delche 18 Posted December 3, 2018 (edited) I decided that it was time to finally create a spray booth so that I could keep painting through the winter. I’m about 90% done with my first attempt but I think it will make a good prototype. The structure is corrugated plastic panels that I bought at Home Depot. It’s held together with plastic L brackets that are glued to their respective panels. Masking tape holds the panels to eachother so that i can remove and dissemble the booth when not in use. For ventilation I’m using a 220 cfm bilge blower and dryer ducting that will vent outside. I picked a bilge blower since it’s rated to operate in explosive environments. Finally, a battery powered led under cabinet light provides illumination . I’ll post final pics but I hope this helps give others ideas so that they can keep painting while it’s cold out. Edited December 3, 2018 by delche Typo 11 2 Share this post Link to post Share on other sites
speedy_w_beans 4272 Posted December 3, 2018 Great idea! I have the same struggles painting in the winter. Share this post Link to post Share on other sites
Lee76 638 Posted December 3, 2018 That looks great, I think I need an upgrade... Here’s a picture of mine, I made it from preformed corrugated cardboard. Currently I’m holding my breath when I spray and then for extraction I open the window and leave the room for a while... As you can see it’s important to keep a tidy work area... 1 8 Share this post Link to post Share on other sites
Lee76 638 Posted December 3, 2018 Can I ask where you got the plastic boards? Is it model making stock or something from a diy store? Also, have you heard any Horror stories of paint booth explosions? I didn’t think the solvent and overspray would be in high enough concentrations to ignite. I have a spare bathroom extractor I was thinking of using, now I’m having second thoughts.. I have a retired spray painter in the family so might ask him for any industry stories... Share this post Link to post Share on other sites
delche 18 Posted December 3, 2018 I purchased the plastic panels from Home Depot. They came in 4x8 sheets and I used two of them for the build. Honestly, I think a bathroom extractor will work just fine if you have it. Adding a cheap furnace filter in front of it will help keep the nasty bits from getting through. Thankfully my bilge fan only cost $30 on Amazon because I didn’t have anything else around the house. 1 Share this post Link to post Share on other sites
Lee76 638 Posted December 3, 2018 Ah, thanks. I see what it is now, correx, I’ve only seen black sheets locally though. I’m thinking if its taped along the right edges it will fold up flat. This might just be my next DIY project. Share this post Link to post Share on other sites
78Triumph 2610 Posted December 3, 2018 Really nice setup! I may have to copy that for this winter! Share this post Link to post Share on other sites
Baddon 860 Posted December 3, 2018 I set one up in the kitchen under the extractor hob. Warm and decent ventilation as well. I have a very easy going good lady....lol 1 Share this post Link to post Share on other sites
Juggular 4964 Posted December 4, 2018 I should think AC brushless motors should be fine. We all know how the brushes create sparks like crazy in a brushed motor. Mix that with the volatile fume, "Huston, we've got an ignition." Even if somebody uses a 540-powered brushed motor for the extractor, I think it would be an alarming puff in the duct at worst. Far less than a fire breather's alcohol fire... A fire breather would spray 300ml of alcohol in 0.5 second. Tamiya spray cans would spray the same amount in 5 minutes... Just as Lee76 said... not concentrated enough. (don't try any of these at home, kids) I meant to ask... @delche, that tiny 3cm fan isn't the 220cfm blower, is it? 1 Share this post Link to post Share on other sites
speedy_w_beans 4272 Posted December 4, 2018 I also meant to ask if your work space heated. If you have heat and good ventilation, then the low humidity in winter is ideal for painting. Translucent colors like window tint will cure very clearly, whereas they can get a little cloudy in the summer in high humidity. Share this post Link to post Share on other sites
delche 18 Posted December 4, 2018 @JuggularThe fan is 4 inches and is rated at 220. It looks super tiny but pushes a ton of air out the back https://www.amazon.com/gp/aw/d/B00D96LYSY?psc=1&ref=yo_pop_mb_pd_title @speedy_w_beansThe space is thankfully heated and is my office/workshop my rear ducting is metal and my friend suggested I should ground it due to static buildup. Anyone else think static/spark will be an issue? 1 Share this post Link to post Share on other sites
Juggular 4964 Posted December 4, 2018 Such a small fan doing 220 is impressive. It says 12v. Do you need a 12v power supply? Share this post Link to post Share on other sites
delche 18 Posted December 4, 2018 I’m using a power supply from an old battery charger. It works for right now but I’m sure I’ll have to replace it eventually. 1 Share this post Link to post Share on other sites
Scipunk 383 Posted January 17, 2019 I tend to use old PSU's from PC's as a 12v supply, relatively cheap can be made to run without a PC and are larger with better cooling also i have a ton of PC fans laying around...lol Gonna grab these sheets tomorrow and build myself one, thanks for the info! Share this post Link to post Share on other sites
delche 18 Posted March 29, 2019 It’s been awhile since my first post but I’ve finally had time to try my booth. I’m starting an SRB build and the booth did really well as I applied primer to the scorcher shell. I was lazy and didn’t vent the exhaust through a window but plan to do so tomorrow when I do more painting. Even so I could tell that the boat bilge fan was doing a good job drawing fumes away from the body The funny thing is that I just moved to a larger home so this booth will probably end up being the prototype for a wooden booth. 2 Share this post Link to post Share on other sites
Tobiwahnknobi 10 Posted August 7, 2019 This is my Spraybooth , cost me round about 30€ 9 Share this post Link to post Share on other sites
delche 18 Posted August 7, 2019 That looks incredible! Share this post Link to post Share on other sites
FoxShot 280 Posted January 2, 2020 ****. These booths look the muts nuts. Excellent idea. Going to make myself a quick one. I dont 'intend' to do any more builds after the Bruiser. However, Tamiya is worse than Crack, and I am enjoying the modelmaking aspect as I used to do lots of static models as a kid Share this post Link to post Share on other sites
Wetman 417 Posted November 27, 2020 On 12/3/2018 at 7:09 AM, Lee76 said: That looks great, I think I need an upgrade... Here’s a picture of mine, I made it from preformed corrugated cardboard. Currently I’m holding my breath when I spray and then for extraction I open the window and leave the room for a while... As you can see it’s important to keep a tidy work area... Preformed corrugated carboard!! Share this post Link to post Share on other sites
