Jason1145 3986 Posted December 28, 2018 It's only a simple TT01E chassis and yet I was still not entirely prepared with a bearing kit, so I atleast got it out the box and took some photo's and went off to order some more bits before I start it properly. I did find some Yeah Racing universals for it and some 53619 Oil Shocks previously made up waiting for a new project. (Ignore the blue motor mount in the photo it doesn't belong there) There is an 8 page manual for the Bodyset and it would require 5 cans of paint if done Box art.... not sure I will follow this... it will be the most complicated bodyset so far for me. A nice exploded view of the TT01E All laid out New tyres - 70mm diameter These two bits will be replaced Front and rear wheels with tyres not glued yet That's all for now, more to follow time permitting 5 Share this post Link to post Share on other sites
Jason1145 3986 Posted December 29, 2018 I'm making a concerted effort to progress this build and not dwell, I dug out some spare rubber sealed 1150 bearings I knew I had hidden and marched on to the first page. Looks easy enough, and it was Step 2 was easier Step 3 made me choose a motor and pinion. A Superstock BZ motor with Hardened 20t pinion, one tooth up on the stock alumnium 19t pinion supplied with the kit. This should scoot along a bit quicker than stock with a silver can - which I'm sure would be ta touch pedestrian? An Mtroniks 20t ESC will speak to it even underwater. The plastic motor mount will do for now, I can always upgrade to a metal one later if desired. I follow that red line..... Like that! Next to install the motor and the top cover Now at Step 5 it's time to make the rear diff, I made the front at the same time as they are identical. Steps 6 and 7 are installing the rear diff and the rear arms... here you can shoose to make it a shorter 251mm wheelbase of 257mm, I left it at 257mm as the bodies I have are all around this length. NOTE to self - come back and change these two brass thingies for 1280 bearings when they arrive After a little faffing about the rear arms are in pace and secured with the 3 screws on the rear diff cover . At this point I found the upper rear arms wobbly due to that A5 part not being secured yet (this is done later in Step 25 when part D1 is secured - this is the top shaft cover that runs from the front diff and along the prop shaft and then secures on to the top of the rear diff.) It took me a little while to figure that out as I was wondering when the two holes circled in red would be secured... but it's ok as it's not gong to fall out as they are sandwiched in for now I have reached Step 9 which attached the rear bumper and had to stop here... so far I'm another hour into the build and my little one woke up to stop play 7 Share this post Link to post Share on other sites
TwistedxSlayer 1290 Posted December 29, 2018 Another thread for me to follow 1 Share this post Link to post Share on other sites
Juls1 1661 Posted December 30, 2018 I’ve been thinking I’d like one of these trucks in the collection, however the body shells look somewhat nightmarish to decal. i don’t really like the stickering bit 1 Share this post Link to post Share on other sites
Jason1145 3986 Posted December 31, 2018 In a way I'm glad the bodyshell is the last thing to do....... otherwise I'd never have started this build! Next is step 10 - attaching rear axles - where I get to use my Yeah Racing universals in place of the massive plastic dog bones. I also have to select the correct rear body posts (B5) as per the BuggyRa bodyset instructions And fitted 1 Share this post Link to post Share on other sites
Jason1145 3986 Posted December 31, 2018 Step 11 is prepping the front arms 12 - Making the front diff 13 - Attaching the front fdiff onto the propellor shaft.... still ot received my 1280 bearings so using the brass ones for now Share this post Link to post Share on other sites
Jason1145 3986 Posted December 31, 2018 Step 14 is attaching the front arms and diff case And fitted - once agan the A5 (top arm holder) is loose until the centre brace is fitted later 1 Share this post Link to post Share on other sites
Jason1145 3986 Posted December 31, 2018 Step 15 is attacing the front bumper..... Steps 16 and 17 deal with the front arms and uprights... another set of Yeah Racing Universals here 1 Share this post Link to post Share on other sites
Jason1145 3986 Posted December 31, 2018 18 + 19 - making the shocks and attaching them front and rear - replaced with 53619 Mini CVA oil shocks Need to replace these ball joints to use the included stepscrews Instructions say use the inner most top shock mount - not sure what difference this will make as opposed to using the outer location? And fitted Step 20 makes the first part of the steering arms Step 21 attaches the front bumper And here she is nearing completion..... 4 Share this post Link to post Share on other sites
svenb 3778 Posted December 31, 2018 Nice to see you building 😉 If I were you I'd put the ball collars back in the dampers, their a lot better than the step screws if you any screws longer enough! 1 1 Share this post Link to post Share on other sites
Jason1145 3986 Posted December 31, 2018 2 minutes ago, svenb said: Nice to see you building 😉 If I were you I'd put the ball collars back in the dampers, their a lot better than the step screws if you any screws longer enough! That’s the only reason I swapped out the collars due to not having self tappping screws that were long enough - I only had machine screws ( the fine thread with a button head) that were long enough and I wasn’t sure if they would be ok or not? Lol I can build the basic stuff, as in, its just a general lack of time and not having a dedicated place to leave it all unpacked mid build. Currently I spend (waste) 10 minutes at the start and end of an hours stint packing and unpacking it again which isn’t ideal... that’s why I’m daunted to start most build. Unlike the TB03 however which looked like it was a complete challenge so I farmed it out to another member, till it got the best of him too and I got it back half built, but the second half build of that was not too bad despite the stopping and starting. Share this post Link to post Share on other sites
svenb 3778 Posted December 31, 2018 25 minutes ago, Jason1145 said: That’s the only reason I swapped out the collars due to not having self tappping screws that were long enough - I only had machine screws ( the fine thread with a button head) that were long enough and I wasn’t sure if they would be ok or not? Lol I can build the basic stuff, as in, its just a general lack of time and not having a dedicated place to leave it all unpacked mid build. Currently I spend (waste) 10 minutes at the start and end of an hours stint packing and unpacking it again which isn’t ideal... that’s why I’m daunted to start most build. Unlike the TB03 however which looked like it was a complete challenge so I farmed it out to another member, till it got the best of him too and I got it back half built, but the second half build of that was not too bad despite the stopping and starting. If you want any screws let me know if have hundreds 😯 I find the build the best bit, more complicated the better. I've recently built a tb03r👍 Bodies I don't enjoy 😯 1 Share this post Link to post Share on other sites
Jason1145 3986 Posted December 31, 2018 1 hour ago, svenb said: If you want any screws let me know if have hundreds 😯 I find the build the best bit, more complicated the better. I've recently built a tb03r👍 Bodies I don't enjoy 😯 I’ll bear the offer in mind cheers but i’ll leave it for now, I’m opposite I prefer bodies... but this has been a nice build and I think I’m about 5 hours in and it’s nearly finished now... chassis anyway. I just finished the steering which is the part of a build I dread the most as I then have to dig around for all the Electrics ( no I don’t want a servo centre machine thanks) and find a charged battery! Then it’s the centering and sorting out the servo with its saver/posts/ mounts etc and making sure there’s no no no no binding etc lol... but it’s all come good after I found an error I’d made when I installed a steering bridge the wrong way round and it wouldn’t line up with some other parts it was supposed to... duh! More pics to follow shortly. I prefer doing the bodies... we should partner up and swap jobs! Wheres the TB03r Build thread? I’d be interested to see it compared to my TB03, did you go with IFS too? Share this post Link to post Share on other sites
Jason1145 3986 Posted December 31, 2018 Step 22 - Steering arms Little knobs! The next steps involved the steering so it meant getting the electrics out... I have seen this servo recommended on here so I bought 3 a few months ago and it's now time to test one out... analogue 4.5KG and waterproof with my preferred 25t spilne. My servo was bang on 8mm.... great! (Fitted as "more than 8mm" position) And fitted and tested ok with no binding Share this post Link to post Share on other sites
Jason1145 3986 Posted December 31, 2018 Step 25 - fitting that central support over the prop shaft Next step - i was dubious to fit this motor cover as it hid the nice looking motor, but I thought it will stop any fingers getting burnt so fitted it The next steps involve the putting the hex's and wheels and tyres on... I still need to go back and secure the ESC and receiver in place with double sided tape - but then the chassis will be finished... in 4 days I think.. a record! Now... where's that bodyshell got to?! 2 1 Share this post Link to post Share on other sites
svenb 3778 Posted December 31, 2018 I didn't do a build thread mainly because I can't upload photos anymore 🤔. Emails not a problem! I went IFS as the R kit comes with a funky aluminium rocker brace👍. 1 Share this post Link to post Share on other sites
Jason1145 3986 Posted January 1, 2019 Here's the low down on the Buggyra bodyset..... I made a start on this today..... still to get the chassis runing lol https://i.imgur.com/eESVG9g.jpg[/i Still with me at the back? I started at this step and it took me 45 minutes to cut these 5 pieces out of this one lexan slab... and even then I balls'd it up! NOTE - there are no templates for the side mirror inserts... I'll have to measure them out later Aaaaaand the main cab cut out... quite proud of myself for getting those two little semi circles cut as they are required to fit onto the lower body properly.. Here it is sitting on top like so Here's my word of warning for you all.... it's obvious but I'm sure we've all misaken a cut line at some point and gone oops after lol I did cut one of these off and no I realise the error it will cause as shown below.... it's the edging of the rear wheel arc... I'm going to have to bodge it back on but it's only got 3m of material to fix at a 90 degree angle to another flat piece! That's all for now, back to work tomorrow so time will be limited again, i've enjoyed this whole holiday period off work and made lots of RC progress in between being the regular super dad/husband/son etc ;p 4 Share this post Link to post Share on other sites
Superluminal 3750 Posted January 1, 2019 Do these tyres have foams in? They have a much taller side wall and dont look like they would fit normal touring car foams. Share this post Link to post Share on other sites
dc-arena 81 Posted January 1, 2019 Look at those body instructions!!! Ffff! Then the decals! Shhh! That’s the stuff of nightmares 😂 2 Share this post Link to post Share on other sites
Jason1145 3986 Posted January 1, 2019 2 hours ago, Superluminal said: Do these tyres have foams in? They have a much taller side wall and dont look like they would fit normal touring car foams. No foams included but thee tyres are the best for seating on a rim I’ve come across and feel like they can run without gluing... but I will glue them before running it outside 1 hour ago, dc-arena said: Look at those body instructions!!! Ffff! Then the decals! Shhh! That’s the stuff of nightmares 😂 Thank you! Thought it was just me 😆 I’ll really have to sit down to work out if I want to change the paint scheme to make sure any new colours compliment the decals. I held the 3 main pieces of the shell up against eachother tonight and now I can finally see how it’s supposed to come together, luckily my ham fisted use of the scissors hasn’t ruined it yet... famous last words. 1 Share this post Link to post Share on other sites
Jason1145 3986 Posted January 1, 2019 I found out about the template for the wing mirrors, there’s a silver mirror decal you just use as the template duh... now I remember doing that a couple times before on other builds.. it was a bit of a hassle then doing it on just a ‘normal’ car bodyset too ... meh what’s another little job to join the queue Got the chassis running indoors tonight and it’s super smooth, I initially forgot to mount my Yeah Racing illuminated ESC plate - so it’s now mounted on the servo under the receiver where it’s actually more on show so that was a good blunder. 1 Share this post Link to post Share on other sites
Fabia130vRS 2098 Posted January 2, 2019 On 12/31/2018 at 4:42 PM, Jason1145 said: Step 22 - Steering arms The next steps involved the steering so it meant getting the electrics out... I have seen this servo recommended on here so I bought 3 a few months ago and it's now time to test one out... analogue 4.5KG and waterproof with my preferred 25t spilne. Next time have a look at Turnigy D303 digital nylon servo, 4,5kg 0.10sec for 5$. In my opinion better then analogue. cant wait to see how the body will be done. 1 Share this post Link to post Share on other sites
speedy_w_beans 4272 Posted January 2, 2019 Glad to hear the chassis is running smoothly. I'm with Fabia130; I'm looking forward to seeing the shell finished. 2 Share this post Link to post Share on other sites
Badcrumble 4203 Posted January 2, 2019 @Jason1145 Are you still struggling with box-art? Have you got any of that chrome you used on that McLaren left? I reckon chrome / black would look mean and not disturb the decals too much? Or pink and black? I know, I know - knock it off and go and build a TT02 ;-) 1 Share this post Link to post Share on other sites
Jason1145 3986 Posted January 2, 2019 11 hours ago, Fabia130vRS said: Next time have a look at Turnigy D303 digital nylon servo, 4,5kg 0.10sec for 5$. In my opinion better then analogue. cant wait to see how the body will be done. Will do Fabia130vRS thanks for that. 10 hours ago, Badcrumble said: @Jason1145 Are you still struggling with box-art? Have you got any of that chrome you used on that McLaren left? I reckon chrome / black would look mean and not disturb the decals too much? Or pink and black? I know, I know - knock it off and go and build a TT02 ;-) That was an American Spazstix Mirror chrome that was hand carried back from the USA by a colleague.. and it’s all used up so that’s that I thought quickly of black and yellow and then immediately realised it’d be a bumble bee... 🐝 I ruled out pink n black. Yes isn’t there a TT02 you need to build somewhere! 🤣 1 Share this post Link to post Share on other sites
