 I got an email about the November releases and they had the TT02RR in it. I followed the link and:
https://www.tamiyausa.com/shop/110-4wd-shaft-drive-road-tt/rc-tt-02rr-chassis-kit/
1. New Adjustable Upper Arms
2. Oil-Filled Gear Differential Units
3. Lower Deck (Hard/Blue) (47339)
4. Alu. Rear Uprights (3.0) (54733)
5. Alu. Propeller Joint (54502)
6. Alu. Propeller Shaft (54501)
7. High Speed Gear Set (68T) (54500)
8. Ball Bearing Set (54476)
9. 5mm Ball Connectors (50875)
10. Metal Drive Shafts & Wheel Axles
11. 5mm Alu. Short Ball Nuts (Blue) (53869)
12. 5mm Alu. Ball Connectors (Blue) (53642)
13. 4mm Anodized Alu. Flange Lock Nuts (Blue) (53159)
14. Medium-Narrow Racing Slicks (51049)
15. CVA Damper & Spring Set
 I wish it also had the 3-degree rear uprights that the R has. Other than that, I think the R has everything but the oil filled diffs.
The R:
https://www.tamiyausa.com/shop/110-4wd-shaft-drive-road-tt/rc-tt-02r-chassis-kit-2/
I think there's little difference over the R version. Tamiya should have at least included the TRF dampers instead of the CVA plastic ones.
Can't say it's of massive interest personally, but I agree the spec is weird not including TRF dampers if there is already the S and R kits out there. Seems like the most obvious way to set it apart from a lesser model and the first thing a racer would change. Carbon towers to improve adjustment and lower cg would also seem like an obvious win for a higher spec chassis.
