Morning gents
I have a question to all . Can anyone tell me if I can get hold of Bruiser wheel adapters to change the three bolt wheels to 12mm standard hex's? I have a good range of tyres and wheels for MT's and scalers all with the 12mm hex hubs. I'd like to fit these to my Bruiser but am unsure if an adapter is made for them.
Can anyone help me here or if someone has done the conversion can you post pics up and tell me how its done?
Regards
J
7 hours ago, voo2doo said:
Cheers Twinset , I think they might make the wheels stick out a bit too far .Pity.
J
if your worried about the wheels sticking out to far then put on a set of fender flairs. i have orderd these myself a week ago.
https://www.ebay.co.uk/itm/1-10-RC-Crawler-Parts-Rubber-Fender-Flares-for-RC4WD-TF2-Mojave-Tamiya-Hilux/392179920037?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Yes,  because the arches are rubber there is a fine line between tightening the small bolts and pulling them through the arches so i added the bolts after the glue had cured.
what kind of glue did you use then
Some folk I know use rubberised super glue but I used two part epoxy resin.Then I covered my paintwork up and taped them on.
J
