TurnipJF
Turnip restores a Sand Scorcher for Grumpy pants
Did a bit more work on the radio box today. Although structurally sound, there are quite a few places where the surface has been abraded by rubbing against objects unknown, and one spot where it seems to have been clouded by cyanoacrylate fumes or some other similar white substance. I went over these areas with 1000 grit used wet, and have managed to improve the appearance of the worst abrasions quite significantly. I will follow this with Greygate plastic polish. It won't be perfect, but it should end up looking a lot better!
Taking the front end apart has been slow going due to the need for repeated applications of penetrating oil on some of the more stubborn fasteners, but it is apart at last! And with no damage to the parts or fasteners either!
That is apart from the two screws which run inside the ball connectors at either end of one of the front shocks, as seen below:
2018-11-19_12-36-35
They have resisted every effort at extraction so far, and I don't want to resort to brute force as that risks damage to the shock parts themselves. Any ideas?
What penetrating fluid are you using? PlusGas is significantly better than WD40.
The steel parts should respond well to my various anti-rust preparations and the alloy tubes should look fine with a bit of polish, but I'm wondering what to do about the cast metal parts.
2018-11-19_12-28-21
They have been thoroughly cleaned with plenty of hot soapy water and a stiff brush, but the surface finish is far from pristine. In other restorations I have seen people get excellent results from those gadgets which stir the parts for hours on end in a pot of mildly abrasive granules. However I do not have access to such a gadget.
Are there any other ways of achieving a nice surface on these parts without specialised equipment? Or should this simply be classed as patina and ignored for the purposes of this restoration?
So far I have tried WD-40, GT85, TF2 and good old 3-in-1 as well as a tin of stuff I found in the shed simply labelled "penetrating oil". I have also tried mild heat and gentle persuasion.
I haven't come across PlusGas for sale locally, but I will keep an eye out for it.
Another thought is that perhaps it could be that red threadlock that comes with the Scorcher kit. I've struggled a couple of times to remove the screws from the shock end collars because
a little threadlock has got on that part of the threads. The fastener just spins when you turn it but is very reluctant to come out. I just used brute force to push them out in the end, because
I'm not sure what I could have used to soften the threadlock. I didn't have to contend with corrosion as well though.
That is quite possible - it does appear that there is more at play here than just corrosion. I will keep trying alternating hot and cold to weaken its hold, and possibly fashion some sort of jig that will let me push the bolts out without transferring stress to the shocks, as I don't want to press the balls themselves out of the shock ends. One has already worked itself loose on the other front shock, and I had to press it back into place along with its retainer.
Top work TJF, the S.S is going to be amazing when she comes home!
I’ve already made shelf space for her to go on display 😁
With the tarnishing I would suggest you do as much as you want to and at whatever level makes you happy.
And thank you for what you have done so far.
2018-11-19_12-28-21
I’m pretty sure there is a spare one of these you could swap with in the parts I sent to you.
I could be wrong though!
Good tips Fuijo, thank you 👍
I only use the blue thread lock, so it will be a combo of salt water, sand, big jumps and heavy landings that have bound these parts together when it was last used in July on the beach 🙈
There is a spare front axle with the parts you sent over. I will pick the best two and use them for the rebuild.
 Autosol is great on alu, not sure about srb.
You tried toothpaste?. The dishwasher?
Put them inside monster truck tyre, add sand, water and spin at 6,000 rpm.  :)
2018-11-19_12-36-35
Screw a nut on so you don't damage the thread, then whack it with a hammer. It may need supporting with a socket at other side depending if you are extracting the screw or the ball.
If the heating and cooling approaches don't work, it will have to be brute force. Although I'm thinking it may be safer to squeeze it out using a vice rather than whacking it with a hammer. Less chance of collateral damage that way. The nut to protect the threads is an excellent suggestion though - thanks for that!
To sort out the tarnishing on pot metal parts I use a powder product called ‘Bar keepers friend’, it’s meant to be used to clean porcelain and metal fittings (funnily enough). Mix the powder with a little water to make a paste, apply to the metal parts & leave for 5-10 minutes, the use a brass suede brush (meant for shoes) to lightly scrub. I’ve done about 8 SRB’s this way and they’ve all turned out great.
  • Thanks 3
2018-11-19_12-36-35
Have you tried soaking them for a period, or only spraying?
I'd recommend soaking it in a container of diesel for a week and see what happens.
If your happy to sacrifice the bolt, I'd be cutting/grinding off the head and supporting the ball with a socket or something.
Might be better than supporting the shock end to knock it out.
Soak, heat, whack, repeat, might be the only option here.
*Disclaimer* - I haven't performed this kind of work on SRB shocks, so bear no responsibility for damage, loss or personal anguish. :lol:
2018-11-19_12-28-21
That may come off with a soda blaster, but depends if you have access to one or the cost is worthwhile.
Autosol and polishing cloth on a Dremel should work, but would be time consuming I imagine
  • Thanks 2
I spent some time this morning with toothpaste, an old(ish) toothbrush and one of the shock towers:
2018-11-22_01-49-04
Can you tell which one now smells minty fresh? :)
I have also noticed that they're not entirely symmetrical. Is that simply how they are made, or are they from different versions of the SRB chassis? For example could it be that one is an original and the other a re-release? And does it matter?
The stubborn bolts have been soaking completely immersed in various fluids for over a week now.
I will be supporting the ball itself if I am going to resort to brute force, as the ball is retained in the shock end with a pair of slim brass rings that are pressed in place, and I don't want to disturb these.
I don't have access to a soda blaster unfortunately, and I would rather not resort to anything which can't get into the nooks and and crannies, otherwise a shiny surface everywhere accessible will simply make the inaccessible parts stand out all the more.
I reckon I will persevere with the toothbrush and toothpaste approach for now. It won't be quick, but the results should look reasonably good, and I don't see any risk to the parts themselves.
I am glad @Grumpy pants isn't in a hurry to get his model back as this is going to take a while! :)
2018-11-22_01-49-04
Hi TJF,
My daughter broke an upright clattering into a kerb, so one will be ReRe and the other is probably a MK2 upright.
No rush at all as and when she comes home is good with me.
Simon
Good to know. When reassembly time comes, I will put everything back together as symmetrically as possible using the parts available.
On 11/13/2018 at 11:19 AM, TurnipJF said:
The penetrating oil has done it's job, allowing me to separate the chassis into front, middle and rear sections without having to resort to drilling out any fasteners.
2018-11-13_11-15-56
I can see why a replacement chassis was supplied - the original is very warped!
The radio gear has been removed from the radio box, which is soaking in a sink full of soapy water in preparation for a thorough cleaning.
2018-11-13_11-15-43
Morning TJF,
Is the old chassis salvageable or scrap?
All the best
Simon
37 minutes ago, Grumpy pants said:
Morning TJF,
All the best
Simon
It is quite warped, so I wouldn't use it on a runner. I might be able to bend it back to the point that it could serve as a shelfer.
