On the hunt for a complete list of part numbers for all the GPM parts that were sold for the TB01.
I've emailed GPM but they don't have one.
Can anyone else help?
This may not be a complete list but it's a good start...
DTB1019               DELRIN FRONT C-HUB SET - 1PR
DTB1020               DELRIN FRONT BEARING C-HUB WITH BUSHING
DTB1021               DELRIN FRONT KNUCKLE ARM SET - 1PR
DTB1022               DELRIN REAR KNUCKLE ARM SET - 1PR
DTB1048               DELRIN STEERING ASSEMBLY SET
DTB1055               DELRIN FRONT ARM WITH PINS SET - 1PR
DTB1056               DELRIN REAR ARM WITH PINS SET - 1PR
DTB14260T          DELRIN SPUR GEAR WITH PIN SET - 42PITCH (60T)
DTB14261T          DELRIN SPUR GEAR WITH PIN SET - 42PITCH (61T)
DTB14262T          DELRIN SPUR GEAR WITH PIN SET - 42PITCH (62T)
DTB14263T          DELRIN SPUR GEAR WITH PIN SET - 42PITCH (63T)
DTB16488T          DELRIN SPUR GEAR WITH PIN SET - 64PITCH (88T)
DTB16489T          DELRIN SPUR GEAR WITH PIN SET - 64PITCH (89T)
DTB16490T          DELRIN SPUR GEAR WITH PIN SET - 64PITCH (90T)
FTB1050A            FIBRE COMPLETED CHASSIS+MOTOR HEAT SINK SET
GTB1028              GRAPHITE FRONT/REAR DAMPER PLATE (4MM)
GTB1050A           GRAPHITE COMPLETED CHASSIS+MOTOR HEAT SINK SET
TB1004                  ALLOY LIGHT KING PIN - 4PCS SET
TB1004S               STEEL LIGHT KING PIN - 4PCS SET
TB1010                  ALLOY DRIVE ADAPTOR WITH ADAPTOR - 4PCS
TB1018                  ALLOY MOTOR MOUNT WITH EXTRA HEAT SINK FIN
TB1020                  ALLOY FRONT HUB SET (EXCLUDE 5X8 BEARING)
TB1021                  ALLOY FRONT KNUCKLE ARM SET - 1PR
TB1022                  ALLOY REAR KNUCKLE ARM SET - 1PR
TB1025                  ALLOY MAIN SHAFT
TB1025AS            ALLOY/STEEL MAIN SHAFT
TB1025S               STEEL MAIN SHAFT
TB1028                  ALLOY FRONT/REAR DAMPER PLATE
TB1038                  ALLOY 9FIN MOTOR CLAMP HEAT SINK (30MM)
TB1038B               ALLOY 9FIN MOTOR CLAMP HEAT SINK (20MM)
TB1038C               ALLOY 9FIN MOTOR CLAMP HEAT SINK (10MM)
TB1038L                ALLOY MOTOR BOTTOM HEAT SINK
TB1040                  ALLOY GEAR BOX JOINT FOR PINION DIFFERENTIAL
TB1040S               STEEL GEAR BOX JOINT FOR PINION DIFFERENTIAL
TB1048                  ALLOY STEERING ASSEMBLY SET+GRAPHITE PLATE (5X8B)
TB1050                  ALLOY CENTRE SHAFT HOUSING
TB1055                  ALLOY FRONT ARM WITH PINS SET - 1PR
TB1056                  ALLOY REAR ARM WITH PINS SET - 1PR
TB1160                  COMPLETED TIE ROD+BALL JOINT - 3PRS SET
TB1200                  URETHANE FRONT/REAR FOAM BUMPER SET WITH POSTS
TB1238A               ALLOY FRONT/REAR UNIVERSAL SWING SHAFT - 1PR
TB1238AC            ALLOY FRONT/REAR UNIVERSAL SWING SHAFT (CVD) - 1PR
TB1238S               STEEL FRONT/REAR UNIVERSAL SWING SHAFT - 1PR
TB1238SA            ALLOY/STEEL FRONT/REAR UNIVERSAL SWING SHAFT - 1PR
TB1238SAC          ALLOY/STEEL FRONT/REAR UNIVERSAL SWING SHAFT (CVD) - 1PR
TB1238SC             STEEL FRONT/REAR UNIVERSAL SWING SHAFT (CVD) - 1PR
TB1310                  ALLOY/STEEL FRONT ANTI ROLL BAR SET
TB1311                  ALLOY/STELL REAR ANTI ROLL BAR SET
Hope that helps.
Cheers,
James
1 hour ago, Fusion-Hobbies said:
Hi,
Sorry, we don't have any of the GPM TB-01 parts.
Cheers,
James
Was worth asking. No worries. The list is a great help.
I do have a list, no parts though...
TG1004                 ALLOY LIGHT KING PIN-4PCS SET
TG1004S               STEEL KING PIN-4PCS SET
TG100A                 ALLOY LIGHT FLY WHEEL FOR 1 SPEED
TG100T                 ALLOY LIGHT FLY WHEEL FOR 2 SPEED
TG1010                 ALLOY DRIVE ADAPTOR (4PCS SET)WITH PIN
TG1014                 ALLOY SUB-CHASSIS 3MM THICK
TG1015T               ALLOY CLUTCH GEAR-15T
TG1016                 ALLOY MAIN CHASSIS 3MM THICK
TG1016T               STEEL CLTCH GEAR-16T
TG1016V              ALLOY MAIN CHASSIS EXTRA THICK
TGX1017T            STEEL CLUTCH GEAR-17T
TG1020                 ALLOY FRONT HUB SET (EXCL 5x8MM BEARING)
TG1021                 ALLOY FRONT KNUCKLE ARM SET-1PR
TG1022                 ALLOY REAR KNUCKLE ARM SET-1PR
TG1025                 STEEL MAIN PROPELLER SHAFT
TG1039C              CARBON BRAKE DISK
TG1040                 ALLOY GEAR BOX JOINT FRONT PINION DIFF.
TG1040S               STEEL GEAR BOX JOINT FOR PINION DIFF.
TG1041M             FIBRE BRAKE PAD WITH SPRING-1PR
TG1048                 ALLOY STEERING ***.SET+GRAPHITE PLATE(EXCL 5x8B)
TG1050                 ALLOY CENTRE SHAFT HOUSING
TG1051                 ALLOT ATTACHING MAIN GEAR HOUSING
TG1055                 ALLOY FRONT ARM SET-1PR
TG1056                 ALLOY REAR ARM -1PR
TG1080                 ALLOY ENGINE MOUNT WITH HEATSINK
TG1160                 COMPLETED TIE ROD+BALL JOINT-4PRS SET
TG1200                 URETHANE FRONT/REAR BUMPER SET WITH POSTS
TG1201                 PLASTIC FRONT/REAR BODY POST+CLIPS+SCREWS-1PR SET
TG1238SF            STEEL FRONT UNIVERSAL SWING SHAFT-1PR
TG1238SR            STEEL REAR UNIVERSAL SWING SHAFT-1PR
TG1300                 MAINFOLD FOR 12-15 CLASS ENGINE
TG1308                 MUFFLER FOR 12-15 CLASS JANPAN/EUR. ENGINE
TG1308PM          MUFFLER & MAINFOLD SET FRONT 10-15 CLASS ENGINE
TG1310                 ALLOY/STEEL FRONT ANTI ROLL BAR SET
TG1311                 ALLOY/STEEL REAR ANTI ROLL BAR SET
TG1330                 NYLON FRONT/REAR BUMPER
TG1808                 ALLOY ENGINE HEATSINK FOR ORI ENGINE-8FINS
TG1812                 ALLOY ENGINE HEATSINK FOR ORI ENGINE-12FINS
TG1818                 ALLOY FLAT ENGINE HEATSINK
DTG1020              DERLIN FRONT BEARING C-HUB WITH BUSHING SET
DTG1021              DERLIN FRONT KNUCKLE ARM SET-1PR
DTG1022              DERLIN REAR KNUCKLE ARM SET-1PR
DTG1048              DERLIN STEERING ASSEMBLY SET
DTG1055              DERLIN FRONT ARM SET-1PR
DTG1056              DERLIN REAR ARM SET-1PR
DTG1150T            DERLIN 1 SPEED MAIN GEAR
DTG1180              DERLIN 2 SPEED GEAR SET-2PCS
DTG1180T            DERLIN STEEL 2 SPEED GEAR SET
DTG4015              DERLIN CLUTCH 2 SHOE-1PR
GTG1014              GRAPHITE UPPER DECK+MOUNT ANTENNA SET
GTG1016              GEAPHITE MAIN CHASSIS 3MM THICK
GTG1029              GRAPHITE FRONT/REAR LOCK PLATE FOR DAMPER
Cheers,
James
