Chatweka 0 Posted September 11, 2018 Looking for what Esc to get for my Cascadia truck. I’m using 7.2v 5000mah battery and the standard 540 motor. Even an idea on resonably priced motor and esc combo would be appreciated. Thanks Share this post Link to post Share on other sites
Tamiyabigstuff 830 Posted September 12, 2018 If you are using the standard 540 motor then any low cost ESC should work fine - even something like the old Tamiya TEU-101BK. Consider using the Tamiya Hop-Up motor for the 1/14 trucks - 56526 - again even the basic Tamiya ESC should be fine. If you install the 56511 MFU this has an ESC built in, although not cheap. Share this post Link to post Share on other sites
Chatweka 0 Posted September 12, 2018 Thanks I will be getting a mfc, probably the mfc03, but that’s a while away yet so I’ve ordered a 540 brushless 4370kv with a 45A esc for $45 aud, thought I’d get a combo then they should be matched Share this post Link to post Share on other sites
Tamiyabigstuff 830 Posted September 12, 2018 28 minutes ago, Chatweka said: Thanks I will be getting a mfc, probably the mfc03, but that’s a while away yet so I’ve ordered a 540 brushless 4370kv with a 45A esc for $45 aud, thought I’d get a combo then they should be matched MFC03 is for the European style trucks, MFC01 is for USA style trucks - different engine noise maybe ? Share this post Link to post Share on other sites
