Hey guys,
I have upgraded my Mud Blaster 2 (WT-01) with the taller shock towers from GPM and some 103mm shocks. Due to the length of the shocks the axles (stock dogbones or GPM CVDs, doesn´t matter) do pop out often.
I was using shorter shocks before but didn´t like the stance and handling.
So is anybody out there who has a similar setup and knows some slightly longer dogbones or CVDs?
Thanks.
12 hours ago, Albert Attaboy said:
A new gearbox is already on its way to me, can´t wait to replace it!
Approx. 25 € plus shipping.
Are you stripping it and swapping the races over?
I find they have a little to much grease in as standard
Posted (edited)
On 11/27/2018 at 6:16 PM, wolfdogstinkus said:
You done well to break it there,..
I bet it was that stump I didn´t see because it was literally invisible.
:ph34r:
Yes, I am only going to use the gearbox shell.
EDIT: ****, I have discovered further damage. Now I have to also replace both chassis which means I have to take the car fully apart. What a bummer...
I am contemplating reinforcing the chassis the same way as the body by using glass fiber tape and Shoe Goo. At least in some crucial spots to keep the added weight low.
Edited by Albert Attaboy
Further damage discovered
