I have a set of CV shocks that I think are for the TL01 chassis (they came with one in the box) with two missing their retainer caps.
I bought a set of 50598 V-parts but the shocks end caps are different to the ones I have.
The 50598 has the screw on link recessed in the end cap (see 1st photo) but mine have them butting up sitting flush (see 2nd photo).
Can anyone advise which part I need?
50598 part 1/2 is recessed inside the end cap (the square bit of the screw on part not visible as recessed)
My CVA shocks have the part 1 from above sitting totally proud of the non recessed endcap.
But that still doesnt address the missing part.
CVA mini shocks arent too expensive. Around £13-19 a set depending where you buy them and will improve handling quiet alot when compared to the standard friction shocks.
18 hours ago, Fabia130vRS said:
Arent CVA dampers with oil? Yours on picture look like normal friction dampers.
17 hours ago, svenb said:
Fabia is correct you have kit standard friction shocks
CVA shocks aren't expensive.
Oh that shows what I know (such a noob!)
13 hours ago, svenb said:
I have the missing parts if wanted
Yes please :wub:
