Weevie 0 Posted October 7, 2018 I am having problems with a TTO2B based Neo Scorcher, with a ETRONIX PULSE EX2 SPORT radio set, in that the aerial clip, when screwed on to the side of the Rx box fouls the central propshaft and also the pre-drilled hole in the chassis base, does not line up with the hole in the Rx box .... Share this post Link to post Share on other sites
BBenny 12 Posted October 7, 2018 I’m sure this is disgraceful, but I just leave the 2.4Ghz aerial loose under the shell, perhaps a little tape to prevent it getting snapped or caught somewhere. Much easier than the 27Mhz whips. 3 Share this post Link to post Share on other sites
Weevie 0 Posted October 7, 2018 43 minutes ago, BBenny said: I’m sure this is disgraceful, but I just leave the 2.4Ghz aerial loose under the shell, perhaps a little tape to prevent it getting snapped or caught somewhere. Much easier than the 27Mhz whips. Will the range not be reduced - or is the external aerial just "for looks" ? And what about the holes not lining up ? Share this post Link to post Share on other sites
Baddon 860 Posted October 7, 2018 By the time range is an issue you will struggle to see the car to control it. 1 Share this post Link to post Share on other sites
Weevie 0 Posted October 7, 2018 5 minutes ago, Baddon said: By the time range is an issue you will struggle to see the car to control it. Thanks Share this post Link to post Share on other sites
Weevie 0 Posted October 7, 2018 OK thanks - I assume that if it does go "out of range" - the power will shut off - to save it disappearing over the horizon ? Also - what is the best (simplest) way of increasing the steering lock ? The steering IS centred - but the lock is very small ! Share this post Link to post Share on other sites
nowinaminute 2815 Posted October 7, 2018 5 hours ago, BBenny said: I’m sure this is disgraceful, but I just leave the 2.4Ghz aerial loose under the shell, perhaps a little tape to prevent it getting snapped or caught somewhere. Much easier than the 27Mhz whips. You mean thats not the proper way!?!?! Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted October 7, 2018 2 hours ago, Weevie said: OK thanks - I assume that if it does go "out of range" - the power will shut off - to save it disappearing over the horizon ? Also - what is the best (simplest) way of increasing the steering lock ? The steering IS centred - but the lock is very small ! Can't. Unless you fitted the mods that drift cars use. The turning circle is fairly useless. Lol Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted October 7, 2018 Or you can alter the end points of the servo to make sure the servo is working within 100% of its steering range Share this post Link to post Share on other sites
TurnipJF 9192 Posted October 7, 2018 It is quite unusual for a standard radio with EPAs set to 100% to struggle to push the steering to the full extent of its lock, however some servos have more travel than others, so possibly if nothing else works you might consider a different servo? Share this post Link to post Share on other sites
