waterbok 1282 Posted November 29, 2018 DF03 damperset as hopup, well no rerere of the HiCaps Share this post Link to post Share on other sites
dc-arena 81 Posted November 29, 2018 I really, really want one of these. Like the Top Force, I used to obsess over it in the catalogue and Radio Race Car magazine. That white paint and neon stickers screams 90’s too, love it! Share this post Link to post Share on other sites
GTodd 1349 Posted November 30, 2018 Darn it! I was praying it'd have a ball differential. I guess I'll use one of my spare 2013 Egress ones. Share this post Link to post Share on other sites
Thommo 1217 Posted November 30, 2018 Guy's..... Monster gearbox won't accept the gear diff because the Monster gearbox is 06 mod gears (Super Astute gear diff is 05). The entire Super Astute TTC gearbox could however fit into a Monster Racer / King Cab. Super Astute gearbox won't accept the Egress diff for the same reason. Don't sweat it though, that gear diff is sweet ! Sorry 2 2 Share this post Link to post Share on other sites
kontemax 1725 Posted December 3, 2018 On 11/30/2018 at 2:16 AM, GTodd said: Darn it! I was praying it'd have a ball differential. I guess I'll use one of my spare 2013 Egress ones. Doesn't work, different teeth module. Max Share this post Link to post Share on other sites
kontemax 1725 Posted December 3, 2018 Well, I've seen the entire manual and my opinion is that Tamiya lost another occasion with this rerelease of the Super Astute. Except for the TTC, I see always the same issues. Tamiya modified the only part that didn't really needed to be modified, the slippery clutch. I run the Super Astute for a while and the only problem with the TTC were the lack of pinion gears and the difficulties to the fine set up the clutch but anyway the part was good enough. At the end the weak points of the model remains the same. Who needs a 6 mm embossed rear plate if the A1 part still continue to break? Other weak points? - Rear arms mounts - Rear Hubs. - Rear shock tower. - Front bulkhead. - Flexible single sheet FRP chassis plate. No upperplate. - 6 mm ball joint replaced with smaller ones. - No adjustable turnbuckles. - No CVDs. Another issue: 730 brass bearings all around. Weight on suspension in abundance. The gear differential works good. Would I buy anyway this model if I would have the money and if I wouldn't have a Vintage Super Astute new in box? Yes, for sure, cause a Super Astute is always a Super Astute. I hope that Tamiya, or some thirty part brands, will release some hop up for this car. Max 1 1 Share this post Link to post Share on other sites
Kaminagayuchi 41 Posted December 3, 2018 Hi Kontemax, I’m ok with you. Tamiya missed the oportunity to release a perfect Super Astute. The quality of the plastic (I suppose it’s the same) and the lack of improvement make me say me it isn´t a good rerelease. I disappointed by Tamiya. Share this post Link to post Share on other sites
GTodd 1349 Posted December 4, 2018 On 12/2/2018 at 5:29 PM, kontemax said: Well, I've seen the entire manual and my opinion is that Tamiya lost another occasion with this rerelease of the Super Astute. Except for the TTC, I see always the same issues. Tamiya modified the only part that didn't really needed to be modified, the slippery clutch. I run the Super Astute for a while and the only problem with the TTC were the lack of pinion gears and the difficulties to the fine set up the clutch but anyway the part was good enough. At the end the weak points of the model remains the same. Who needs a 6 mm embossed rear plate if the A1 part still continue to break? Other weak points? - Rear arms mounts - Rear Hubs. - Rear shock tower. - Front bulkhead. - Flexible single sheet FRP chassis plate. No upperplate. - 6 mm ball joint replaced with smaller ones. - No adjustable turnbuckles. - No CVDs. Another issue: 730 brass bearings all around. Weight on suspension in abundance. The gear differential works good. Would I buy anyway this model if I would have the money and if I wouldn't have a Vintage Super Astute new in box? Yes, for sure, cause a Super Astute is always a Super Astute. I hope that Tamiya, or some thirty part brands, will release some hop up for this car. Max Valid points BUT. New plastic is new plastic and I bet it's stronger. Other than the rear arm mounts and maybe the front suspension mounts the rest of the parts you listed I never broke and I was a horrible racer. The plastic quality is now worlds better. Yes it stinks having to purchase pergu upgrades and a graphite chassis plate if you want it but that's half the fun! These cars until the EVO TF and Dyna Storm were never about all out performance. It was the enjoyment of the build, the quality of the parts (even if lacking in a few areas) and the beuty of the bodies. I'm stoked and building mine as an Astute, I can not wait!!!! 2 Share this post Link to post Share on other sites
Snappy1 966 Posted December 4, 2018 Well, I just hit the go button, I had pre ordered through RC Jazz, The price...….. $277.24 AUD, far cheaper than I was expecting which is approx. $205 US or 160 quid It should be here in less than 2 weeks, now to pickup some spare front ends for my vintage shelfer and vintage runner 2 Share this post Link to post Share on other sites
Butler 338 Posted December 4, 2018 When will they release the spares for this? Would like a couple of sets of the ribs and spikes for the front of my DT02. Share this post Link to post Share on other sites
ThunderDragonCy 7881 Posted December 4, 2018 3 hours ago, Butler said: When will they release the spares for this? Would like a couple of sets of the ribs and spikes for the front of my DT02. Schumacher re released their rib spike this year so no need to wait. http://www.racing-cars.com/pp/manufacturer/Schumacher/U6847.html Share this post Link to post Share on other sites
dc-arena 81 Posted December 4, 2018 6 hours ago, Snappy1 said: Well, I just hit the go button, I had pre ordered through RC Jazz, The price...….. $277.24 AUD, far cheaper than I was expecting which is approx. $205 US or 160 quid It should be here in less than 2 weeks, now to pickup some spare front ends for my vintage shelfer and vintage runner Wow, that's a great price. I've not used RC Jazz before, will have to check them out! Share this post Link to post Share on other sites
Butler 338 Posted December 4, 2018 2 hours ago, ThunderDragonCy said: Schumacher re released their rib spike this year so no need to wait. http://www.racing-cars.com/pp/manufacturer/Schumacher/U6847.html They don't say Tamiya Super Gripper on the side though. My DT02 is liveried like a Falcon and the tyre lettering is painted too, so they wont cut it. #purist Share this post Link to post Share on other sites
ThunderDragonCy 7881 Posted December 4, 2018 5 hours ago, Butler said: They don't say Tamiya Super Gripper on the side though. My DT02 is liveried like a Falcon and the tyre lettering is painted too, so they wont cut it. #purist Fair enough! Share this post Link to post Share on other sites
Snappy1 966 Posted December 6, 2018 WOW, Super Astute kits have hit E bay, all listings appear to be located in the UK, and all looking for approx twice what I paid out of Hong Kong once 10% GST is added, No front arms yet Share this post Link to post Share on other sites
GTodd 1349 Posted December 6, 2018 I'm going to need that link for RC Jaz please 😀 Share this post Link to post Share on other sites
Mahjik 197 Posted December 6, 2018 https://www.rcjaz.com/ Says there are out of stock though... Share this post Link to post Share on other sites
candyman212 45 Posted December 6, 2018 Just bought mine from the UK, early release was a nice surprise. Anyone see the original one on ebay for £300, thats tempting too! Share this post Link to post Share on other sites
markturbo 136 Posted December 8, 2018 Does anyone know which yellow cva shocks (part number) to buy that would fit this? Share this post Link to post Share on other sites
ThunderDragonCy 7881 Posted December 8, 2018 The Fire Dragon ReRe v and w parts are what you need. 2 sets of 9225025. Share this post Link to post Share on other sites
GTodd 1349 Posted December 8, 2018 Seems like someone else is making a Astute out of the Super Astute too. Good call. The Super Astute decals are a little to 90s for me, the chassis is brilliant though! Share this post Link to post Share on other sites
Thommo 1217 Posted December 10, 2018 I wonder if an Astute body set will be released next year...... a bit like the Avante 2001 body set that came out post Egress 2013. Alternatively, Tamiya may eventually knock out an Astute re-release that is essentially the Super Astute with (Astute box art, stickers, yellow shocks, and the original black light weight wheels and tyres (pin spike front / hybrid spike rear). Retain the Super Astute TTC and lower suspension arms. I'm sure a few of you have thought about this already. Who's willing to bet they take the first option..... Share this post Link to post Share on other sites
waterbok 1282 Posted December 10, 2018 Just been picking parts together at Seidel for gearbox only, already at 140€ and thats only 90% of the parts. Think the Monster chassis will have to wait a little bit longer for an upgrade. Share this post Link to post Share on other sites
candyman212 45 Posted December 10, 2018 Mine has arrived! 8 Share this post Link to post Share on other sites
Grastens 2795 Posted December 10, 2018 Quite glamourous, that one Great to see the presentation is nicer than the usual kit! Share this post Link to post Share on other sites
