Selling my Tamiya TA04-SS which has been painstakingly converted to TA04R
This car was built brand new in late '16 for the 2017 Iconic cup. After a successful championship win, it was converted to a TA04-R spec for the 2018 season.
A last minute decision was made to use a TB02, so it was used a few times, but less than 10 runs outdoors
It was also loaned out to compete in the 2018 Iconic cup indoor event where it took TQ & finished 3rd overall
It started life as a TA04-SS. Here is the list of options fitted to make it a TA04-R plus all the parts to make it competitive in the iconic cup:
Carbon tub lower deck with flex post
Carbon fibre top deck
U/J's fitted F&R
Stabilisers F&R
Ball diffs F&R
TRF blue dampers
Alloy servo mounts
Low friction belts F&R
TA04 racing hub carrier set
TA04 blue alloy steering set
TA04 finned motor mount
0.4 module spur gear
I've also added some parts:
Hex head screws fitted all round
Blue alloy ball studs. Steel ball studs where strength was needed
Moodyfools titanium droop screws
HPI 5.5mm allox hexes
Chassis has been modified to accept Vapex lipos (ok'd prior to modification, so perfectly legal). Chassis has outdoor use, hence scratches
I am including all the spares listed including the SS suspension arms, some spur gears & some new parts. I am including the original chassis, plus the TA04 carbon lower deck (brand new), I found after purchase it wasn't a R spec.
I will also throw in a Hobbywing 1060 esc, a TP 17t brushed motor & some used  Sorex 32r BRCA tyres to get you started
Note: you will require a pinion gear & servo saver plus your radio gear to get it running. A suitable shell will be required for its current setup. Fit the SS arms to use the MR-S shell
Its boxed with the instruction manual plus the Toyota MR-S carbon print shell
I can also include 2 Vapex 3300 mah lipos for additional cost
£250 posted. Collection from Bristol possible
A picture won't load for some reason. Pictures available upon request
