OCD 516 Posted July 15, 2018 I built an M06 up from spares and hop-ups I had on hand. Really it's pretty standard fare and didn't think it was substantive enough to bother documenting. Instead I figure I'll just provide a quick rundown of the ingredients so far: M06 chassis I assembled from mostly leftovers of my previous S15 project 53571 fluorine damper set; Tech Racing blue adjusters, 53876 1mm down retainers, blue trf springs rear/yellow front, two-hole pistons front & rear, #200 oil front/ #400 rear Gear diff with some putty, which is probably too stiff to be driveable, so this may get swapped to a ball diff 54268 aluminum motor mount & DF03 heatsink bar Sport Tuned motor Sway-bar kit I made from spares 54604 body mount extensions, as the front posts I had on hand were already too short for the Beetle body 54361 & 54362 carbon damper stays Tech Racing +7mm wide front axles 54237 low-friction kingpins Bunch of pretty aluminum, titanium, & stainless hardware I'm still swapping around wheel and tire combinations, and have a few tricks up my sleeve for the body trim, which will be the bulk of this thread. I've been trying to narrow down my color choice. Currently I am at: PS-40 pink backed with PS-23 gunmetal PS-40 pink backed with PS-49 blue PS-44 green backed with PS-23 gunmetal I think I have too much paint Input or suggestions? 5 Share this post Link to post Share on other sites
Fabia130vRS 2098 Posted July 15, 2018 I dont know about the color, but I know this body with this rims in the rear, that offset, and the front also, looks amazing hotrod-ish. looking forward for more updates. edit: about the color, if going with pink, would be cool maybe to see some tribal grahics on the side, like this in the picture, and maybe a scale surfboard on top. Or am I goint the wrong direction of this build? otherwise if one colord, I would go with green. Share this post Link to post Share on other sites
_oliK 108 Posted July 15, 2018 Solid green would indeed be cool..but so would be tribal pink. Looking forward for this one! Share this post Link to post Share on other sites
OCD 516 Posted July 15, 2018 11 hours ago, Fabia130vRS said: if going with pink, would be cool maybe to see some tribal grahics on the side, like this in the picture, and maybe a scale surfboard on top. Or am I goint the wrong direction of this build? You've read my mind I do in fact have a surfboard, and and some similar ideas: 1 Share this post Link to post Share on other sites
OCD 516 Posted July 15, 2018 11 hours ago, _oliK said: Solid green would indeed be cool..but so would be tribal pink. Looking forward for this one! I actually contemplated a solid, dark green, but I already have an M01 Mini that color, and I have a strong affinity for metallics. Strong. 2 Share this post Link to post Share on other sites
TurnipJF 10812 Posted July 15, 2018 Tamiya metallic purple looks really good... 1 Share this post Link to post Share on other sites
OCD 516 Posted July 15, 2018 5 minutes ago, TurnipJF said: Tamiya metallic purple looks really good... Remarkably, I don't have that color Although I do think the translucent pink backed with the anodized blue will give me a purple. Gonna do a test sample in a bit. Share this post Link to post Share on other sites
TurnipJF 10812 Posted July 15, 2018 Good luck with the test sample! If it doesn't work, a can of Tamiya PS paint in metallic purple is a good investment if metallic paints are your thing. It looks really rich and deep and sparkly, great in both sunlight and shadows. 1 Share this post Link to post Share on other sites
OCD 516 Posted July 16, 2018 Yeah, I've wrestled with the the fact that I love that purple color but can't justify buying anymore paint until I get through some of my hoard although I'd probably opt for the translucent purple, as the tints give you so many more options for backing. The photo quality isn't really demonstrating the true range of colors I ended up with, but here's both the pink and green backed with both gunmetal and PS-48 blue in the lighter sections: Share this post Link to post Share on other sites
Fabia130vRS 2098 Posted July 16, 2018 In my opinion, both look better backed up with gun metal 1 Share this post Link to post Share on other sites
OCD 516 Posted July 16, 2018 Yep, I think so too. Here's another pic in the sunlight: It's still a bit difficult to capture the full range of colors, but I think this shows how much depth you get from that gunmetal backing. I'm thinking deep magenta 1 Share this post Link to post Share on other sites
_oliK 108 Posted July 16, 2018 But whatever floats your goat! 1 Share this post Link to post Share on other sites
OCD 516 Posted July 16, 2018 4 minutes ago, _oliK said: Gureeen! lol, you're not making this any easier I really wanted to do green, but it just doesn't look dark enough for my liking. I thought maybe I could experiment and see if I could get a darker result, but that magenta is just calling out to me ¯\_(ツ)_/¯ Share this post Link to post Share on other sites
OCD 516 Posted July 17, 2018 Using poster tack putty to mask the running lights: 1 Share this post Link to post Share on other sites
speedy_w_beans 4286 Posted July 17, 2018 Poster-tack for masking? That's fantastic! I wish I would have thought of this or known about this years ago. There were a number of bodies I did where masking with tape was a tremendous hassle. I'm definitely keeping this idea in mind for the future! 1 Share this post Link to post Share on other sites
OCD 516 Posted July 18, 2018 38 minutes ago, speedy_w_beans said: Poster-tack for masking? That's fantastic! I wish I would have thought of this or known about this years ago. There were a number of bodies I did where masking with tape was a tremendous hassle. I'm definitely keeping this idea in mind for the future! I think I learned of this technique on this forum? In any case it's a perfect solution for masking any kind of pocket area that is too narrow to properly tape off; Instead of a half-hour of mediocre masking, I get sharper lines with about 5 minutes of effort. It's also incredibly cheap as I'm still using the same lump I bought nearly a decade ago Share this post Link to post Share on other sites
OCD 516 Posted July 18, 2018 PS-40 coat, no turning back now Grape juice! 4 Share this post Link to post Share on other sites
Fabia130vRS 2098 Posted July 18, 2018 6 hours ago, speedy_w_beans said: Poster-tack for masking? That's fantastic! I wish I would have thought of this or known about this years ago. There were a number of bodies I did where masking with tape was a tremendous hassle. I'm definitely keeping this idea in mind for the future! I also was a tape masking guy, and really was good at it, bu sometimes in thight areas the paint would just run through. but my buddy was into some sick design painting like tribals flames, and this is really a good thing, if doing hard designs, you can paint the hole boddy from inside and then you go layer by layer, paint from the outside on the protection foil with a marker, and from the inside draw lines with a working knife, of course, big planning is needed. http://www.bittydesign.net/en/liquid-mask @OCD, good choice I would say! Going for the one color design? Share this post Link to post Share on other sites
OCD 516 Posted July 19, 2018 O.K. What an epically weird color this turned out to be -- I *really* wanted a nice and dark color and was worried that if I didn't lay down enough of the pink I'd end up with something brighter than I was shooting for. So I went crazy on the pink, more so than I did with the test sample, and then gave it solid backing with the gunmetal. It's a beautiful color in person, but holy moly photographing this color accurately is next to impossible. I ended up taking photos in different lighting, with diffused-sunlight appearing closest to reality, and the studio lighting looking the absolute worst Overall I quite pleased with it, but it won't be easy to photograph. The results: 6 Share this post Link to post Share on other sites
Fabia130vRS 2098 Posted July 19, 2018 Yup, looks on pictures strange. But good! Same with my color ps-16, in no light, black letter stickers are not visible on the pictures, but in real the blue has some, silver metalic pearl inside and is in light a bit silver-ish. So I believe also with this, looks to me when not exposed to light like dark cherry, in the studio like dark orange but i believe its not. 😄 1 Share this post Link to post Share on other sites
_oliK 108 Posted July 24, 2018 Wow, lookd really strange inside but bathed in sunlight...gorgeous. Also, I love the rear wheels, makes for a great cal-looker. If only they weren't that wide. 1 Share this post Link to post Share on other sites
OCD 516 Posted August 1, 2018 Got sidetracked with other projects, but back and ready to get into the details Here's some of what I'm augmenting the original decal set with, starting with this black chrome and matte rubber flex line decals from Wrap-Up Next: I'm using the black chrome rather than bright chrome since this will be alongside some of the original decals that are really a duller silver. The matte black stuff is basically adhesive-backed silicone, and looks exactly like real rubber weather stripping. I was also excited to use these, but noticed that unfortunately none of them are the correct size for this body: The original is about 10mm, while the closest foil versions are 8 & 13mm, so I'm going to do a trial-fitting and see if I can accept the difference in scale. 1 Share this post Link to post Share on other sites
dc-arena 81 Posted August 1, 2018 Ooh I fancy and M-06 and a Beetle would be cool. Is your body from this kit?: https://tamico.de/Tamiya-Volkswagen-Kaefer-M-06-Bausatz-58572 Annnd, how did you make the rear wheels wider like that? It looks cool! Share this post Link to post Share on other sites
OCD 516 Posted August 1, 2018 2 hours ago, dc-arena said: Ooh I fancy and M-06 and a Beetle would be cool. Is your body from this kit?: https://tamico.de/Tamiya-Volkswagen-Kaefer-M-06-Bausatz-58572 Annnd, how did you make the rear wheels wider like that? It looks cool! Yep, that's the body I am using. The M06 is the absolutely *perfect* chassis for the bug -- motor hanging aft of the rear axle, as it should be The rear wheels are a from Surging, which have a slightly wider offset than stock. The tires are vintage Duratrax 1.5" slicks intended for Tamiya three-piece front wheels. Probably unsuitable for any running but I'm into the "fun" look they give to the overall form. Not entirely sure if I'm going to keep them, as the theme is evolving as I progress. I have more options to experiment with after the body details are sorted. Share this post Link to post Share on other sites
