Andyfish2000
Brushless and/or Lipo for re re Hotshot
Having put the cars down for the last year or so whilst I built up my flying capability, I have a renewed interest again in getting some of the cars running.  One thing that I have avoided up to now is lipo batteries and brushless motors, but with the planes mostly having them i have begun to understand some of the benefits and so thought I ought to consider upgrading the cars.  So my first one is likely to be my hotshot re re.  It currently has a sport tuned Tamiya black motor which obviously adds some speed,  Would I gain a lot from simply getting a lipo (and LVC) for it on its current set up or should I also consider brushless motor and new ESC?
Andy
Adding lipo on its own does make a difference, I was surprised when chucking a 2s lipo into a stock TT02B how much faster it was.
The thing with brushless motors is you need to get the gearing right to make the most of it. In my Boomerang i run a Trackstar 13.5T with the biggest pinion (17t I think) and I find it goes really well on NiMH. 13.5T is the sweet spot for me in Tamiya buggies (well the rere or budget end, obviously TRF or DB01 could handle faster). I run the TBLE-02S as well, you don't need to change ESC. You wouldnt be able to gear a 17.5T high enough in a Hotshot, they get to about 7.8 FDR from memory which is probably better suited to 10.5T. 10.5T pushes the limit of the ESC though.
I prefer NiMH for bashing as I can leave them charged and usually when we run in the backyard its my son asking to do it right away. I use lipo for racing but don't have any that fit my Boomerang so haven't tried it.
Yep, what Jonathon said!
Lipo faster, check.  13.5T being the sweet spot for TBLE02s, check.  Higher gear ratio, check.
If you are curious about NiMH vs LiPo?  About 12-15%.  Because LiPo is lighter, has a higher voltage and maintains the high voltage during discharge.  Sometimes though, a heavier car feels better. So that's something else to consider.
As above, lipos add a volt+ more, a tonne of amps more, lighter and sustain the voltage longer before dropping off, just need a bit more involvement in looking after them.
Brushless motors are more efficient,  so more of the energy is converted into speed/power and if you go for a Sensored system,  can alter the timing through the rpm range, giving a real boost in rpm.
I'm loving the 10bl120 esc atm, will run down to a 4.5t motor on 2s, or a 13.5t on 3s, for under £40! :-
https://www.modelsport.co.uk/hobbywing-quicrun-10bl120-sensored/rc-car-products/425021
(Its a bit of a faff altering the settings, drag brake etc with the button, but once you do it a few times you get used to it, or get a plug in programmer)
That'll leave, pretty much any brushless motor to choose from, I know of people running that chassis with a 10.5t on 3s, but a 13.5t maybe a good starting point.
