing they're all probably similar stuff?
Tbh they're all much of a muchness. Apparently AE green slime is exactly the same stuff as noleen sf3 shock grease which is used as lubricant for motorcycle forks and shock seals. It might be worth having a look for that instead as you can get considerably more than AE supplies for not a lot more cash.
I got SRAM butter - for mountain bike fork bushings, shock seals, etc
Don't know how available it would be in NZ
Cool, I thought that might be the case.  Thanks for the tip.
I'd guess it should be available, although there's always a big markup on things sold here.  I'll check out the bike shop down the road.  Thanks.
My pot of grease was the same cost of two tubes of green slime from a major model sport provider.
Though a tube of slime probably lasts for ages. Doubt I’ll ever get to the bottom of this pot!
