Sign in to follow this
khyzersoze
KhyzerSoze's SMT10 Fleet
Always liked the SMT10 looks.  Just never got around to picking it up... until now.   Decided to pick up 2.  Max-D for me, and Grave Digger for my son.
Ran it box stock and it was..... slooooow... but I already knew that.  Time to build them up!
Specs:
Axial SMT10 Grave Digger:
Parts:
Axial RR10 Bomber Rear Sway bar AX31331 (for use in SMT10 front axle)
GDS Racing 107-145mm Steel Drive Shafts
SSD RC Steel Transmission Gears for SCX10/Wraith/SMT10
STRC CNC Machines Aluminum Reinforcement Lower Link Plate (Green)
Axial Heavy Duty Locker (AX30500)
Aluminum Transmission Case
Aluminum Upper Chassis Links
SSD RC Titanium Steering Links
Xtra Speed Stainless Steel Axle Tubes
Xtra Speed HD Steel Spur Gear 56T/15T
Boom Racing Axial Wraith HD Steel Rear Axle Shafts For AR60 Axle
Boom Racing Axial Yeti Heavy Duty Bevel Helical Gear Set - 38T/13T
JConcepts Tribute Wheels 2.6x3.6 (White)
JConcepts Firestorm Tires (Blue Compound)
Boom Racing 25T Aluminum Servo Horn
Electronics:
Hobbywing Quicrun 10BL60 Brushless unsensored ESC
HobbyStar 4-Pole 3500kv Brushless Waterproof Motor
DS3218MG 20kg Servo
Axial SMT10 Max-D:
Parts:
MIP X-Duty C-Drive Steel Drive Shafts for Axial SMT10 (MIP18190)
Axial Lower Link Plates for Bomber/Yeti/SMT10 (AX31245)
SSD RC Titanium Upper Links
JConcepts Tribute Wheels 2.6x3.6 (Silver)
SSD RC HD D60 Knuckles
Vanquish Products Aluminum Wraith/Yeti Clamping Lockout
Vanquish Products AR60 Axle Servo Mount
Electronics:
DS3218MG 20kg Servo
Grave Digger Upgrade Part 1: Transmission Gears, Transmission housing, Spur Gear, and Motor
Finally got to kick off the upgrade build.  The Grave Digger will be getting the upgrade treatment first, as it's my son's.
First thing that needs to be taken care of are the transmission gears and housing.
SSD HD Gears going in...
New SSD HD Gears in aluminum transmission housing
All put together
Xtra Speed 56T Steel Spur gear going in
Xtra Speed on left, Axial on right
Hobbystar 4-pole 3500kv waterproof brushless going in.
All meshed up (The stock 11T Pinion is pictured.  I actually ended up swapping out to the 15T pinion that came with the Xtra Speed 56T spur gear)
Powerplant/powertrain all mounted up
Using a Hobbywing Quicrun 10BL60 Brushless Esc
Grave Digger Upgrade Part 2: Axles & Drive Shaft
Time to upgrade and strengthen those axles for monster truck status.
Boom Racing HD Diff Gear. Kept it at stock ratio. For now, only going in the rear axle.
Started with the rear axle first.  Old diff setup coming out (on right), new one going in (on left).
Put the Axial locker into the diff housing.  This is only for the rear axle
Another look at old(left) vs new(right)
All greased up and put back into the axle housing.
Time for the axle tubes
With the axle tubes... you'd need modifications to your stock rear axle shaft in order to get them to fit through the tubes.  These Boom Racing HD Axle shaft required no modification whatsoever.  Goes in perfectly.
Some how I missed taking a picture of the axle tube inside the axles for the rear, but here it is all put back together.
Time to get started on the front axles.  Front axle shafts require no modification to fit through the axle tubes.
Getting that axle tube in.  It's a tight fit, and on top of that not all AR60's are exactly the same.  These tubes fit easily on the short side for the most part.  On the long side, I had to bust out the hammer to get them in there.  I had an easier time with the front axle accepting the tube on the long side than the rear.
Here is the axle tube inside the housing
Putting on the lower half of the GDS Racing drive shafts.
Axles all done.
Grave Digger Upgrade Part 3: Suspension & Steering
Time to finish up the bulk of the remaining upgrades.  Mostly suspension and steering related.
DS3218MG 20kg Servo
Got these generic "RCAWD" aluminum upper links from eBay
Old noodle links vs new aluminum links
Rear upper links installed
STRC link plates to strengthen the lower links.
Had an issue where one of their screws just wasn't long enough.. happens to be the only one that is a cap head and not countersunk screw.  Luckily I had some longer ones from my Yeti's stainless steel screw upgrade exercise.
Upper links and Link plates all added...
Front sway bar added
DS3218 20kg Servo mounted up
SSD RC steering links going on...
Using my favorite Boom Racing low profile servo horn.
SSD steering links all mounted up
Two trucks I have been curious about, but never got around to looking into. Very nice.
Also, I recently started using that same servo (2 of them) and really like them so far.
Max-D Upgrade Part 1: Transmission Gears, Transmission housing, Spur Gear, and Motor
Starting the Max-D upgrade.  Very similar to the Grave Digger with a few different parts.
This was a surprise... I've run this truck 2x.. 2!  All on stock 27t brushed motor driving around the driveway.  You think bringing this up to Axial will achieve anything?
Aluminum Transmission Housing
New SSD HD Gears in aluminum transmission housing (wiped away excess grease after taking picture)
Xtra Speed Spur mounted on
All meshed up
HobbyStar 3500kv 4-pole Waterproof Brushless Motor
Max-D Upgrade Part 2 - Axles
Onward to part 2 of the Max-D upgrade.... got the following going in.
Took out the stock rear diff gear setup.
Put that Axial Locker in
Boom Racing HD Helical Gear Set put in
Time for the Xtra Speed Axle Tubes
Axle tubes are in
Boom Racing HD Axle shaft for tubes
Vanquish AR60 Rear lockouts
Rear axle is done
Starting the front axle
Xtra Speed Axle tubes going into the front axle
The tubes are all in
SSD HD60 Knuckles
Knuckles are on
MIP X-Duty C-Drive kit for SMT10
Lower half of the MIP Shafts put on the axles.  Part 2 done.
Max-D Upgrade Part 3 - Suspension, Links, Servo
Getting to the stability upgrades for the Max-D to handle the extra power and weight.
SSD Titanium Upper links
SSD upper links and Yeti lower link plates installed
Top half of the MIP shaft installed and connected in the rear
Vanquish Servo mount went on
Using Axial Bomber Rear Sway bar as a front sway bar on the SMT10
Front sway bar installed
Suspension all mounted up
DS3218 Servo mounted on.  Hopefully it holds up.
SSD Titanium Steering links
Decided to use the stock servo horn instead of the Boom Racing aluminum one.
Front axle MIP shaft connected and all mounted up.
