NL1990
Top Force 2017 - black evo spec.
Starting of with a fresh Tamiya Top Force Re-Re 2017 (47350)
I have decided To color the wheels with Rit dye Black .
After doing some magic water dipping.
Hit the lettering with magic marker.
The original Tamiya top force decal sheet wil be replaced with a Mci racing top force evolution original color pattern decal sheet .
Im still waiting on a couple more parts in the next coming week, to make this a custom evolution spec. Wil be Updated soon.
  • Like 10
The beginning, i replace the standard nylon gearing with tamiya 50529 plastic gears , i add tamiya 47328 speed tuned gear set . Not to mention a full ball bearing set.
53136 2x one piece ball thrust bearing
Gpm alu prop shaft , Gpm alloy front gearbox cover (bottom)
1823636630_2019-01-1723_20_17.thumb.jpg.fec6869fc2cf0a8a4064ff6f1599d31f.jpg1915056531_2019-01-1723_20_38.thumb.jpg.e07c0440cf0f613858e9bfb1e95e3191.jpg476795808_2019-01-1723_21_09.thumb.jpg.5a8f05c11a00b82403c62fc3eed69cf8.jpg1681374959_2019-01-1723_21_23.thumb.jpg.fd43e2b00f139c615e97a3bd41e44db7.jpg
Losing those ugly red front knuckels
Replace em with black ones
Add black gpm c hubs
Use 53109 turnbuckle shaft set
Use 53598 black ball connectors
Still need some black wheel nuts and
Some Touring Car Lightweight King Pins.459351212_2019-01-1822_52_08.thumb.jpg.5e112e63c7f53f86ce29689774b3b908.jpg506823915_2019-01-1822_52_55.thumb.jpg.16000f87b5d138a7fd8007f185d0011f.jpg246727178_2019-01-1822_53_15.thumb.jpg.e6682dfb6e14057b5ce9b61a1216a346.jpg
Action video :https://m.youtube.com/watch?v=-KjWuHNYJyQ
Setup
Goolrc 4300kv motor
Hobbywing ezrun 80A esc
69t higspeed tuned gearset
21t module
3200mah 30c 11.1v lipo
Spektrum dx 3.0
Some small upgrades
 perfect looking rc jazz aluminium rear gear box
l29qmvqyvhzo3.jpgJ12 fix
Added a full titanium screw set
after I broke my differential from my top force last week,1.jpg.20fd7b0942ccf4ba923bb12859934258.jpg
2.thumb.jpg.8ff7366a26f78f934b3dee146893a0fe.jpg3.thumb.jpg.34ec0ec5a8e8d457a2814972032f02e6.jpg4.jpg.3caaf108c4a922467fa5bc3276d3ecd3.jpg
To much power on these splines
I decided to replace them right away with the correct TA-03 replacement
5.thumb.jpg.1fba65cdcae97b7845f39a303b671001.jpg6.jpg.43c662423c6908bac32d67e64fd5df46.jpg
7.jpg.9580f1bc47c3283d27b0fdd0dffc20b4.jpg8.jpg.bef1f0df11b6ba40af37d916d82dcd30.jpg9.jpg.541233be144964b6b34108c22f4dbcd3.jpg
I realy enjoy running this one its holding up real good i only drive 11,1v with 4300kv and its been taking big jumps highspeed crashes and holds up good
Is the ta03 diff gear a smaller diameter than the original one or is it just an illusion in those pictures?
Yes on one side it smaller
Are the TA03 diffs better than the stock ones in the Top Force?
Yes they are much lighter and stronger very big improvement
