Seanster43 222 Posted October 17, 2019 Coming on nicely 1 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted October 17, 2019 Was looking at these ones. Share this post Link to post Share on other sites
ThunderDragonCy 7881 Posted October 17, 2019 They look perfect. Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted October 17, 2019 54 minutes ago, Honza said: Yes, TL01/M-03 upright will be significiantly wider, as they are designed to stick out of rims so small diameter rims can be used. Long span arms have pivot point inside of wheel. How wide is space for uprights in rear arms? If it's 12mm, TA04 uprights won't fit - they are ~16mm wide, if I remember correctly. Maybe TL01LA uprights might be right choice? They appear to have right shape and they also should have some toe-in Or, you can go by way of long CVDs - TRF415 and TB Evo5 with reversible arms used 48mm swing shafts, from what you've said, they should be perfect fit. Wheel axles can be used from TRF414. Good question on the width of them. I don't know without measuring. Interesting what they did with the extra bolt on part on the TA06 Share this post Link to post Share on other sites
svenb 3778 Posted October 17, 2019 These are off a evo III, 2° toe by the looks of it. 1 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted October 17, 2019 2 hours ago, svenb said: These are off a evo III, 2° toe by the looks of it. They look like they may fit. PM inbound. Share this post Link to post Share on other sites
svenb 3778 Posted October 17, 2019 59 minutes ago, TwistedxSlayer said: They look like they may fit. PM inbound. 👍 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted October 26, 2019 Nice parcel arrived with 2degree uprights and a very special limited edition clip from Svenb. Cheers mate. And a parcel from RC Echo which has plenty more 5mm alloy ball mounts and TA04 upper arm adjustable knuckles. This build may slow down even more now.... The Outer Worlds has been released on the Xbox lol. 1 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted October 26, 2019 Well... I got a spare 2 minutes. The rear uprights are 15mm wide. The rear arm is 12mm wide. Safe to say they don't fit. Lol. Share this post Link to post Share on other sites
svenb 3778 Posted October 26, 2019 Doh! Can you trim a bit off the sides? 1 hour ago, TwistedxSlayer said: Well... I got a spare 2 minutes. The rear uprights are 15mm wide. The rear arm is 12mm wide. Safe to say they don't fit. Lol. 1 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted October 26, 2019 17 minutes ago, svenb said: Doh! Can you trim a bit off the sides? Very tempted too and then I’ll pick up some correct ones down the line. Share this post Link to post Share on other sites
svenb 3778 Posted October 26, 2019 Am I right in thinking that the TB01 long arm suspension set is the same as the TB evo? I should know this 🙄 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted October 26, 2019 15 minutes ago, svenb said: Am I right in thinking that the TB01 long arm suspension set is the same as the TB evo? I should know this 🙄 Yes. Share this post Link to post Share on other sites
svenb 3778 Posted October 26, 2019 Are these of any use? From a tb evo iv Share this post Link to post Share on other sites
svenb 3778 Posted October 26, 2019 13mm wide but don't think they have any toe Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted October 26, 2019 17 minutes ago, svenb said: 13mm wide but don't think they have any toe Would need the TA06 top part to turn the mount through 90degrees. Share this post Link to post Share on other sites
Honza 937 Posted November 1, 2019 On 10/26/2019 at 2:31 PM, svenb said: Are these of any use? From a tb evo iv Evo 4 onwards have 2.6mm hinge pin. They won't fit. Share this post Link to post Share on other sites
svenb 3778 Posted November 1, 2019 1 hour ago, Honza said: Evo 4 onwards have 2.6mm hinge pin. They won't fit. Yes and different bearing size, but could drill 2.6 to 3mm Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted November 1, 2019 2.6mm. Who at Tamiya decided that dropping 0.4mm was a good idea?! Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted November 9, 2019 On 10/26/2019 at 12:37 PM, svenb said: Doh! Can you trim a bit off the sides? Tried to trim some off with a Stanley knife, proper hard plastic, give it up a bad idea. Share this post Link to post Share on other sites
svenb 3778 Posted November 9, 2019 1 hour ago, TwistedxSlayer said: Tried to trim some off with a Stanley knife, proper hard plastic, give it up a bad idea. Slotting disc in a angle grinder to sand it down!? A bit extreme but does work. Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted November 10, 2019 14 hours ago, svenb said: Slotting disc in a angle grinder to sand it down!? A bit extreme but does work. Could be an option I guess. Lol. Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted November 30, 2019 Managed to pick up some TL01LA front and rear uprights. They are on their way. 2 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted December 5, 2019 Well... time for an update. Not just yet 😉😉 Here is a sneaky preview picture. 2 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted December 6, 2019 Right, on my iPad now, so a little easier to upload pictures. As per suggestion from @Honza I very luckily found some TL01LA hub carriers, front and rear, yesterday they arrived. So I made a start on the rear suspension and hopefully the 39mm cvds will fit which is the whole reason I’ve spent ages trying to find a solution that works. Rather than using the fixed upper link from the TL01 I’ve opted to use some from the TA04 upper arm set that are adjustable. I decided to to change the front upper extra braces from adjustable to less easily adjustable and used the adjustable threads on the steering linkages instead. 3 Share this post Link to post Share on other sites
