Flat-spotting the tyres from longterm standing is one thing
(easily cured by axle & model stands) but what about the
whole suspension?
The Pajero MTW is looking more and more saggy at the tail
due to the big long trailing-arm girders bending with the
weight on it.
Nose sits a lot lower than the front! & it looks wierd. [V]
How does one avoid it?
can't flip the girders upsidedown as they are directional,
so can't let them bend back on themselves.
Use plastic zip ties in a cross or X formation by tieing the trailing-arm end with the axle. Is not pretty but it works and if you use black plastic zip ties it will be less noticable.
The zip tie forces the trailing-arm back into a curve which would raise the chasis and body.
  • 3 months later...
